Caddy 5 options/upgrades - split from "2020 Caddy 5 press launch and information"
Sportvan
Post by Sportvan »
@Jasons6930
Rain sensor is missing, all they fit is a humidity sensor,
With VCDS I can see that rain sensing wipers are enabled, I’m guessing it just needs to be told that it now has a sensor (just fitted by myself)
As it’s a commerce pro with the tech pack etc, the main board is programmed for all the components as such, rain sensing and CH-LH lighting is very low on the list!
I don’t have the led lighting in the load area, I do have the old roof lights from my old caddy and have wired them into the tailgate. It’s going to Van racking solutions in fee down at some point to be fitted out in the back, I need to get my wiring before then!
JimmyKombi
Post by JimmyKombi »
@Sportvan
I have the same spec but with Barn doors and I too have no auto wipers, after much discussion with the TPS guys we summised that unless you have a rear window (which with our spec would give you the auto dipping rear view mirror which has something to do with the rain sensor gubbins) you wont get auto wipers...so yes it just plain sucks
Sportvan
Post by Sportvan »
Hi Jimmy, that is utter BS! The wiring is there, I’ve got a tailgate on mine (glazed) and for some odd reason a solid bulkhead! There is a humidity sensor plugged in where the rain sensor goes. Also in VCDS I can see that rain sensing wipers are there and active in the programming!
The issue is, in the case of my van, the central electrics are in transport mode, and lighting is not in production mode either. I’m hoping to get back to SMV on Friday and show a tech, as im banging my head against a wall trying to explain it to service!
How does your van behave when you unlock it? Do your interior lights come on? Or only when you physically open the door? Do you have orientation lighting? (Flick main beam when leaving the vehicle) do the lights come on for a certain period?
JimmyKombi
Hmmm nope lights on only when I open the door and no nothing if i flick main beam
Sportvan
Post by Sportvan »
So your central electrics are in the same state as mine. I’ve also been speaking to a fellow auto electrician who does work for VW main dealers, and they are having a few issues. So I would be surprised if this is VW’s way of “fixing” the issues and then just fob the customer off!
JimmyKombi
@Sportvan
Well yes, I was a little surpised to have every gadget but no auto wipers, nice one looking into this, I look forward to your eventual findings!
Jasons6930
Post by Jasons6930 »
Sportvan wrote: ↑Wed Oct 13, 2021 3:41 pm @Jasons6930
Sorry forgot about this!
Well, having spoke to my dealer they were adamant that their demo had auto lights and wipes, now weather new vehicles have it is another matter. As i said before, even looking at the actual spec on the VW web, it does not mention them.
Anyway, had a build date of first week of May 2022 for mine so hopefully they might have sorted it all by then!
:D
Reason: reduced the quote
Jasons6930
Sportvan wrote: ↑Tue Oct 26, 2021 4:37 am Hi Jimmy, that is utter BS! The wiring is there, I’ve got a tailgate on mine (glazed) and for some odd reason a solid bulkhead! There is a humidity sensor plugged in where the rain sensor goes. Also in VCDS I can see that rain sensing wipers are there and active in the programming!
Ok, just taken delivery of mine and indeed, no CH/LH function (in the menus), interior light does not come on when unlocked (havent tried in the dark) and not sure about rain sensing wipers as it ain't raining!
Just need to check tyre pressures now as it looks (and feels) like they are inflated to the max!
Did you get any further with yours?
I have VCDS but i have run out of vins so i don't really want to spend out on more vins if a lot of the programming is not working with it.
EDIT: Just to note, i do not have a sensor at the bottom of the windscreen, just a plastic blank, and the rear view mirror is non dimming.
And a stupid bloody pointless lightbulb in the load compartment!!!!!
Jasons6930
As an update to this, reverse sensors don't make any noise in use, even though there is a volume slider for it in the menu, power steering groans like mad turning out of a junction, no rain sensors (no submenu in VCDS either, vehicle spec lists wipers with light sensor), auto headlights are on and off at the slightest whiff of cloud cover, interior light does not come on with unlocking (previous gen caddys did this but only in the load compartment) plus VCDS gives faults in various modules, and the ride is bloody horrendous after driving a fair bit on B roads.
Mind you, the latter i think is down to the shit Giti branded tyres that are fitted to the standard 16" rims that were inflated to around 46psi. Not even sure it had a proper PDI as every tyre was a different pressure. I've reduced the pressures in all of them down to 40, although that is still quite hard. I will probably give up and put some Primacy 4's on it all round some time soon.
Nearly all faults logged were dated the day i picked it up. so booked in beginning of June.
Just to add, the brand new transit connect I part ex'd never went near a dealer after i picked it up for the two years i had it from new.
Sportvan
Post by Sportvan »
@Jasons6930
I haven’t gone any further with mine, as the dealers and VWCS are utterly f**king useless. It’s got a service soon so when it goes in for that I want it all resolved or they can shove up their arse, and I will have my money back.
There is a sensor between the screen vents, this is what’s used for the headlights, it’s actually a sun load sensor for the climate control IIRC, put your hand over it and the lights will come on.
VCDS won’t work as the van requires a code and I’m buggered if I can find one that works. In Central electrics (19) auto wipers are activated, as it’s a host of other items. That are supposed to work, CH LH lights are active. They have left the BCM in transport mode and activated certain functions. The interior light will time out after 1 min if you manually switch it on and turn off the engine. The only way to have it on when doing paperwork say in the van it to have the engine running.
Just wait for your E Call system to f**k about. If you get the SOS fault visit workshop and the system doesn’t recover, This will leave you with no control over your infotainment system when you restart the van, pressing and holding the SOS button for 10 secs will reboot the system.
How the F**k this won an award (VOTY?) I don’t know. VW certainly know how to pay off the journo’s to get good reviews, possibly threaten to pull their marketing from them.
Toyota are doing a commercial version of the Corolla Estate. Bet you wouldn’t get any issues with that, or BS Like you get from VWCS.
Re the connect, I have to say in the 8 speed 120ps form I have it in, the van was rubbish. Suspension didn’t have enough travel so the ESP would kick in on an undulating corner at 40mph! The gearbox lazy, and servicing and running costs were higher than the caddy.
Reason: removed quote
Jasons6930
Thanks for the update.
VCDS is pretty much useless on the majority of modules now as VAG have a new form of protection called SFD protection, which can only be passed through either VAG or third party OBD units. I have just picked up an ODB II and once registered it will get the passcode for the modules. One thing that also dosen't work are the reverse sensor sound with the back up cam. The front works when it feels like it. I used the OBD to turn on the sound button on the screen, but all that has done has allowed me to silence the front, and installed and a random rear camera wash button!
After doing a module scan i don't even have the RLS sub menu so i am not even sure if it will ever work, even if they install a RLS sensor.
I have posted a scan of my 09 Module but its over a few posts..
Interestingly, a few days after the above scan, i switched on and got the notification of an 'update', but god knows what that did.
Admittedly i haven't rescanned to see if there have been any changes yet.
I spoke to my dealer and they were sure most of these things should work although they are not sure about the CH/LH.
When you installed you RLS, did you already have the control sub system showing or did it pop up automatically after you have installed the RLS and rescanned?
Jasons6930
Heres a scan of my 09 Module but its over three posts..
Code: Select all
SW:5WA-937-086-AF   HW:5WA-937-086-M ---  Cent. Elect.
;Component:BCM37w_M1028 0175     Coding:
;EV_BCM37w    7001    EV_BCM37w_007.rod
;Saturday    7    May    2022    18:06:15:35443
;VCDS Version: Release 22.3.1 (x64)  Data version: 20220407 DS337.0
IDE00001-ENG99061-Production mode-Access control    not active     3
IDE00001-ENG115730-Production mode-Exterior lighting    not active     3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren    not active     3
IDE00001-ENG112304-Production mode-Heckwischer    not active     3
IDE00001-ENG98647-Production mode-Interior lights    not active     3
IDE00001-ENG259333-Production mode-pa_ambiente_aussenlicht_pmode    not active     3
IDE00001-ENG258242-Production mode-pa_auto_abschaltung_pmode    not active     3
IDE00001-ENG263594-Production mode-pa_klemme_15_pmode    not active     3
IDE00001-ENG263561-Production mode-pa_klemme_50_pmode    not active     3
IDE00001-ENG260387-Production mode-pa_sitzpneumatik_pmode    not active     3
IDE00001-ENG281100-Production mode-Remotestart_Pmode    not active     3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung    not active     3
IDE00001-ENG115731-Production mode-Virtuel_pedal    not active     3
IDE00002-Transport mode    active     1
IDE00301-Mileage    0 km    4
IDE00820-Activating and deactivating all development messages    not active     1
IDE02152-Characteristics in production mode    2000 ms    4
IDE02332-Deactivate production mode    0    3
"IDE02455-ENG116601-Light function ""Coming/Leaving Home""-Coming Home Verbaustatus"    not installed     2
"IDE02455-ENG260981-Light function ""Coming/Leaving Home""-Darstellung Coming-home Verlauf"    not active     2
"IDE02455-ENG261352-Light function ""Coming/Leaving Home""-Darstellung Leaving-home Verlauf"    not active     2
"IDE02455-ENG115657-Light function ""Coming/Leaving Home""-Leaving-Home Verbausstatus"    not enabled     2
"IDE02455-ENG115863-Light function ""Coming/Leaving Home""-Menueeinstellung CHO LHO"    Menuesteuerung Zeit aktivieren     2
"IDE02455-ENG116602-Light function ""Coming/Leaving Home""-Menuesteuerung Coming Home Werkseinstellung"    not active     2
"IDE02455-ENG116606-Light function ""Coming/Leaving Home""-Menuesteuerung Leaving-home Freischaltung per BAP"    not active     2
IDE02488-Anti-theft system interior monitoring    100%    1
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischen    not active     8
IDE02711-ENG133397-Rear wiper-Einzelansteuerung Heckintervallwischen    not active     8
IDE02711-ENG133395-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1    8 s    8
IDE02711-ENG133396-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2    16 s    8
IDE02711-ENG112304-Rear wiper-Heckwischer    not installed     8
IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlauf    not active     8
IDE02711-ENG258487-Rear wiper-Heckwischer_Kaltstart    Heckwischerstopp bei Wiederstart und Erststart     8
IDE02711-ENG114946-Rear wiper-Komfortwischen Heck    active     8
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1    5 s    8
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2    3 s    8
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik    7 s    8
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall    7 s    8
IDE02711-ENG289598-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall LSS AUS    10 s    8
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW    not active     8
IDE02711-ENG261056-Rear wiper-Modus_Heckintervall    statische Intervallpausenzeit     8
IDE02711-ENG259069-Rear wiper-Rueckfahrwischen_Temp    OFF     8
