Can anyone tell me what I've done to my tailights. They don't light up in the E pattern anymore. This is a genuine mk4 but I have been messing around with some coding so I'm not sure what I have done
Sent from my SM-G988B using Tapatalk
Did you do an Auto-Scan and did you save it before you changed the coding? if so revert back to the old code by going into the log and copy and paste it into the new coding box found in the coding section of the correct module if that makes sense? then start againR8umar wrote: ↑Thu Dec 17, 2020 3:24 pm Decided to do the VW badge gloss black and wrap the backing the same colour as the van
Can anyone tell me what I've done to my taillights. They don't light up in the E pattern anymore. This is a genuine mk4 but I have been messing around with some coding so I'm not sure what I have done
Strange, AFAIK there's no way to do this via coding. Needs a EEPROM edit via VCP..
I did it using obdeleven. It had a history mode so I should have my original coding there I'll give that a go. Thankscaddychris2002 wrote: Did you do an Auto-Scan and did you save it before you changed the coding? if so revert back to the old code by going into the log and copy and paste it into the new coding box found in the coding section of the correct module if that makes sense? then start again
Possibly. I don't know anything about whatever app you're using, where it gets software updates from or what applying them does to your vehicle. You need to edit the BCM configuration EEPROM and write it back to BCM. AFAIK the only software that can do that is VAGCANPro.
