Stop start function disabling
Coopzcaddy
Re: Stop start function disabling
Post by Coopzcaddy »
Sportvan wrote:Stop start, it’s a pain in the arse with DSG and dangerous. The van has shut the engine off as you come up to roundabouts without it coming to a stop and if it’s clear and you want to go you have to wait for the sodding thing to start again. If I knew a way of disabling it permanently with VCDS I would.
Being ex vag the reason this does this is because the wheel speed sensor is linked to the ecu and detects your braking and below a certain speed it sends a message to say " were stopping " so shuts the engine down. Pain in the arse I know Image all my dsg cars I had as company cars did this.
dan@biali
Post by dan@biali »
In the Life there is a switch to turn start stop off. You can just make out the A Off button on the right just above the gearstick.
Caddyluv
Post by Caddyluv »
Mine you can turn it off. Standard trendline caddy 4. Exactly the same way.
Geraout
Post by Geraout »
OP knows there is a button - he wants to turn it off permanently.
Caddy bridge wrote: Sat Apr 21, 2018 8:26 am Is it possible to disable the stop start function ? I know there is a button to turn it off in the cab for a short while.
dan@biali
Post by dan@biali »
My bad! But the canbus control box I linked to would do what he wants.
mark1a
Post by mark1a »
I'v been considering one of these, operates the switch itself so no coding and non-invasive to ECU.
https://www.ebay.co.uk/itm/NEW-Start-St ... 2352078637
Estoril 18” | OE Xenons | Limo tints | Wind deflectors
Alpine iLX-705d HU | Focal 2.1+2 audio | Dynamat | 4G WiFi | Wireless phone charge
Royston21
Post by Royston21 »
Sportvan wrote: Mon May 07, 2018 6:02 pm Stop start, it’s a pain in the arse with DSG and dangerous. The van has shut the engine off as you come up to roundabouts without it coming to a stop and if it’s clear and you want to go you have to wait for the sodding thing to start again. If I knew a way of disabling it permanently with VCDS I would.
I agree it’s a real pain. Been in a few close calls due to starting and then cutting straight out and saying “start engine manually”
Not noticed mine cutting engine before I stop
Pepsi
Post by Pepsi »
I'm sure there must be a way to do this.
I did it on my mk7 golf gti last year using OBD Eleven. There was a video online r that show you how to do it. Should be similar on the caddy?
I'm sure you could get the same results with vcds
This is the video for the golf.
https://youtu.be/Zdhejtz3mhw
Best thing I ever did as always hated stop start.
Nice one Pepsi
Gateway 19
Adaptation: Setting voltage limit to 12 so that it never kicks in.
Neat trick, have to give it a go...
Sportvan
Post by Sportvan »
I just got used to disabling it every time in the old caddy. The new one is exactly the same, it will cut the engine as you coast to a stop. To disable it in that, you swipe down on the screen and then press the disable start stop icon on the screen.
Pepsi
Post by Pepsi »
@petrev
dan@biali
Post by dan@biali »
Did you see the link to the other video where the guy just disconnects the start stop plug from the battery? No need for vagcom and quickly reversible. No idea how sensible that is though!
https://www.youtube.com/watch?v=DafjVxuTjFk
I have a box fitted to another car that is like the thing mark1a linked to that remembers settings so I don't have to press buttons every time I start the car. Works well and again, completely reversible.
Hi Dan,
Can see lots on AliX for Golfs, Skodas etc. but none for Caddy.
They are loop through devices and have the wrong plugs, sadly.
wildybeast
Post by wildybeast »
This maybe of interest http://www.4gochip.com/
mark1a
Post by mark1a »
^^^ it links to the eBay listing I posted 3 years ago, same module, same seller.