IDE02711-ENG154784-Rear wiper-Spannungsanforderung_konfig_Wischer    Keine_Spannungsanforderung     8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck    active     8
IDE03787-Activate left/right hand drive switch-over    not active     1
IDE05534-ENG116609-Headlamp washer system-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung    5    7
IDE05534-ENG115769-Headlamp washer system-SRA bei Waschwassermangel    active     7
IDE05534-ENG115767-Headlamp washer system-SRA Einweichpausenzeit    0 ms    7
IDE05534-ENG115768-Headlamp washer system-SRA Nachwaschzeit    0 ms    7
IDE05534-ENG116611-Headlamp washer system-SRA Pausenzeit    10000 ms    7
IDE05534-ENG258416-Headlamp washer system-SRA Untersetzung Init    0    7
IDE05534-ENG116610-Headlamp washer system-SRA Verzoegerungszeit    0 ms    7
IDE05534-ENG115766-Headlamp washer system-SRA Waschzeit    2000 ms    7
IDE05822-Anti-theft alarm system vehicle inclination sensor    100%    1
IDE05823-DWA Interior monitoring parameter set    01 0A 08 00 43 53 0A 78 02 14 0A 32 81 33 0C FF 00 00 01 A5 16 03 00 0C 43 00 85 0A 37 F7 69 23 75 5B 57 DB 26 44 3F 3A 69 58 85 2D 0A A3 02 6A 06 53 00 0E 17 00 88 0A 30 F7 66 0F E3 4A 87 1B 06 34 3F 3A 69 58 83 08 0A A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 4A 77 1B 06 24 3F 3A 69 47 83 08 0A A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 28 57 1B 06 24 3F 3A 69 58 82 05 0A A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 55 5B 57 9B 26 24 0C FA 0A 34 85 2D 0A A3 21 03 00 25 35 0F 0F 0F 37 B7 51 42 2A F9     172
IDE06274-MAS05958-Light functions for special-purpose vehicle-intermittent low beam    Low beam     4
IDE06274-MAS05960-Light functions for special-purpose vehicle-intermittent high beam    High Beam     4
IDE06425-Dynamometer mode: functional    not activated     1
IDE07007-ENG128461-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt    active     8
IDE07007-ENG115720-Air conditioning/heating function via remote control-Remote Start    not installed     8
IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbaut    not installed     8
IDE07007-ENG128460-Air conditioning/heating function via remote control-Rueckmeldung_bei_Aktivierung    active     8
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module    20 min    2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus    255 min    2
IDE08786-MAS13782-Assistance light functions-Will Beam assistant: responsivity adjustable via BAP    not active     9
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung    500 ms    9
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen    not active     9
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit    sensitive     9
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe    active     9
IDE08786-ENG259537-Assistance light functions-Maskierung_Regenlichtmen    not active     9
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne    30%    12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz    25%    12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne    30%    12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz    25%    12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne    58%    12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz    53%    12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne    58%    12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz    53%    12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne    85%    12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz    80%    12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne    85%    12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz    80%    12
IDE09767-ENG133381-Position lamps-Bedingungen zur Parklichtbegrenzung    Switch-off due to energy management     7
IDE09767-ENG133380-Position lamps-Bedingungen zur Standlichtbegrenzung    Switch-off due to energy management     7
IDE09767-ENG137034-Position lamps-Faktor fuer Verfuegbarkeitstimer    Faktor fuer x5 Minuten     7
IDE09767-ENG115862-Position lamps-Lichtwarnungsverhalten    klemmenabhaengig     7
IDE09767-ENG115859-Position lamps-Parklicht ueber LSS aktiviert    One-sided     7
IDE09767-ENG126816-Position lamps-Standlicht aus    active     7
IDE09767-ENG115829-Position lamps-Standlichtreduzierung mit beidseitigem Parklicht    active     7
IDE09767-ENG133383-Position lamps-Standlicht-Verfgbarkeit    24 s    7
IDE10844-Control module rear lid opening: duration status query    0 ms    2
IDE10845-Control module rear lid opening: vehicle type-    0    12
IDE10845-ENG258964-Control module rear lid opening: vehicle type-p_a_p_mode_aktivieren_vip    0    12
IDE10845-ENG259328-Control module rear lid opening: vehicle type-p_t_delay_VIP_Freigabe_ZV_Ansteuerung    0 s    12
IDE10845-ENG260538-Control module rear lid opening: vehicle type-p_t_VIP_Bremslicht_hell    0 ms    12
IDE10845-ENG259913-Control module rear lid opening: vehicle type-p_t_VIP_Bremslicht_hell_offen    0 ms    12
IDE10845-ENG260941-Control module rear lid opening: vehicle type-p_t_VIP_Sperrzeit_Schlsselsuche    0 s    12
IDE10845-ENG259196-Control module rear lid opening: vehicle type-p_t_VIP_Verzoegerung    0 ms    12
IDE10845-ENG259996-Control module rear lid opening: vehicle type-p_v_VIP_aktiv    0 km/h    12
IDE10845-ENG261214-Control module rear lid opening: vehicle type-p_v_VIP_deaktiv    0 km/h    12
IDE12302-SFT00022-Identification of sub-bus participant-Steering column electronics systems    old     6
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control module    old     6
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor    old     6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch    old     6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module    old     6
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor    old     6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn    old     6
IDE12302-SFT271909-Identification of sub-bus participant-left tail lamp 1    old     6
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module    old     6
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interior    old     6
IDE12302-SFT271950-Identification of sub-bus participant-Rear lid opener control module    New     6
IDE12302-SFT271966-Identification of sub-bus participant-Left head area heater    old     6
IDE12302-SFT271967-Identification of sub-bus participant-Right head area heater    old     6
IDE12302-SFT272014-Identification of sub-bus participant-Control head for driving and comfort functions    New     6
IDE12302-SFT272057-Identification of sub-bus participant-Valve block 1 in front seat driver side    old     6
IDE12302-SFT272061-Identification of sub-bus participant-Valve block 1 in front seat passenger side    old     6
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrest    old     6
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushion    old     6
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrest    old     6
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushion    old     6
IDE12302-SFT272121-Identification of sub-bus participant-Control unit 2 for driving and convenience functions    old     6
IDE12302-SFT272142-Identification of sub-bus participant-left tail lamp 2    old     6
IDE12302-SFT272143-Identification of sub-bus participant-Right rear tail lamp 1    old     6
IDE12302-SFT272144-Identification of sub-bus participant-Right rear tail lamp 2    old     6
IDE12302-SFT272221-Identification of sub-bus participant-Radio receiver for remote start    old     6
IDE12302-SFT272238-Identification of sub-bus participant-Wiper motor control unit 2    old     6
IDE12302-SFT272272-Identification of sub-bus participant-Virtual pedal door opening: rear driver side    old     6
IDE12302-SFT272286-Identification of sub-bus participant-Virtual pedal door opening: rear passenger side    old     6
IDE13391-ENG246968-BAP function status-CHo_LHo_Nachlauf    0 ms    16
IDE13391-ENG115656-BAP function status-Coming Home Leuchten    Low beam     16
IDE13391-ENG116604-BAP function status-Coming-home Einschaltereignis    Ignition On     16
IDE13391-ENG116608-BAP function status-Helligkeitsschwelle Forward-Messung    0 lx    16
IDE13391-ENG116605-BAP function status-Helligkeitsschwelle Infrarot-Messung    0 lx    16
IDE13391-ENG116603-BAP function status-Menueeinstellung Cominghome    not active     16
IDE13391-ENG258918-BAP function status-Menueeinstellung Cominghome bei Tag    10 seconds     16
IDE13391-ENG259258-BAP function status-Menueeinstellung Leaving-home bei Tag    10 seconds     16
IDE13391-ENG116607-BAP function status-Menueeinstellung Leaving-home Zeit per BAP    not active     16
IDE13391-ENG258405-BAP function status-Tagfahrlicht mit CHO bei Tag in Stellung AUTO    not active     16
IDE13391-ENG259717-BAP function status-Tagfahrlicht mit LHO bei Tag in Stellung AUTO    not active     16
IDE15901-Direct entry keys    installed     2
IDE15902-MAS10541-rotary light switch-Light rotary switch with fog light    Yes     4
IDE15902-MAS10542-rotary light switch-Light rotary switch with fog tail light    Yes     4
IDE15902-MAS10543-rotary light switch-Light rotary sw. with AFL    Yes     4
IDE15902-MAS10544-rotary light switch-Light rotary switch with park. light pos.    Yes     4
MAS05894-IDE13022-Engine run on-Function activation    not active     4
MAS05894-MAS13391-Engine run on-Delay time timer    1500 ms    4
MAS07146-MAS13125-Button 1-Function of button 1    not coded/not installed     1
MAS07146-MAS13128-Button 1-Indicator lamp button 1    installed     1
MAS07147-MAS13129-Button 2-Function of button 2    not coded/not installed     1
MAS07147-MAS13131-Button 2-Indicator lamp button 2    installed     1
MAS07148-MAS13132-Button 3-Function of button 3    not coded/not installed     1
MAS07148-MAS13134-Button 3-Indicator lamp button 3    installed     1
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze    1200 lx    24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze    2200 lx    24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle    2000 lx    24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO    600 lx    24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten    1200 lx    24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten    2200 lx    24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red    00 1E     24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell    3500 lx    24
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway    not active     24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity    Medium     24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung    3800 mV    24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke    3500 lx    24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung    1400 mV    24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke    0 lx    24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung    2    24
MAS09325-IDE13878-Daytime running lamps-Activation: daytime running lights    Daytime running lamps     8
MAS09325-MAS09335-Daytime running lamps-Daytime running lights/parking light    not active     8
MAS09325-MAS16273-Daytime running lamps-Speed warning active: rear fog lamps    0 km/h    8
MAS09325-MAS21314-Daytime running lamps-Daytime running indicator lamp    not active     8
MAS09325-ENG142193-Daytime running lamps-Geschwindigkeitsabhaengiges TFL    0 km/h    8
MAS09325-ENG116594-Daytime running lamps-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich    not active     8
MAS09325-ENG122184-Daytime running lamps-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten    not active     8
MAS09325-ENG115734-Daytime running lamps-Tagfahrlicht nur in Schalterstellung AUTO    active     8
MAS09325-ENG116593-Daytime running lamps-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht    not active     8
MAS09325-ENG142192-Daytime running lamps-TFL_Abschaltung_ueber_Geschwindigkeit    not active     8
MAS09325-ENG116591-Daytime running lamps-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge    active     8
