Simonh23
Post by Simonh23 »
purplebaghera wrote:Wobble blocks fitted
How have you found these mate, has it been notably more stable?
Reason: reduced the quote
Jeff007
Post by Jeff007 »
Fitted curtains and drilled thru a wiring loom.
Gazear
Post by Gazear »
Booked a remap for next week
2012 LWB 1.6 101 blue. Not a BG van.
@jeff
ARRGH !
:cry:
Curtain pics if you can ?
Jeff007
Post by Jeff007 »
StImage
StImage
AImage
Still got the rear sides and cab divider to go. Plus the riveting for the press studs. This end was where I went thru loom. Was gonna glue them too. Image
Thanks for the pics
Lots of fun fitting them ...
RY_VW
Post by RY_VW »
Little doofers finally came to fit it so on it went, couple of scratches + more now from dropping it on the gravelImage not bad for £30 though. Just need the oil filler ring now Image
Sent from my SM-A202F using Tapatalk
More to follow 8)
Markyk
Post by Markyk »
Fitted caddy life mirrors and side door rail covers Image mirrors were a swine with the various antennas and such that needed swapping over but got there in the end! Image
DjLoop
Post by DjLoop »
Try to make lock mechanisem work with 2019 dorrs on. 2008 caddy 🙈
Vw Caddy 2008 Carrera Cup Showcar/Db Drag/Demo car
1200Ah Winston Lifepo4 Lithium
114kw in Amplifier power
140m 40 x 40 Steel reinforcement
Bullet Proof Glass "14mm"
370a Mechman Alternator
8 pot RS6 Calipers
370mm RSQ5 Discs
EGR Delete
PDF Delete
038 130 073AL injectors
Turbo GTB1749V
Full Powerflex
Jono1
Post by Jono1 »
@markyk
Where did you get the rail covers from?
Mirrors look spot on aswell.
Both top of my list 👍
Markyk
Post by Markyk »
@Jono1
Hi man
I got them from a guy on fb. He also lists on eBay here’s the link. This is for the maxi x2 rails. He offers them plain or painted.
https://www.ebay.co.uk/itm/VW-Caddy-2K- ... 890.l49286
Mirrors also from him Image
Ryzar1
Post by Ryzar1 »
Just thought I’d post an updated picture of my caddyImage
Ryzar1
Post by Ryzar1 »
My coil overs should arrive soon I’ll post another pic with it lowered
Looking good
Tagllana1
Post by Tagllana1 »
Hi @Ryzar1, did you get the side window fitted yourself? If so, can you point me in the right direction please?
Tom
