m-racer
Post by m-racer »
I mounted Touran Seats today. Everything was straight forward. Only the airbag connector had to be switched.
No lights came up. But I am going to check everything with vcds again to be sure.
The seats are much better than the original ones. 😁👍
I only need to get the heating cables somewhere. Any ideas?
@tommyzooom
@stan-the-man
Handyandy
Post by Handyandy »
Changed the front suspension wishbones today and give the van a service changed all the filters even the cabin filter which I never new I had until last year that was obviously the original one put in when the van was registered back in 2013 but all done now till next year
Deanomk1
Post by Deanomk1 »
Finished carpet lining the main parts of the back today. Replaced the rubber floor up front with new black carpets including behind the seats. So much nicer inside now.
Ran the power, ground, new speaker and tweeter cables in. Just have to remove the head unit tomorrow and splice in to speaker wires then I’ll make a mdf mount to sit in the rear void and get the amp and crossovers mounted.
D866
Post by D866 »
Machine polished my swap black pearl van. First time polished since it was made I’d say!
m-racer
Post by m-racer »
Hi, how can I get in touch with these guys? I am not able to write private messages!?
petrev wrote: Sat Jun 10, 2023 1:26 pm @tommyzooom
@stan-the-man
enk005
Post by enk005 »
@m-racer if you use instagram you can message them there.
@tommyzooom
@stanthevwcaddyman
m-racer
Post by m-racer »
Thank you. I will do that. 😀👍
raitis
Post by raitis »
Had my first attempt at rust repair on the outside of the boot lid using a spray called Brunox. I was not very careful with sandpaper and scratched the paint under the VW emblem :( Will touch that up later but leave most of the repaired areas as is since it will be hidden by the number plate holder and light cover trim. There are design flaws with Caddy mk3 boot lid/barn door number plate cover trims as their plastic becomes brittle and cracks. They also vibrate, hitting the paint and exposing affected areas to rust. Also, the foam padding underneath the license plate holder collects moisture which also results in rust. I need to do the inside of the boot lid next. It is even worse :oops:
Deanomk1
Post by Deanomk1 »
Finished installing new hertz components, sound deadened the doors. Went and got a sub for behind the passenger seat, managed to squeeze a 10 inch audison one in there. Ran the remote for the sub and mounted it under the esp button. Refitted the bulkhead. Really impressed with the sound of it all
jme9
Post by jme9 »
Been getting started on a small conversation, so I bought an old VW Touran, whipped the seats out and gave them a real scrub, and jetwashed them down. Fitted the bases, waiting for them to dry so the new seats can go in.
Over the weekend I fit a leisure battery under the passenger seat, with a split charge system. Almost ready for insulation and carpet.
Zippy320
Post by Zippy320 »
Received my air duct parts today from VW , Installed them as soon as I got home from work , I feel more and more complete er the car is now almost complete as it would have been from factory. I'm going to order the wiper caps for it soon , apparently these cars don't come with them from factory but it can be added so ill do it , that and the engine cover if I can figure out which one fits and if I can find them .
Missing 1 important item though , the plastic undercarriage engine splash shield . Can I get this from another type of car or does it have to come from the Caddy model that I have?
Still a long way to go to get it to the level that makes me comfortable , but im getting there slowly .
Still new to VW
Still getting used to the smell of a diesel engine .
2008 VW Caddy 1.9 TDI Manual
and Various other cars .
Russ74
Post by Russ74 »
Zippy320 wrote:Received my air duct parts today from VW , Installed them as soon as I got home from work , I feel more and more complete er the car is now almost complete as it would have been from factory. I'm going to order the wiper caps for it soon , apparently these cars don't come with them from factory but it can be added so ill do it , that and the engine cover if I can figure out which one fits and if I can find them .
Mk5/6 golf Jetta under tray is the same.
Golf 6 etc. is the same as far as I can tell.
Scrapyard Time.
Need cover, screws, bolts, and speed nuts as per LLLPARTS listing below.
OEM come with noise reducing square air filled dots !
Aftermarket often don't have this extra layer.
e.g. https://www.ebay.co.uk/itm/363764515143
https://www.lllparts.co.uk/catalogs/vw/ ... 825/825000
This page shows a few variants (Full cover MkIII is the type you are looking for.)
https://www.audivw24.de/search.php?text ... +caddy+III
Handyandy
Post by Handyandy »
Replaced the rear wheel bearings while a removed them to replace the old rotten disc protectors for some nice new ones. Now to put It all back together and on the ground
Sent from my SM-A125F using Tapatalk