MAS12382-MAS06760-Dynamic turn signal control-Emergency flashers in roll mode    active     8
MAS12382-MAS07029-Dynamic turn signal control-Crash flashing    not active     8
MAS12382-MAS07032-Dynamic turn signal control-Emergency flashing    not active     8
MAS12382-MAS07033-Dynamic turn signal control-Panic flashing    not active     8
MAS12382-MAS07034-Dynamic turn signal control-Theft flashing    active     8
MAS12382-MAS07036-Dynamic turn signal control-Garage door opener adaptation flashing    active     8
MAS12382-MAS07041-Dynamic turn signal control-Taxi alarm flashing    active     8
MAS12382-MAS07044-Dynamic turn signal control-Rear lid opening angle adaptation flashing    active     8
MAS12382-MAS12781-Dynamic turn signal control-Telematic blinking or blinking by positioning assistant    active     8
MAS12382-MAS14169-Dynamic turn signal control-Confirmation flashing of the central locking system when unlocking    active     8
MAS12382-MAS14170-Dynamic turn signal control-Confirmation flashing of the central locking system when locking    active     8
MAS12382-ENG122206-Dynamic turn signal control-DWA_Schaerfungsquittung    active     8
MAS12382-ENG142195-Dynamic turn signal control-Dynamische_Blink_Delay    50 ms    8
MAS12382-ENG261058-Dynamic turn signal control-IPA_RPA_Blinkbest„tugung    active     8
MAS12382-ENG260850-Dynamic turn signal control-IPA_RPA_blinken_links    active     8
MAS12382-ENG258687-Dynamic turn signal control-IPA_RPA_blinken_rechts    active     8
MAS12382-ENG260708-Dynamic turn signal control-Multikollisions_blinken    not active     8
MAS12382-ENG122209-Dynamic turn signal control-Notwarn_blinken_NBA_Phase_2    active     8
MAS12382-ENG122211-Dynamic turn signal control-Richtungs_blinken_links    active     8
MAS12382-ENG122210-Dynamic turn signal control-Richtungs_blinken_rechts    active     8
MAS12382-ENG260812-Dynamic turn signal control-SWA_blinken_links    active     8
MAS12382-ENG260466-Dynamic turn signal control-SWA_blinken_rechts    active     8
MAS12382-ENG122214-Dynamic turn signal control-Warnblinken_Zuendung_AUS    active     8
MAS12382-ENG122213-Dynamic turn signal control-Warnblinken_Zuendung_EIN    active     8
MAS13139-MAS13135-Button 4-Function of button 4    not coded/not installed     1
MAS13139-MAS13136-Button 4-Indicator lamp button 4    installed     1
MAS14140-IDE15905-Flashing function-Travel Assist    not active     4
MAS14140-ENG154601-Flashing function-Fahrerassistenz_Blinkenfunktionen    Warnblinke_zulaessig     4
MAS14140-ENG259090-Flashing function-Hupen_durch_Fahrerassistenz    not active     4
MAS14140-ENG142029-Flashing function-Warnblinken_durch_Fahrerassistenz    not active     4
MAS20279-WFS transponder gateway coding    Transponder GW in Kessy OK box     4
SFT00061-MAS10520-Special Function-Special function 1    not installed     4
SFT00061-SFT00048-Special Function-Special Function 2    not enabled     4
SFT00061-ENG260472-Special Function-Blinkerueberwachug_Sonderfunktions_SG    not installed     4
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status    not active     9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC    00 00 00     9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC    0    9
ENG253358-ENG258212-Anpassungen_Exterior_Light-Delay_Max    100 ms    270
ENG253358-ENG259279-Anpassungen_Exterior_Light-Events_Szene_1    00 00 00 00 00 00 00 00     270
ENG253358-ENG260085-Anpassungen_Exterior_Light-Events_Szene_10    00 00 00 00 00 00 00 00     270
ENG253358-ENG260997-Anpassungen_Exterior_Light-Events_Szene_11    00 00 00 00 00 00 00 00     270
ENG253358-ENG258638-Anpassungen_Exterior_Light-Events_Szene_12    00 00 00 00 00 00 00 00     270
ENG253358-ENG259456-Anpassungen_Exterior_Light-Events_Szene_13    00 00 00 00 00 00 00 00     270
ENG253358-ENG260535-Anpassungen_Exterior_Light-Events_Szene_14    00 00 00 00 00 00 00 00     270
ENG253358-ENG259560-Anpassungen_Exterior_Light-Events_Szene_15    00 00 00 00 00 00 00 00     270
ENG253358-ENG259132-Anpassungen_Exterior_Light-Events_Szene_16    00 00 00 00 00 00 00 00     270
ENG253358-ENG260337-Anpassungen_Exterior_Light-Events_Szene_17    00 00 00 00 00 00 00 00     270
ENG253358-ENG259462-Anpassungen_Exterior_Light-Events_Szene_18    00 00 00 00 00 00 00 00     270
ENG253358-ENG258627-Anpassungen_Exterior_Light-Events_Szene_19    00 00 00 00 00 00 00 00     270
ENG253358-ENG260067-Anpassungen_Exterior_Light-Events_Szene_2    00 00 00 00 00 00 00 00     270
ENG253358-ENG259484-Anpassungen_Exterior_Light-Events_Szene_20    00 00 00 00 00 00 00 00     270
ENG253358-ENG260587-Anpassungen_Exterior_Light-Events_Szene_21    00 00 00 00 00 00 00 00     270
ENG253358-ENG260042-Anpassungen_Exterior_Light-Events_Szene_22    00 00 00 00 00 00 00 00     270
ENG253358-ENG259549-Anpassungen_Exterior_Light-Events_Szene_23    00 00 00 00 00 00 00 00     270
ENG253358-ENG260635-Anpassungen_Exterior_Light-Events_Szene_24    00 00 00 00 00 00 00 00     270
ENG253358-ENG258179-Anpassungen_Exterior_Light-Events_Szene_25    00 00 00 00 00 00 00 00     270
ENG253358-ENG259599-Anpassungen_Exterior_Light-Events_Szene_26    00 00 00 00 00 00 00 00     270
ENG253358-ENG260140-Anpassungen_Exterior_Light-Events_Szene_27    00 00 00 00 00 00 00 00     270
ENG253358-ENG258932-Anpassungen_Exterior_Light-Events_Szene_28    00 00 00 00 00 00 00 00     270
ENG253358-ENG258855-Anpassungen_Exterior_Light-Events_Szene_29    00 00 00 00 00 00 00 00     270
ENG253358-ENG259951-Anpassungen_Exterior_Light-Events_Szene_3    00 00 00 00 00 00 00 00     270
ENG253358-ENG259306-Anpassungen_Exterior_Light-Events_Szene_30    00 00 00 00 00 00 00 00     270
ENG253358-ENG260976-Anpassungen_Exterior_Light-Events_Szene_31    00 00 00 00 00 00 00 00     270
ENG253358-ENG260284-Anpassungen_Exterior_Light-Events_Szene_32    00 00 00 00 00 00 00 00     270
ENG253358-ENG260168-Anpassungen_Exterior_Light-Events_Szene_4    00 00 00 00 00 00 00 00     270
ENG253358-ENG259646-Anpassungen_Exterior_Light-Events_Szene_5    00 00 00 00 00 00 00 00     270
ENG253358-ENG260432-Anpassungen_Exterior_Light-Events_Szene_6    00 00 00 00 00 00 00 00     270
ENG253358-ENG259181-Anpassungen_Exterior_Light-Events_Szene_7    00 00 00 00 00 00 00 00     270
ENG253358-ENG258154-Anpassungen_Exterior_Light-Events_Szene_8    00 00 00 00 00 00 00 00     270
ENG253358-ENG260860-Anpassungen_Exterior_Light-Events_Szene_9    00 00 00 00 00 00 00 00     270
ENG253358-ENG259092-Anpassungen_Exterior_Light-MappingArray    0    270
ENG253358-ENG263521-Anpassungen_Exterior_Light-MappingArray_Umfeld    0    270
ENG253358-ENG258812-Anpassungen_Exterior_Light-p_Abstand_IDG_Inszenierung    6.0 m    270
ENG253358-ENG258950-Anpassungen_Exterior_Light-p_Kessy_ID    not active     270
ENG253358-ENG289605-Anpassungen_Exterior_Light-p_vip30_Dimmung_SalR    0    270
ENG253358-ENG289606-Anpassungen_Exterior_Light-p_vip30_Dimmung_TSG    0    270
ENG253358-ENG289607-Anpassungen_Exterior_Light-p_vip30_Dimmzeit    0 ms    270
ENG253358-ENG259215-Anpassungen_Exterior_Light-pa_ambExtLight_Installation    active     270
ENG253358-ENG258160-Anpassungen_Exterior_Light-pa_ext_Ambiente    not active     270
ENG253358-ENG260968-Anpassungen_Exterior_Light-Passive_Timeout    0.00 s    270
ENG253358-ENG258460-Anpassungen_Exterior_Light-PSO_active_participant_ambient_lighting_exterieur_enabled    not active     270
ENG253358-ENG261089-Anpassungen_Exterior_Light-Verzoegerung_Blinken    not active     270
ENG253146-ENG141986-Aussenlicht-SG-Architektur-Abblendlicht_Leuchtentyp    H7     8
ENG253146-ENG258089-Aussenlicht-SG-Architektur-Abschaltung Redundanzpfad Prfung    active     8
ENG253146-ENG141987-Aussenlicht-SG-Architektur-Bremslicht_ist_auch_Blinklicht    No     8
ENG253146-ENG259743-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_1    FF     8
ENG253146-ENG260787-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_2    FF     8
ENG253146-ENG259890-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_3    FF     8
ENG253146-ENG260564-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_1    FF     8
ENG253146-ENG258294-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_2    FF     8
ENG253146-ENG259373-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_3    FF     8
ENG253146-ENG115861-Aussenlicht-SG-Architektur-Lichthupe bei Zuendung aus moeglich    not active     8
ENG253146-ENG115832-Aussenlicht-SG-Architektur-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht    not active     8
ENG253146-ENG115831-Aussenlicht-SG-Architektur-Schlusslicht mit Bremslichtfunktion    not active     8
ENG253146-ENG115860-Aussenlicht-SG-Architektur-Zahl der aktiven Scheinwerfer auf 2 limitieren    in Betrieb lassen     8
ENG253356-ENG258933-Automatische_Funktionen-Automatik_Funktionen_Warnungen_aktiv    not activated     4
ENG253356-ENG258835-Automatische_Funktionen-Automatik_Funktionen_WarnungWenn_AusserhalbExitBereich_aktiv    not activated     4
ENG253356-ENG260748-Automatische_Funktionen-AutomatikFunktionen_WarnungWenn_VerlassenBeiHautNichtGeschlossen_aktiv    not activated     4
ENG253356-ENG281101-Automatische_Funktionen-AutomatikFunktionen_WarnungWennIDGeberImInnenraum_aktiv    not activated     4
ENG253356-ENG258145-Automatische_Funktionen-AutomatischeFunktionen_Beschleunigtes_Entry_aktiv    not activated     4
ENG253356-ENG260562-Automatische_Funktionen-Automatisches_Entriegeln_aktiv    not activated     4
ENG253356-ENG260693-Automatische_Funktionen-Automatisches_Verriegeln_aktiv    not activated     4
ENG253240-ENG263541-Automatisierte Abschaltungen-Abschalt_verz”gerungs_zeit    60 s    8
ENG253240-ENG263514-Automatisierte Abschaltungen-Abschalt_wunsch_entprellung    1.0 s    8
ENG253240-ENG259987-Automatisierte Abschaltungen-Abschaltung nur in P    Alle Fahrstufen     8
ENG253240-ENG277086-Automatisierte Abschaltungen-Dauer fr Ausfhrung des Abschaltwunsch an SPN    2.0 s    8
ENG253240-ENG277087-Automatisierte Abschaltungen-Dauer Hinweistext Komfortabschaltung    10.0 s    8
ENG253240-ENG259819-Automatisierte Abschaltungen-Signalisierungsdauer Automatische Abschaltung erfolgt    5.0 s    8
ENG253240-ENG258392-Automatisierte Abschaltungen-Stillstandsdrehzahlschwelle Verbrennungsmotor    400    8
ENG253240-ENG258639-Automatisierte Abschaltungen-Verfgbarkeit Komfortabschaltung    available.     8
ENG253240-ENG258110-Automatisierte Abschaltungen-Zndungsabschaltung ber Energiemanagement    available.     8
ENG253240-ENG126843-Automatisierte Abschaltungen-ZV verriegeln bei Klemme 15 Ein    active     8
ENG253018-Clamp_Control-    Driver door     1
ENG253018-ENG261243-Clamp_Control-Immobilizer_Active_Zas    activated     1
ENG253221-ENG259820-Clamp_Coordinator-Clamp_Coordinator_priority_AAA    100    40
ENG253221-ENG260325-Clamp_Coordinator-Clamp_Coordinator_priority_DIAG    200    40
ENG253221-ENG260088-Clamp_Coordinator-Clamp_Coordinator_priority_MWS    10    40
ENG253221-ENG259040-Clamp_Coordinator-Clamp_Coordinator_priority_ORU    1    40
ENG253221-ENG259149-Clamp_Coordinator-Clamp_Coordinator_priority_PHP    100    40
ENG253221-ENG261099-Clamp_Coordinator-Clamp_Coordinator_priority_RPA    100    40
ENG253221-ENG258680-Clamp_Coordinator-Clamp_Coordinator_priority_RWK    100    40
ENG253221-ENG260388-Clamp_Coordinator-Clamp_Coordinator_priority_SPN    10    40
ENG253221-ENG259706-Clamp_Coordinator-Clamp_Coordinator_priority_ZAS    10    40
ENG126647-ENG98399-debug_light_function-Activation    0    11
ENG126647-ENG101417-debug_light_function-Adresse    0    11
ENG126647-ENG126820-debug_light_function-Bitmask    0    11
ENG126647-ENG126821-debug_light_function-Divisor    0    11
ENG126647-ENG98827-debug_light_function-Offset    0    11
ENG126647-ENG126822-debug_light_function-Polaritaet    0    11
ENG253229-ENG258467-Define_Const-Dimm2Bin    0%    4
ENG253229-ENG259386-Define_Const-Dimmzeit_SAL_Umfeld    0.00 s    4
ENG253229-ENG253468-Define_Const-Gamma    0    4
ENG253142-ENG258099-Design_switching-Display_Nachtdesign-Umschaltung    Standlicht/Fahrlicht_u_RLS     5
ENG253142-ENG261004-Design_switching-RLS_Nachtdesign_Schwelle    20    5
