stewartcjones
Post by stewartcjones »
Image Image Image Image Image Image Image
Removed ramp welded in new section ready for new bumper and also added front splitter
J_Con
Post by J_Con »
Cheers @petrev didn't realise how much I liked it until it was gone!
Van was washed today with Gyeon Bathe+..very nice shampoo to use
S400ASP
Post by S400ASP »
Improvised spray booth!
Chalks
Post by Chalks »
What did I do today? Sliced my fingers up!
Finished it off and wrote up How to ...
2 x Reversing Lights + 2 x Rear Fog - UK Mk4 - ?MOT?
Adz87
Post by Adz87 »
Technically this was yesterday, but finally managed to get all of the black plastic parts (bumpers, door mouldings and handles etc) colour coded. And the set of Audi split rims I’ve had laying about for a few years refurbed and on! She’s looking sharp!
S400ASP
Post by S400ASP »
Adz87 wrote:Technically this was yesterday, but finally managed to get all of the black plastic parts (bumpers, door mouldings and handles etc) colour coded. And the set of Audi split rims I’ve had laying about for a few years refurbed and on! She’s looking sharp!
Looking good Image
S400ASP
Post by S400ASP »
Fitted the new mirrors this morning
anoneamus
Post by anoneamus »
Lockstock wrote: Thu May 12, 2022 1:27 pm @anoneamus
Did you have to have your speedo coding adjusted in vcds for the 205 70 tyre as I imagine the bigger circumference would give you lower speed reading than actual...
Speedos are usually calibrated to read slightly higher than the actual speed. With these tyres it's actually slightly more accurate (measuring with GPS). In any case it's within the 5-6% of the original wheels circumference so one does not generally adjust speedo (or expect gearbox etc. strain on that small a change in wheel size - I believe 7% is the cutoff beyond which one needs to adjust etc.).
Lockstock
Post by Lockstock »
Cheers man, good to know. I found that there are higher load options available in the 205 70 than 195 65, and the 195 65 just looks too small on the caddy maxi.
Based on yours I'm gonna look into it at next tyre change 👍
anoneamus
Post by anoneamus »
Lockstock wrote: Mon May 16, 2022 8:15 am I found that there are higher load options available in the 205 70 than 195 65, and the 195 65 just looks too small on the caddy maxi.
Use this wheel size calculator to see what will fit and what won't and whether whatever you're choosing is within 7% of what came with the car.
https://www.wheel-size.com/calc/
mangrovejack
Post by mangrovejack »
Did a whole bunch this weekend gone, installed new headlight bulbs, new double DIN head unit and started deadening the front doors (what a chore that one is!). Not going to double post, you can see the results in my build thread - viewtopic.php?f=13&t=50069
Hmmm ?
Too flashy ?
Gloss black + Emblem
Finished the gloss black on the new grill.
Didn't do any grey tint in the end.
G1L8313
Post by G1L8313 »
Managed to lower it abit more