ENG253142-ENG260371-Design_switching-RLS_Tagdesign_Schwelle    100    5
ENG253142-ENG258254-Design_switching-Werteanzahl_Mittelwert    100    5
ENG253142-ENG260585-Design_switching-Werteanzahl_Mittelwert_Start-    5    5
ENG253216-MAS18908-DevCod_Automatische_Verriegelung-Terminal 15: behavior of the automatic locking function    Function only allowed for terminal 15 off     6
ENG253216-ENG261088-DevCod_Automatische_Verriegelung-AutomatikFunktionen_HVLaden_EigenerBereich_aktiv    not activated     6
ENG253216-ENG258169-DevCod_Automatische_Verriegelung-AutomatikFunktionen_Sonderfall_ZyklischeSucheBeiKlemme15_aktiv    not_activated     6
ENG253216-ENG277085-DevCod_Automatische_Verriegelung-Automatische_FunktionBeiAnnaeherung_Entfernung_aktiv    activated     6
ENG253028-DevCod_Bedienstellen    not activated     1
ENG253195-IDE04159-DevCod_Dienste_Byte1-Deactivation of start/stop function    not active     6
ENG253195-ENG281096-DevCod_Dienste_Byte1-Entry_Deaktivierung_aktiv    not activated     6
ENG253195-ENG258846-DevCod_Dienste_Byte1-Entry_GoDeaktivierung_Aktivierungs_Variante    not activated     6
ENG253195-ENG258351-DevCod_Dienste_Byte1-ErkennungFahrzeug_Verlassen_aktiv    activated     6
ENG253195-ENG261030-DevCod_Dienste_Byte1-ErkennungFahrzeug_Zugang_aktiv    activated     6
ENG253195-ENG260255-DevCod_Dienste_Byte1-ErkennungFahrzeugZugang_bei_Remotestart    activated     6
ENG253195-ENG259070-DevCod_Dienste_Byte1-ErkennungFahrzeugZugangVerlassen_Triggerung_aktiv    activated     6
ENG253102-ENG258819-DevCod_Dienste_Byte2-BereichsueberwachungPilotiertesParken_Variante    not activated     6
ENG253102-ENG259756-DevCod_Dienste_Byte2-BewussteGesamtEntriegelung_aktiv    not activated     6
ENG253102-ENG261309-DevCod_Dienste_Byte2-Paketbotenmodus_aktiv    not activated     6
ENG253102-ENG277103-DevCod_Dienste_Byte2-RSAD_Krypto_Checks_aktivieren    activated     6
ENG253102-ENG259641-DevCod_Dienste_Byte2-RSADMassnahme_aussen_aktiv    not activated     6
ENG253102-ENG259949-DevCod_Dienste_Byte2-RSADMassnahme_innen_aktiv    not activated     6
ENG253102-ENG260061-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_aktiv    not activated     6
ENG253102-ENG259459-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_NichtKessyEntr_aktiv    not activated     6
ENG253102-ENG259282-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_OeffnenFT_aktiv    not activated     6
ENG253202-ENG259475-DevCod_Dienste_Byte3-VIT_close    not activated     6
ENG253202-ENG259049-DevCod_Dienste_Byte3-VIT_KESSY_Inversbit    not activated     6
ENG253296-ENG259208-DevCod_Fahrzeugkonfiguration_Byte1-BEM_verbaut    activated     6
ENG253296-ENG174999-DevCod_Fahrzeugkonfiguration_Byte1-Convertible    not activated     6
ENG253296-ENG259388-DevCod_Fahrzeugkonfiguration_Byte1-HBFS_Schiebetuer    not activated     6
ENG253296-ENG259603-DevCod_Fahrzeugkonfiguration_Byte1-HFS_Schiebetuer    activated     6
ENG253296-ENG260764-DevCod_Fahrzeugkonfiguration_Byte1-NFZ_mit_2Zonen    activated     6
ENG253296-ENG259616-DevCod_Fahrzeugkonfiguration_Byte1-Reaktivierung_all_Tueren_VK2    not activated     6
ENG253183-ENG259579-DevCod_Fahrzeugkonfiguration_Byte2-Softtouch_verbaut    installed     6
ENG253183-ENG277104-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_1_aktiv    not activated     6
ENG253183-ENG277105-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_2_aktiv    not activated     6
ENG253183-ENG277106-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_3_aktiv    not activated     6
ENG253183-ENG277107-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_4_aktiv    not activated     6
ENG253183-ENG277108-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_5_aktiv    not activated     6
ENG253183-ENG141964-DevCod_Fahrzeugkonfiguration_Byte2-Steering alignment    Right     6
ENG253369-ENG260810-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Fahrertuer    activated     6
ENG253369-ENG258777-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Verdeck_offen    not activated     6
ENG253369-ENG258088-DevCod_IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Heck_Schlieáverhinderung    activated     6
ENG253369-ENG258863-DevCod_IDGeber_Suche-InnenraumsucheMitEEAuth_Variante    not activated     6
ENG253369-ENG281080-DevCod_IDGeber_Suche-Unterdrueckung_zyklischer _Suchen_bei_entriegeltem_Fahrzeug_aktiv    not activated     6
ENG253170-ENG281102-DevCod_Nutzerkonfigurationen-HMIMenue_Aktivierung_Nah_Mittel_Fern_aktiv    not activated     6
ENG253170-ENG259272-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_Advanced_aktiv    not activated     6
ENG253170-ENG258478-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_aktiv    not activated     6
ENG253170-ENG281078-DevCod_Nutzerkonfigurationen-HMIMenue_Nutzer_Warnung_AutomatikFunktion_aktiv    not activated     6
ENG253247-IDE02474-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive entry exit function    Function only allowed for terminal 15 off     7
ENG253247-MAS18909-DevCod_Passive_EntryExit_Toggle-Terminal 15: behavior of the unlock/lock button function    not activated     7
ENG253247-MAS18910-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive exit function    Function only allowed for terminal 15 off     7
ENG253247-ENG260696-DevCod_Passive_EntryExit_Toggle-FunkkommunikationFuerPassiveEntryExit_Wiederholung_aktiv    activated     7
ENG253247-ENG261245-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offenen_Tueren    activated     7
ENG253247-ENG261070-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offener_Zugangstuer    not activated     7
ENG253247-ENG258791-DevCod_Passive_EntryExit_Toggle-Passive_Toggle_bei_offenen_Tueren    not activated     7
ENG253247-ENG260751-DevCod_Passive_EntryExit_Toggle-PassiveEntryExit_aktiv    not activated     7
ENG253117-ENG260289-DevCod_Passive_Go-Innenraumsuche_IDGeberFreigeben_bei_Remotestart    not activated     6
ENG253117-ENG259313-DevCod_Passive_Go-PassiveGo_bei_offener_Heckklappe    activated     6
ENG253117-ENG261220-DevCod_Passive_Go-PassiveGo_bei_offener_Schiebetr    activated     6
ENG253197-ENG260990-Diebstahlschutz Schnittstelle-DWA_HSB_HSK_ueberwachung_aktiv    not active     6
ENG253197-ENG258293-Diebstahlschutz Schnittstelle-DWA_mit_Einfachhorn    sounder_installed     6
ENG253197-ENG258890-Diebstahlschutz Schnittstelle-DWA_mit_NGS    active     6
ENG253197-ENG258731-Diebstahlschutz Schnittstelle-DWA_ohne_Thatcham    limited     6
ENG253197-ENG258944-Diebstahlschutz Schnittstelle-DWA_Scheinwerferueberwachung_aktiv    not active     6
ENG253197-ENG258663-Diebstahlschutz Schnittstelle-DWA_verbaut    installed     6
ENG253197-ENG258162-Diebstahlschutz Schnittstelle-IRUE_NGS_Deaktivierung_via_MMI    active     6
ENG253197-ENG261022-Diebstahlschutz Schnittstelle-Irue_verbaut    installed     6
ENG253197-ENG261072-Diebstahlschutz Schnittstelle-Sirene_alarmzahl    10_Alarme     6
ENG253197-ENG260442-Diebstahlschutz Schnittstelle-Verbau_Deaktivierungstaster_DWA_Sensor    not active     6
ENG253244-MAS10115-Diebstahlschutz.Modulsoftware-Anti-theft blinkers by inter. door handle activ.    OFF     6
ENG253244-Diebstahlschutz.Modulsoftware-    active     6
ENG253244-ENG258423-Diebstahlschutz.Modulsoftware-Akustischer Alarm ueber Hupe    not active     6
ENG253244-ENG258401-Diebstahlschutz.Modulsoftware-Anhaengerueberwachung_aktiv    not active     6
ENG253244-ENG146510-Diebstahlschutz.Modulsoftware-beeptime    10_ms     6
ENG253244-ENG260066-Diebstahlschutz.Modulsoftware-dwa_alarm_ton    frequency_modulated     6
ENG253244-ENG258606-Diebstahlschutz.Modulsoftware-DWA_campermode    not active     6
ENG253244-ENG260322-Diebstahlschutz.Modulsoftware-DWA_Verdeckoeffnungsueberwachung_aktiv    not active     6
ENG253244-ENG261182-Diebstahlschutz.Modulsoftware-IRUE_NGS_bewusst_entschaerfen    active     6
ENG253365-ENG260723-Dienste-BeeinflussungStartStopp_aktiv    not activated     4
ENG253365-ENG258656-Dienste-BereichsueberwachungPilotiertesParken_aktiv    not activated     4
ENG253365-ENG259029-Dienste-EntryGoDeaktivierung_Nutzerkonfiguration_aktiv    activated     4
ENG253365-ENG260489-Dienste-EntryGoDeaktivierung_Quittierung_aktiv    not activated     4
ENG253365-ENG258571-Dienste-GenerischeOrtung_aktiv    not activated     4
ENG253365-ENG260124-Dienste-Keyfinder_Aussen_aktiv    not activated     4
ENG253365-ENG259116-Dienste-Keyfinder_Innen_aktiv    not activated     4
ENG253144-ENG259520-Dimmung (der Suchbeleuchtung Kl. 58)-p_delta_KL58D_min    3.00%    21
ENG253144-ENG253461-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xd    160%    21
ENG253144-ENG253462-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xs    160%    21
ENG253144-ENG253463-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xt    160%    21
ENG253144-ENG259127-Dimmung (der Suchbeleuchtung Kl. 58)-p_Kl_58xk_Schrittanzahl_kurzer_Tastendruck    10    21
ENG253144-ENG261206-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_max    90.00%    21
ENG253144-ENG258780-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_min    10.00%    21
ENG253144-ENG259198-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_tol    5.00%    21
ENG253144-ENG261308-Dimmung (der Suchbeleuchtung Kl. 58)-p_langer_Tastendruck    1.0 s    21
ENG253144-ENG260197-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xs_Nachlauf_lang    900 s    21
ENG253144-ENG261144-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xt_Nachlauf_kurz    30 s    21
ENG253144-ENG258180-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Master    10 min    21
ENG253144-ENG253464-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Slave    12 min    21
ENG122925-DWA_Interior_Monitoring_Data_Set_Development    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     150
ENG253243-ENG286261-Easy Open-p_a_Schiebetrentriegelung_durch_VIP_bei_Tankklappe_offen    not active     4
ENG253243-ENG258420-Easy Open-p_a_VIP_Freigabeentzug_bei_Anhaenger    not active     4
ENG253243-ENG258644-Easy Open-Virtuelles_Pedal_Aktiv_Kl_15    not active     4
ENG253243-ENG259016-Easy Open-Virtuelles_Pedal_Aktiv_Kl_S    not active     4
ENG253243-ENG260097-Easy Open-Virtuelles_Pedal_Aktiv_Motorlauf    not active     4
ENG253243-ENG286386-Easy Open-Virtuelles_Pedal_Schiebetren_Aktiv_Kl_15    not active     4
ENG253243-ENG286387-Easy Open-Virtuelles_Pedal_Schiebetren_Aktiv_Kl_S    not active     4
ENG253243-ENG286388-Easy Open-Virtuelles_Pedal_Schiebetren_Aktiv_Motorlauf    not active     4
ENG129029-ENG258264-Easy_close_alignment-delta_rssi_hysterese    0    15
ENG129029-ENG260847-Easy_close_alignment-min_HD_Oeffungswinkel    0%    15
ENG129029-ENG259133-Easy_close_alignment-min_HD_Oeffungswinkel_Rev    0%    15
ENG129029-ENG259801-Easy_close_alignment-VIT_AktivTasteB    0.0 s    15
ENG129029-ENG259762-Easy_close_alignment-VIT_RSSI_Verlassensscans    0.0 s    15
ENG129029-ENG260687-Easy_close_alignment-VIT_RSSI_Wiedereintrittscans    0.0 s    15
ENG166045-ENG258452-EASYCLOSE-EasyCloseAktiv    not activated     4
ENG166045-ENG260520-EASYCLOSE-ECL_ext_verriegeln    not activated     4
ENG166045-ENG248655-EASYCLOSE-ECL_Start_ueber_ViP    not activated     4
ENG253250-ENG130581-Fahrlichthinweis-Fahrlicht_Hinweis_mehrfach    active     4
ENG253250-ENG126818-Fahrlichthinweis-Fahrlichtwarnung_Hinweis_Konfig    Hinweis_in_LDS-Stellung_Null_und_SL     4
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset    not active     6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent    not installed     6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung    not installed     6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA    not active     6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung    800 ms    6
ENG141682-ENG260711-Front_wiper-cp_tipwischen_Kl_15_aus    OFF     6
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm    active     6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf    active     6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition    keine Abtaupostition     6
ENG141682-ENG260480-Front_wiper-Frontwischer_typ    Direct     6
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung    active     6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer    active     6
ENG141682-ENG258360-Front_wiper-pa_2_Motorsystem    not active     6
ENG141682-ENG259770-Front_wiper-Regensensor aktiv Fahrfreigabe    not active     6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren    active     6
ENG141682-ENG260083-Front_wiper-Spannungsanforderung_konfig_Frontwischer    Sollspannungsanforderung 13.5     6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay    300 ms    6
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz    active     6
ENG141682-ENG259232-Front_wiper-tipwischen_Kl_15_aus    not active     6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status    not active     6
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant    not active     6
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube    not active     6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus    active     6
ENG141682-ENG122991-Front_wiper-Wischer stop bei Motorstart    immer Wischerstopp     6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube    active     6
ENG171911-ENG263558-Funk-FFB Batteriewarnung unterdruecken    not active     4
ENG171911-ENG141957-Funk-Radio freq.    MQB37w: 434 MHz RdW + NAR (2-kanalig)     4
ENG253288-Grundparameter SPN-    10000 ms    30
Jasons6930
Code: Select all
ENG253288-ENG126955-Grundparameter SPN-duration_to_ZAT_continuous_actuation_detection    1000 ms    30
ENG253288-ENG129005-Grundparameter SPN-duration_to_ZAT_multi_actuation_detection    3000 ms    30
ENG253288-ENG126950-Grundparameter SPN-duration_ZAT_debounce    50 ms    30
ENG253288-ENG260569-Grundparameter SPN-Speed_ threshold_for_start_wish_plausibilisation    10 km/h    30
ENG253288-ENG129008-Grundparameter SPN-Speed_threshold_for_terminal_15_emergency_shutoff    7.0 km/h    30
ENG253288-ENG126954-Grundparameter SPN-time_to_ZAT_Open_circuit_detection    1000 ms    30
ENG253288-ENG126951-Grundparameter SPN-time_to_ZAT_Short_circuit_fault_detection    60 s    30
ENG253288-ENG126952-Grundparameter SPN-time_ZAT_lock_after emergency_shutoff    1000 ms    30
ENG253288-ENG126953-Grundparameter SPN-time_ZAT_lock_after_normal_shutoff    500 ms    30
ENG253288-ENG253449-Grundparameter SPN-time_ZAT_one_switch_actuation_detection    3000 ms    30
ENG253178-ENG126630-Heckdeckelsteuerung-Reichweitenbegrenzung fuer Servoheck schliessen    not active     8
ENG253178-ENG125652-Heckdeckelsteuerung-Servoheck Schlossansteuerung    Always     8
ENG253178-ENG126838-Heckdeckelsteuerung-Softtouch-Betaetigung senden    Always     8
ENG253178-ENG142011-Heckdeckelsteuerung-trunk_lid_conrol_unit    not installed     8
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid    installed     8
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid    installed     8
ENG141645-MAS00213-HW_Verbau-Insufficient coolant    installed     8
ENG141645-MAS00214-HW_Verbau-Brake pad wear    not installed     8
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor    installed     8
ENG141645-ENG260128-HW_Verbau-Kontaktfritten    OFF     8
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube    installed     8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung    not installed     8
ENG141645-ENG152427-HW_Verbau-Rear window defogger    not installed     8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15    active     8
ENG253080-IAA Nutzermanagement    installed     1
ENG253173-ENG259645-IDGeber_Suche-Innenraumsuche_Kl15_aktiv    activated     4
ENG253173-ENG261236-IDGeber_Suche-Innenraumsuche_Kl15_Triggerung_aktiv    activated     4
ENG253173-ENG260685-IDGeber_Suche-Innenraumsuche_Kl15_TuerenKlappenFenster_auch_vor_erstem_Anfahren    activated     4
ENG253173-ENG258195-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Heck_aktiv    activated     4
ENG253173-ENG260525-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_aktiv    activated     4
ENG253173-ENG258977-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_NFZ_aktiv    activated     4
ENG253173-ENG258651-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_TriggerVariante    activated     4
ENG253173-ENG261351-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Tueren_aktiv    activated     4
ENG129016-Initialization_diagnostics_switching_terminal    not activated     4
ENG253070-MAS14172-Intelligente Heckleuchte-Parametierung-Brake light larger area    not active     23
ENG253070-MAS14173-Intelligente Heckleuchte-Parametierung-Brake light smaller area    not active     23
ENG253070-ENG259403-Intelligente Heckleuchte-Parametierung-p_Abstand_BRL_Aktivierung    0.00 m    23
ENG253070-ENG260952-Intelligente Heckleuchte-Parametierung-p_Abstand_BRL_Deaktivierung    0.00 m    23
ENG253070-ENG259366-Intelligente Heckleuchte-Parametierung-p_adaptive_helligkeitsanpassung    not active     23
ENG253070-ENG260454-Intelligente Heckleuchte-Parametierung-p_beschleunigung_BRL_dauer    10 ms    23
ENG253070-ENG260199-Intelligente Heckleuchte-Parametierung-p_beschleunigung_BRL_schwelle    -16.00000 m/sý    23
ENG253070-ENG260962-Intelligente Heckleuchte-Parametierung-p_CHO_LHO_statisch    not active     23
ENG253070-ENG259731-Intelligente Heckleuchte-Parametierung-p_LH_Diag_LED_def_inaktiv    not active     23
ENG253070-ENG259241-Intelligente Heckleuchte-Parametierung-p_LH_Diag_Status_def_inaktiv    not active     23
ENG253070-ENG260043-Intelligente Heckleuchte-Parametierung-p_LH_zusatzschlussl_def_deaktiv    not active     23
ENG253070-ENG260406-Intelligente Heckleuchte-Parametierung-p_LS_helligkeit_schwelle_dunkel    4000 lx    23
ENG253070-ENG260839-Intelligente Heckleuchte-Parametierung-p_LS_helligkeit_schwelle_hoch    50000 lx    23
ENG253070-ENG258451-Intelligente Heckleuchte-Parametierung-p_SHL_Anim_LTM_Auto    not active     23
ENG253070-ENG259407-Intelligente Heckleuchte-Parametierung-p_SHL_AnimDimm_Freigabe_KL15aus    0    23
ENG253070-ENG260457-Intelligente Heckleuchte-Parametierung-p_SHL_AnimDimm_Freigabe_KL15ein    0    23
ENG253070-ENG259766-Intelligente Heckleuchte-Parametierung-p_SHL_dynamisch    not active     23
ENG253070-ENG258437-Intelligente Heckleuchte-Parametierung-p_v_BRL_Aktivierung    20 km/h    23
ENG253070-ENG258439-Intelligente Heckleuchte-Parametierung-p_v_BRL_Deaktivierung    10 km/h    23
ENG253070-ENG261315-Intelligente Heckleuchte-Parametierung-p_v_SHL_dynamisch_level_aus    60 km/h    23
ENG253070-ENG259510-Intelligente Heckleuchte-Parametierung-p_v_SHL_dynamisch_level_ein    75 km/h    23
ENG253039-MAS06614-Intelligente Heckleuchte-Verbau-Variant    0    4
ENG253039-SFT271909-Intelligente Heckleuchte-Verbau-left tail lamp 1    not installed     4
ENG253039-SFT272142-Intelligente Heckleuchte-Verbau-left tail lamp 2    not installed     4
ENG253039-SFT272143-Intelligente Heckleuchte-Verbau-Right rear tail lamp 1    not installed     4
ENG253039-SFT272144-Intelligente Heckleuchte-Verbau-Right rear tail lamp 2    not installed     4
ENG253039-ENG173995-Intelligente Heckleuchte-Verbau-APS_installed    not installed     4
ENG253039-ENG260486-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_NSL_iSBBR    not active     4
ENG253039-ENG260357-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_RFL_iSBBR    not active     4
ENG253265-ENG260602-Interior_light_default_values-Default_value_active_profile    1    96
ENG253265-ENG258400-Interior_light_default_values-Default_value_ambient_color    1    96
ENG253265-ENG259067-Interior_light_default_values-Default_value_ambient_color_fod    1    96
ENG253265-ENG258906-Interior_light_default_values-Default_value_brightness_profile_1    100%    96
ENG253265-ENG260896-Interior_light_default_values-Default_value_brightness_profile_2    100%    96
ENG253265-ENG259361-Interior_light_default_values-Default_value_brightness_profile_3    100%    96
ENG253265-ENG259248-Interior_light_default_values-Default_value_brightness_profile_4    100%    96
ENG253265-ENG259191-Interior_light_default_values-Default_value_brightness_profile_5    100%    96
ENG253265-ENG259315-Interior_light_default_values-Default_value_brightness_profile_6    100%    96
ENG253265-ENG260148-Interior_light_default_values-Default_value_brightness_profile_7    100%    96
ENG253265-ENG259491-Interior_light_default_values-Default_value_brightness_profile_8    0%    96
ENG253265-ENG258409-Interior_light_default_values-Default_value_brightness_set_1    50%    96
ENG253265-ENG260620-Interior_light_default_values-Default_value_brightness_set_2    50%    96
ENG253265-ENG259395-Interior_light_default_values-Default_value_brightness_set_3    50%    96
ENG253265-ENG260548-Interior_light_default_values-Default_value_brightness_set_4    50%    96
ENG253265-ENG261071-Interior_light_default_values-Default_value_brightness_set_5    50%    96
ENG253265-ENG259147-Interior_light_default_values-Default_value_brightness_set_6    50%    96
ENG253265-ENG259714-Interior_light_default_values-Default_value_brightness_set_7    50%    96
ENG253265-ENG260350-Interior_light_default_values-Default_value_brightness_set_8    50%    96
ENG253265-ENG260494-Interior_light_default_values-Default_value_contour_color    1    96
ENG253265-ENG259828-Interior_light_default_values-Default_value_contour_color_fod    1    96
ENG253265-ENG258473-Interior_light_default_values-Default_value_door_contact    active     96
ENG253265-ENG261059-Interior_light_default_values-Default_value_functional_ambient_lighting    not active     96
ENG253265-ENG258185-Interior_light_default_values-Default_value_play_of_colors    0    96
ENG253265-ENG260118-Interior_light_default_values-Status_functional_ambient_lighting_function_0    0    96
ENG253265-ENG260033-Interior_light_default_values-Status_functional_ambient_lighting_function_1    0    96
ENG253265-ENG260515-Interior_light_default_values-Status_functional_ambient_lighting_function_10    0    96
ENG253265-ENG261126-Interior_light_default_values-Status_functional_ambient_lighting_function_11    0    96
ENG253265-ENG260982-Interior_light_default_values-Status_functional_ambient_lighting_function_12    0    96
ENG253265-ENG258716-Interior_light_default_values-Status_functional_ambient_lighting_function_13    0    96
ENG253265-ENG258745-Interior_light_default_values-Status_functional_ambient_lighting_function_14    0    96
ENG253265-ENG258773-Interior_light_default_values-Status_functional_ambient_lighting_function_15    0    96
ENG253265-ENG261349-Interior_light_default_values-Status_functional_ambient_lighting_function_16    0    96
ENG253265-ENG258101-Interior_light_default_values-Status_functional_ambient_lighting_function_17    0    96
ENG253265-ENG258275-Interior_light_default_values-Status_functional_ambient_lighting_function_18    0    96
ENG253265-ENG258192-Interior_light_default_values-Status_functional_ambient_lighting_function_19    0    96
ENG253265-ENG260897-Interior_light_default_values-Status_functional_ambient_lighting_function_2    0    96
ENG253265-ENG260194-Interior_light_default_values-Status_functional_ambient_lighting_function_20    0    96
ENG253265-ENG258332-Interior_light_default_values-Status_functional_ambient_lighting_function_21    0    96
ENG253265-ENG259651-Interior_light_default_values-Status_functional_ambient_lighting_function_22    0    96
ENG253265-ENG261294-Interior_light_default_values-Status_functional_ambient_lighting_function_23    0    96
ENG253265-ENG259414-Interior_light_default_values-Status_functional_ambient_lighting_function_24    0    96
ENG253265-ENG258573-Interior_light_default_values-Status_functional_ambient_lighting_function_25    0    96
ENG253265-ENG258495-Interior_light_default_values-Status_functional_ambient_lighting_function_26    0    96
ENG253265-ENG260792-Interior_light_default_values-Status_functional_ambient_lighting_function_27    0    96
ENG253265-ENG261350-Interior_light_default_values-Status_functional_ambient_lighting_function_28    0    96
ENG253265-ENG259636-Interior_light_default_values-Status_functional_ambient_lighting_function_29    0    96
ENG253265-ENG259360-Interior_light_default_values-Status_functional_ambient_lighting_function_3    0    96
ENG253265-ENG260163-Interior_light_default_values-Status_functional_ambient_lighting_function_30    0    96
ENG253265-ENG260013-Interior_light_default_values-Status_functional_ambient_lighting_function_31    0    96
ENG253265-ENG260816-Interior_light_default_values-Status_functional_ambient_lighting_function_32    0    96
ENG253265-ENG258823-Interior_light_default_values-Status_functional_ambient_lighting_function_33    0    96
ENG253265-ENG258362-Interior_light_default_values-Status_functional_ambient_lighting_function_34    0    96
ENG253265-ENG258252-Interior_light_default_values-Status_functional_ambient_lighting_function_35    0    96
ENG253265-ENG261196-Interior_light_default_values-Status_functional_ambient_lighting_function_36    0    96
ENG253265-ENG260391-Interior_light_default_values-Status_functional_ambient_lighting_function_37    0    96
ENG253265-ENG259418-Interior_light_default_values-Status_functional_ambient_lighting_function_38    0    96
ENG253265-ENG259523-Interior_light_default_values-Status_functional_ambient_lighting_function_39    0    96
ENG253265-ENG258165-Interior_light_default_values-Status_functional_ambient_lighting_function_4    0    96
ENG253265-ENG259088-Interior_light_default_values-Status_functional_ambient_lighting_function_40    0    96
ENG253265-ENG258142-Interior_light_default_values-Status_functional_ambient_lighting_function_41    0    96
ENG253265-ENG259166-Interior_light_default_values-Status_functional_ambient_lighting_function_42    0    96
ENG253265-ENG258220-Interior_light_default_values-Status_functional_ambient_lighting_function_43    0    96
ENG253265-ENG259935-Interior_light_default_values-Status_functional_ambient_lighting_function_44    0    96
ENG253265-ENG260916-Interior_light_default_values-Status_functional_ambient_lighting_function_45    0    96
ENG253265-ENG258884-Interior_light_default_values-Status_functional_ambient_lighting_function_46    0    96
ENG253265-ENG260167-Interior_light_default_values-Status_functional_ambient_lighting_function_47    0    96
ENG253265-ENG259709-Interior_light_default_values-Status_functional_ambient_lighting_function_48    0    96
ENG253265-ENG258367-Interior_light_default_values-Status_functional_ambient_lighting_function_49    0    96
ENG253265-ENG261268-Interior_light_default_values-Status_functional_ambient_lighting_function_5    0    96
ENG253265-ENG260926-Interior_light_default_values-Status_functional_ambient_lighting_function_50    0    96
ENG253265-ENG258790-Interior_light_default_values-Status_functional_ambient_lighting_function_51    0    96
ENG253265-ENG259976-Interior_light_default_values-Status_functional_ambient_lighting_function_52    0    96
ENG253265-ENG260404-Interior_light_default_values-Status_functional_ambient_lighting_function_53    0    96
ENG253265-ENG258371-Interior_light_default_values-Status_functional_ambient_lighting_function_54    0    96
ENG253265-ENG259284-Interior_light_default_values-Status_functional_ambient_lighting_function_55    0    96
ENG253265-ENG260285-Interior_light_default_values-Status_functional_ambient_lighting_function_56    0    96
ENG253265-ENG258600-Interior_light_default_values-Status_functional_ambient_lighting_function_57    0    96
ENG253265-ENG260626-Interior_light_default_values-Status_functional_ambient_lighting_function_58    0    96
ENG253265-ENG260773-Interior_light_default_values-Status_functional_ambient_lighting_function_59    0    96
ENG253265-ENG259316-Interior_light_default_values-Status_functional_ambient_lighting_function_6    0    96
ENG253265-ENG261109-Interior_light_default_values-Status_functional_ambient_lighting_function_60    0    96
ENG253265-ENG258106-Interior_light_default_values-Status_functional_ambient_lighting_function_61    0    96
ENG253265-ENG260286-Interior_light_default_values-Status_functional_ambient_lighting_function_62    0    96
ENG253265-ENG260233-Interior_light_default_values-Status_functional_ambient_lighting_function_63    0    96
ENG253265-ENG260974-Interior_light_default_values-Status_functional_ambient_lighting_function_7    0    96
ENG253265-ENG259492-Interior_light_default_values-Status_functional_ambient_lighting_function_8    0    96
ENG253265-ENG260578-Interior_light_default_values-Status_functional_ambient_lighting_function_9    0    96
ENG253069-ENG259642-Interior_light_external_events-External_event_activation_69    not active     16
ENG253069-ENG259453-Interior_light_external_events-External_event_activation_of_ready_to_drive_visualization    not active     16
ENG253069-ENG258384-Interior_light_external_events-External_event_ready_to_drive_visualization_with_sound    not active     16
ENG253344-ENG253469-Interior_light_functions_1_to_70-Light_function_1    not active     9
ENG253344-ENG260993-Interior_light_functions_1_to_70-Light_function_10    not active     9
ENG253344-ENG261210-Interior_light_functions_1_to_70-Light_function_11    not active     9
ENG253344-ENG259885-Interior_light_functions_1_to_70-Light_function_12    not active     9
ENG253344-ENG258428-Interior_light_functions_1_to_70-Light_function_13    not active     9
ENG253344-ENG260468-Interior_light_functions_1_to_70-Light_function_14    not active     9
ENG253344-ENG259544-Interior_light_functions_1_to_70-Light_function_15    not active     9
ENG253344-ENG261129-Interior_light_functions_1_to_70-Light_function_16    not active     9
ENG253344-ENG259775-Interior_light_functions_1_to_70-Light_function_17    not active     9
ENG253344-ENG259446-Interior_light_functions_1_to_70-Light_function_18    not active     9
ENG253344-ENG259229-Interior_light_functions_1_to_70-Light_function_19    not active     9
ENG253344-ENG253470-Interior_light_functions_1_to_70-Light_function_2    active     9
ENG253344-ENG259487-Interior_light_functions_1_to_70-Light_function_20    not active     9
ENG253344-ENG259385-Interior_light_functions_1_to_70-Light_function_21    not active     9
ENG253344-ENG259785-Interior_light_functions_1_to_70-Light_function_22    not active     9
ENG253344-ENG258581-Interior_light_functions_1_to_70-Light_function_23    not active     9
ENG253344-ENG260265-Interior_light_functions_1_to_70-Light_function_24    not active     9
ENG253344-ENG261256-Interior_light_functions_1_to_70-Light_function_25    not active     9
ENG253344-ENG260361-Interior_light_functions_1_to_70-Light_function_26    not active     9
ENG253344-ENG259100-Interior_light_functions_1_to_70-Light_function_27    not active     9
ENG253344-ENG260930-Interior_light_functions_1_to_70-Light_function_28    not active     9
ENG253344-ENG259955-Interior_light_functions_1_to_70-Light_function_29    not active     9
ENG253344-ENG253471-Interior_light_functions_1_to_70-Light_function_3    not active     9
ENG253344-ENG259370-Interior_light_functions_1_to_70-Light_function_30    active     9
ENG253344-ENG261130-Interior_light_functions_1_to_70-Light_function_31    not active     9
ENG253344-ENG258748-Interior_light_functions_1_to_70-Light_function_32    active     9
ENG253344-ENG260955-Interior_light_functions_1_to_70-Light_function_33    not active     9
ENG253344-ENG259496-Interior_light_functions_1_to_70-Light_function_34    not active     9
ENG253344-ENG258588-Interior_light_functions_1_to_70-Light_function_35    not active     9
ENG253344-ENG259600-Interior_light_functions_1_to_70-Light_function_36    not active     9
ENG253344-ENG259095-Interior_light_functions_1_to_70-Light_function_37    not active     9
ENG253344-ENG260346-Interior_light_functions_1_to_70-Light_function_38    not active     9
ENG253344-ENG259274-Interior_light_functions_1_to_70-Light_function_39    not active     9
ENG253344-ENG260499-Interior_light_functions_1_to_70-Light_function_4    not active     9
ENG253344-ENG258529-Interior_light_functions_1_to_70-Light_function_40    not active     9
ENG253344-ENG258505-Interior_light_functions_1_to_70-Light_function_41    not active     9
ENG253344-ENG258603-Interior_light_functions_1_to_70-Light_function_42    not active     9
ENG253344-ENG259158-Interior_light_functions_1_to_70-Light_function_43    not active     9
ENG253344-ENG260244-Interior_light_functions_1_to_70-Light_function_44    not active     9
ENG253344-ENG260634-Interior_light_functions_1_to_70-Light_function_45    not active     9
ENG253344-ENG258174-Interior_light_functions_1_to_70-Light_function_46    not active     9
ENG253344-ENG260984-Interior_light_functions_1_to_70-Light_function_47    not active     9
ENG253344-ENG258949-Interior_light_functions_1_to_70-Light_function_48    not active     9
ENG253344-ENG259994-Interior_light_functions_1_to_70-Light_function_49    not active     9
ENG253344-ENG258326-Interior_light_functions_1_to_70-Light_function_5    not active     9
ENG253344-ENG259724-Interior_light_functions_1_to_70-Light_function_50    not active     9
ENG253344-ENG259989-Interior_light_functions_1_to_70-Light_function_51    not active     9
ENG253344-ENG259580-Interior_light_functions_1_to_70-Light_function_52    not active     9
ENG253344-ENG258381-Interior_light_functions_1_to_70-Light_function_53    not active     9
ENG253344-ENG259438-Interior_light_functions_1_to_70-Light_function_54    not active     9
ENG253344-ENG261290-Interior_light_functions_1_to_70-Light_function_55    not active     9
ENG253344-ENG259516-Interior_light_functions_1_to_70-Light_function_56    not active     9
ENG253344-ENG261086-Interior_light_functions_1_to_70-Light_function_57    not active     9
ENG253344-ENG260704-Interior_light_functions_1_to_70-Light_function_58    not active     9
ENG253344-ENG258566-Interior_light_functions_1_to_70-Light_function_59    not active     9
ENG253344-ENG261278-Interior_light_functions_1_to_70-Light_function_6    not active     9
ENG253344-ENG260248-Interior_light_functions_1_to_70-Light_function_60    not active     9
ENG253344-ENG260845-Interior_light_functions_1_to_70-Light_function_61    not active     9
ENG253344-ENG258817-Interior_light_functions_1_to_70-Light_function_62    not active     9
ENG253344-ENG260488-Interior_light_functions_1_to_70-Light_function_63    not active     9
ENG253344-ENG259000-Interior_light_functions_1_to_70-Light_function_64    not active     9
ENG253344-ENG260181-Interior_light_functions_1_to_70-Light_function_65    not active     9
ENG253344-ENG259146-Interior_light_functions_1_to_70-Light_function_66    not active     9
ENG253344-ENG258530-Interior_light_functions_1_to_70-Light_function_67    not active     9
ENG253344-ENG261172-Interior_light_functions_1_to_70-Light_function_68    not active     9
ENG253344-ENG258454-Interior_light_functions_1_to_70-Light_function_69    not active     9
ENG253344-ENG259680-Interior_light_functions_1_to_70-Light_function_7    not active     9
ENG253344-ENG260506-Interior_light_functions_1_to_70-Light_function_70    not active     9
ENG253344-ENG258912-Interior_light_functions_1_to_70-Light_function_8    not active     9
ENG253344-ENG258633-Interior_light_functions_1_to_70-Light_function_9    not active     9
ENG253391-ENG258190-Interior_light_general_settings-Automatic_ambiance_lighting_with_fpa    not active     14
ENG253391-ENG259555-Interior_light_general_settings-Crash_color    1    14
ENG253391-ENG259741-Interior_light_general_settings-Door_warning_light    not active     14
ENG253391-ENG258939-Interior_light_general_settings-Door_warning_light_brightness    100%    14
ENG253391-ENG258181-Interior_light_general_settings-Door_warning_light_color    1    14
ENG253391-ENG259296-Interior_light_general_settings-Innenlicht_durch_Fahrerassistenz    active     14
ENG253391-ENG261240-Interior_light_general_settings-Interior_light_activation_by_opening_trunk    not active     14
ENG253391-ENG261275-Interior_light_general_settings-Interior_light_alternative_clamp_control_entry    not active     14
ENG253391-ENG260888-Interior_light_general_settings-Interior_light_alternative_clamp_control_exit    not active     14
ENG253391-ENG258268-Interior_light_general_settings-interior_light_color    1    14
ENG253391-ENG260936-Interior_light_general_settings-Interior_light_dependency_on_key_or_belt_buckle    2    14
ENG253391-ENG259666-Interior_light_general_settings-Interior_light_function    active     14
ENG253391-ENG260600-Interior_light_general_settings-Interior_light_trunk_light    active     14
ENG253391-ENG259259-Interior_light_general_settings-Kl30alm    active     14
ENG253391-ENG259746-Interior_light_general_settings-Kl30G_activation_by_opening_trunk    active     14
ENG253391-ENG260275-Interior_light_general_settings-Kl30G_wake_up_behaviour    not active     14
ENG253391-ENG259384-Interior_light_general_settings-Kl30G_without_pwm    not active     14
ENG253391-ENG258730-Interior_light_general_settings-Kl58_color    1    14
ENG253391-ENG260492-Interior_light_general_settings-Mapping_fpa_profile_1    1    14
ENG253391-ENG261042-Interior_light_general_settings-Mapping_fpa_profile_2    5    14
ENG253391-ENG258453-Interior_light_general_settings-Mapping_fpa_profile_3    3    14
ENG253391-ENG260820-Interior_light_general_settings-Mapping_fpa_profile_4    4    14
ENG253391-ENG258889-Interior_light_general_settings-Mapping_fpa_profile_5    2    14
ENG253391-ENG260732-Interior_light_general_settings-Mapping_fpa_profile_6    7    14
ENG253391-ENG260062-Interior_light_general_settings-Mfg_interior_light_color    1    14
ENG253391-ENG260638-Interior_light_general_settings-Pso_active_participant_ambient_lighting_interior_enabled    active     14
ENG253391-ENG258979-Interior_light_general_settings-roof_console_installed    active     14
ENG253391-ENG258685-Interior_light_general_settings-Trunk_light_brightness    100%    14
ENG253391-ENG260452-Interior_light_general_settings-Trunk_light_color    1    14
ENG253223-ENG260423-Interior_light_hmi_config-Bytes 25-60    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00     100
ENG253223-ENG259513-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_1    64    100
ENG253223-ENG260783-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_2    64    100
ENG253223-ENG260290-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_3    64    100
ENG253223-ENG258130-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_4    64    100
ENG253223-ENG259034-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_5    64    100
ENG253223-ENG259728-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_6    64    100
ENG253223-ENG258649-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_7    64    100
ENG253223-ENG258756-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_8    64    100
ENG253223-ENG260831-Interior_light_hmi_config-Hmi_ambient_color    not active     100
ENG253223-ENG258324-Interior_light_hmi_config-Hmi_ambient_colors_bitmask    00 00 00 00     100
ENG253223-ENG258789-Interior_light_hmi_config-Hmi_ambient_colors_fod_bitmask    00 00 00 00     100
ENG253223-ENG260180-Interior_light_hmi_config-Hmi_ambient_profile_1    not active     100
ENG253223-ENG258163-Interior_light_hmi_config-Hmi_ambient_profile_2    not active     100
ENG253223-ENG258800-Interior_light_hmi_config-Hmi_ambient_profile_3    not active     100
ENG253223-ENG258761-Interior_light_hmi_config-Hmi_ambient_profile_4    not active     100
ENG253223-ENG259948-Interior_light_hmi_config-Hmi_ambient_profile_5    not active     100
ENG253223-ENG261117-Interior_light_hmi_config-Hmi_ambient_profile_6    not active     100
ENG253223-ENG258601-Interior_light_hmi_config-Hmi_ambient_profile_7    not active     100
ENG253223-ENG259615-Interior_light_hmi_config-Hmi_ambient_profile_8    not active     100
ENG253223-ENG258875-Interior_light_hmi_config-Hmi_config_fixed_color_play_of_colors    0    100
ENG253223-ENG260154-Interior_light_hmi_config-Hmi_config_hmi_preview    not active     100
ENG253223-ENG258806-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_1    0F     100
ENG253223-ENG260370-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_2    0F     100
ENG253223-ENG261327-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_3    0F     100
ENG253223-ENG260102-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_4    0F     100
ENG253223-ENG259550-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_5    0F     100
ENG253223-ENG258870-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_6    0F     100
ENG253223-ENG260001-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_7    0F     100
ENG253223-ENG259068-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_8    0F     100
ENG253223-ENG259772-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_1    0    100
ENG253223-ENG259687-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_2    0    100
ENG253223-ENG259129-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_3    0    100
ENG253223-ENG260699-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_4    0    100
ENG253223-ENG259317-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_5    0    100
ENG253223-ENG258480-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_6    0    100
ENG253223-ENG261090-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_7    0    100
ENG253223-ENG258664-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_8    0    100
ENG253223-ENG261119-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_1    0    100
ENG253223-ENG259685-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_2    0    100
ENG253223-ENG260690-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_3    0    100
ENG253223-ENG259252-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_4    0    100
ENG253223-ENG258904-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_5    0    100
ENG253223-ENG260909-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_6    0    100
ENG253223-ENG258840-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_7    0    100
ENG253223-ENG260828-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_8    0    100
ENG253223-ENG259535-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_1    0    100
ENG253223-ENG259249-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_2    0    100
ENG253223-ENG258349-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_3    0    100
ENG253223-ENG260458-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_4    0    100
ENG253223-ENG258285-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_5    0    100
ENG253223-ENG258936-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_6    0    100
ENG253223-ENG260143-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_7    0    100
ENG253223-ENG259986-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_8    0    100
ENG253223-ENG260694-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_1    0    100
ENG253223-ENG259604-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_2    0    100
ENG253223-ENG258410-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_3    0    100
ENG253223-ENG261012-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_4    0    100
ENG253223-ENG259932-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_5    0    100
ENG253223-ENG260104-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_6    0    100
ENG253223-ENG260125-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_7    0    100
ENG253223-ENG259125-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_8    0    100
ENG253223-ENG260419-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_1    0    100
ENG253223-ENG261132-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_2    0    100
ENG253223-ENG260056-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_3    0    100
ENG253223-ENG259330-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_4    0    100
ENG253223-ENG258990-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_5    0    100
ENG253223-ENG259936-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_6    0    100
ENG253223-ENG258422-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_7    0    100
ENG253223-ENG258463-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_8    0    100
ENG253223-ENG258418-Interior_light_hmi_config-Hmi_config_timer_hmi_preview    5 s    100
ENG253223-ENG259957-Interior_light_hmi_config-Hmi_contour_color    not active     100
ENG253223-ENG259365-Interior_light_hmi_config-Hmi_contour_colors_bitmask    00 00 00 00     100
ENG253223-ENG259211-Interior_light_hmi_config-Hmi_contour_colors_fod_bitmask    00 00 00 00     100
ENG253223-ENG260051-Interior_light_hmi_config-Hmi_Display_Color_light_function    1    100
ENG253223-ENG258352-Interior_light_hmi_config-Hmi_door_contact    not active     100
ENG253223-ENG258250-Interior_light_hmi_config-Hmi_fpa_dependency    not active     100
ENG253223-ENG260229-Interior_light_hmi_config-Hmi_functional_ambiance_lighting_list    not active     100
ENG253223-ENG258930-Interior_light_hmi_config-Hmi_functional_ambience_lighting    not active     100
ENG253223-ENG258483-Interior_light_hmi_config-Hmi_menu_ambient_lighting    not active     100
ENG253223-ENG261116-Interior_light_hmi_config-Hmi_play_of_colors    not active     100
ENG253223-ENG260969-Interior_light_hmi_config-Hmi_setup_set_1    FF     100
ENG253223-ENG260367-Interior_light_hmi_config-Hmi_setup_set_2    FF     100
ENG253223-ENG259030-Interior_light_hmi_config-Hmi_setup_set_3    FF     100
ENG253223-ENG260913-Interior_light_hmi_config-Hmi_setup_set_4    FF     100
ENG253223-ENG258666-Interior_light_hmi_config-Hmi_setup_set_5    FF     100
ENG253223-ENG259988-Interior_light_hmi_config-Hmi_setup_set_6    FF     100
ENG253223-ENG258907-Interior_light_hmi_config-Hmi_setup_set_7    FF     100
ENG253223-ENG258492-Interior_light_hmi_config-Hmi_setup_set_8    FF     100
ENG253223-ENG259126-Interior_light_hmi_config-roof_console_door_contact    active     100
ENG253355-Interior_light_interface_function    No_voltage_requirement     1
ENG253312-ENG297177-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_1    0    51
ENG253312-ENG297178-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_10    0    51
ENG253312-ENG297179-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_11    0    51
ENG253312-ENG297180-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_12    0    51
ENG253312-ENG297181-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_13    0    51
ENG253312-ENG297182-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_14    0    51
ENG253312-ENG297183-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_15    0    51
ENG253312-ENG297184-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_2    0    51
ENG253312-ENG297185-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_3    0    51
ENG253312-ENG297186-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_4    0    51
ENG253312-ENG297187-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_5    0    51
ENG253312-ENG297188-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_6    0    51
ENG253312-ENG297189-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_7    0    51
ENG253312-ENG297190-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_8    0    51
ENG253312-ENG297191-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_9    0    51
ENG253312-ENG297192-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_1    0    51
ENG253312-ENG297193-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_10    0    51
ENG253312-ENG297194-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_11    0    51
ENG253312-ENG297195-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_12    0    51
ENG253312-ENG297196-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_13    0    51
ENG253312-ENG297197-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_14    0    51
ENG253312-ENG297198-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_15    0    51
ENG253312-ENG297199-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_2    0    51
ENG253312-ENG297200-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_3    0    51
ENG253312-ENG297201-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_4    0    51
ENG253312-ENG297202-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_5    0    51
ENG253312-ENG297203-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_6    0    51
ENG253312-ENG297204-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_7    0    51
ENG253312-ENG297205-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_8    0    51
ENG253312-ENG297206-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_9    0    51
ENG253312-ENG297207-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_1    0    51
ENG253312-ENG297208-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_10    0    51
ENG253312-ENG297209-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_11    0    51
ENG253312-ENG297210-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_12    0    51
ENG253312-ENG297211-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_13    0    51
ENG253312-ENG297212-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_14    0    51
ENG253312-ENG297213-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_15    0    51
ENG253312-ENG297214-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_2    0    51
ENG253312-ENG297215-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_3    0    51
ENG253312-ENG297216-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_4    0    51
ENG253312-ENG297217-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_5    0    51
ENG253312-ENG297218-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_6    0    51
ENG253312-ENG297219-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_7    0    51
ENG253312-ENG297220-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_8    0    51
ENG253312-ENG297221-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_9    0    51
ENG253312-ENG297222-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_1    Offset_0     51
ENG253312-ENG297223-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_10    Offset_0     51
ENG253312-ENG297224-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_11    Offset_0     51
ENG253312-ENG297225-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_12    Offset_0     51
ENG253312-ENG297226-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_13    Offset_0     51
ENG253312-ENG297227-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_14    Offset_0     51
ENG253312-ENG297228-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_15    Offset_0     51
ENG253312-ENG297229-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_2    Offset_0     51
ENG253312-ENG297230-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_3    Offset_0     51
ENG253312-ENG297231-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_4    Offset_0     51
ENG253312-ENG297232-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_5    Offset_0     51
ENG253312-ENG297233-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_6    Offset_0     51
ENG253312-ENG297234-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_7    Offset_0     51
ENG253312-ENG297235-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_8    Offset_0     51
ENG253312-ENG297236-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_9    Offset_0     51
ENG253312-ENG297237-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_1    Offset_0     51
ENG253312-ENG297238-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_10    Offset_0     51
ENG253312-ENG297239-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_11    Offset_0     51
ENG253312-ENG297240-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_12    Offset_0     51
ENG253312-ENG297241-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_13    Offset_0     51
ENG253312-ENG297242-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_14    Offset_0     51
ENG253312-ENG297243-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_15    Offset_0     51
ENG253312-ENG297244-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_2    Offset_0     51
ENG253312-ENG297245-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_3    Offset_0     51
ENG253312-ENG297246-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_4    Offset_0     51
ENG253312-ENG297247-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_5    Offset_0     51
ENG253312-ENG297248-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_6    Offset_0     51
ENG253312-ENG297249-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_7    Offset_0     51
ENG253312-ENG297250-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_8    Offset_0     51
ENG253312-ENG297251-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_9    Offset_0     51
ENG253312-ENG297252-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_1    Offset_0     51
ENG253312-ENG297253-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_10    Offset_0     51
ENG253312-ENG297254-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_11    Offset_0     51
ENG253312-ENG297255-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_12    Offset_0     51
ENG253312-ENG297256-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_13    Offset_0     51
ENG253312-ENG297257-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_14    Offset_0     51
ENG253312-ENG297258-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_15    Offset_0     51
ENG253312-ENG297259-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_2    Offset_0     51
ENG253312-ENG297260-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_3    Offset_0     51
ENG253312-ENG297261-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_4    Offset_0     51
ENG253312-ENG297262-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_5    Offset_0     51
ENG253312-ENG297263-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_6    Offset_0     51
ENG253312-ENG297264-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_7    Offset_0     51
ENG253312-ENG297265-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_8    Offset_0     51
ENG253312-ENG297266-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_9    Offset_0     51
ENG253400-ENG259423-Interior_light_router_config-Output_bcm_amb1_light_function    0    93
ENG253400-ENG258209-Interior_light_router_config-Output_bcm_amb2_light_function    0    93
ENG253400-ENG261174-Interior_light_router_config-Output_bcm_amb3_light_function    0    93
ENG253400-ENG259810-Interior_light_router_config-Output_bcm_amb4_light_function    0    93
ENG253400-ENG261141-Interior_light_router_config-Output_bcm_frl_light_function    0    93
ENG253400-ENG258669-Interior_light_router_config-Output_BCM_interiorlight    0    93
ENG253400-ENG260789-Interior_light_router_config-Output_bcm_krl_light_function    20    93
ENG253400-ENG263574-Interior_light_router_config-Output_interior_light_master_door_warning_lights_front_left    0    93
ENG253400-ENG263530-Interior_light_router_config-Output_interior_light_master_door_warning_lights_front_right    0    93
ENG253400-ENG263557-Interior_light_router_config-Output_interior_light_master_door_warning_lights_rear_left    0    93
ENG253400-ENG263579-Interior_light_router_config-Output_interior_light_master_door_warning_lights_rear_right    0    93
ENG253400-ENG259911-Interior_light_router_config-Output_lin10_light_function_slave_1    0    93
ENG253400-ENG261157-Interior_light_router_config-Output_lin10_light_function_slave_10    0    93
ENG253400-ENG259627-Interior_light_router_config-Output_lin10_light_function_slave_11    0    93
ENG253400-ENG260063-Interior_light_router_config-Output_lin10_light_function_slave_12    0    93
ENG253400-ENG260392-Interior_light_router_config-Output_lin10_light_function_slave_13    0    93
ENG253400-ENG261033-Interior_light_router_config-Output_lin10_light_function_slave_14    0    93
ENG253400-ENG260756-Interior_light_router_config-Output_lin10_light_function_slave_15    0    93
ENG253400-ENG259504-Interior_light_router_config-Output_lin10_light_function_slave_2    0    93
ENG253400-ENG259442-Interior_light_router_config-Output_lin10_light_function_slave_3    0    93
ENG253400-ENG260805-Interior_light_router_config-Output_lin10_light_function_slave_4    0    93
ENG253400-ENG258266-Interior_light_router_config-Output_lin10_light_function_slave_5    0    93
ENG253400-ENG259364-Interior_light_router_config-Output_lin10_light_function_slave_6    0    93
ENG253400-ENG258390-Interior_light_router_config-Output_lin10_light_function_slave_7    0    93
ENG253400-ENG259292-Interior_light_router_config-Output_lin10_light_function_slave_8    0    93
ENG253400-ENG258719-Interior_light_router_config-Output_lin10_light_function_slave_9    0    93
ENG253400-ENG259289-Interior_light_router_config-Output_lin5_light_function_slave_1    0    93
ENG253400-ENG260386-Interior_light_router_config-Output_lin5_light_function_slave_10    0    93
ENG253400-ENG259124-Interior_light_router_config-Output_lin5_light_function_slave_11    0    93
ENG253400-ENG259695-Interior_light_router_config-Output_lin5_light_function_slave_12    0    93
ENG253400-ENG260422-Interior_light_router_config-Output_lin5_light_function_slave_13    0    93
ENG253400-ENG261133-Interior_light_router_config-Output_lin5_light_function_slave_14    0    93
ENG253400-ENG258921-Interior_light_router_config-Output_lin5_light_function_slave_15    0    93
ENG253400-ENG260665-Interior_light_router_config-Output_lin5_light_function_slave_2    0    93
ENG253400-ENG260238-Interior_light_router_config-Output_lin5_light_function_slave_3    0    93
ENG253400-ENG260068-Interior_light_router_config-Output_lin5_light_function_slave_4    0    93
ENG253400-ENG260774-Interior_light_router_config-Output_lin5_light_function_slave_5    0    93
ENG253400-ENG258506-Interior_light_router_config-Output_lin5_light_function_slave_6    0    93
ENG253400-ENG259536-Interior_light_router_config-Output_lin5_light_function_slave_7    0    93
ENG253400-ENG260354-Interior_light_router_config-Output_lin5_light_function_slave_8    0    93
ENG253400-ENG261251-Interior_light_router_config-Output_lin5_light_function_slave_9    0    93
ENG253400-ENG259104-Interior_light_router_config-Output_lin9_light_function_slave_1    0    93
ENG253400-ENG260459-Interior_light_router_config-Output_lin9_light_function_slave_10    0    93
ENG253400-ENG259020-Interior_light_router_config-Output_lin9_light_function_slave_11    0    93
ENG253400-ENG260441-Interior_light_router_config-Output_lin9_light_function_slave_12    0    93
ENG253400-ENG260308-Interior_light_router_config-Output_lin9_light_function_slave_13    0    93
ENG253400-ENG258226-Interior_light_router_config-Output_lin9_light_function_slave_14    0    93
ENG253400-ENG259889-Interior_light_router_config-Output_lin9_light_function_slave_15    0    93
ENG253400-ENG259254-Interior_light_router_config-Output_lin9_light_function_slave_2    0    93
ENG253400-ENG258737-Interior_light_router_config-Output_lin9_light_function_slave_3    0    93
ENG253400-ENG260120-Interior_light_router_config-Output_lin9_light_function_slave_4    0    93
ENG253400-ENG258661-Interior_light_router_config-Output_lin9_light_function_slave_5    0    93
ENG253400-ENG260829-Interior_light_router_config-Output_lin9_light_function_slave_6    0    93
ENG253400-ENG260402-Interior_light_router_config-Output_lin9_light_function_slave_7    0    93
ENG253400-ENG261173-Interior_light_router_config-Output_lin9_light_function_slave_8    0    93
ENG253400-ENG260176-Interior_light_router_config-Output_lin9_light_function_slave_9    0    93
ENG253400-ENG258236-Interior_light_router_config-Output_roof_console_1    FF     93
ENG253400-ENG258284-Interior_light_router_config-Output_roof_console_2    FF     93
ENG253400-ENG260269-Interior_light_router_config-Output_roof_console_3    FF     93
ENG253400-ENG261203-Interior_light_router_config-Output_roof_console_4    FF     93
ENG253400-ENG258705-Interior_light_router_config-Output_roof_console_5    1E     93
ENG253400-ENG258805-Interior_light_router_config-Output_roof_console_6    1E     93
ENG253400-ENG260327-Interior_light_router_config-Output_tsg_bfs_1    0    93
ENG253400-ENG259694-Interior_light_router_config-Output_tsg_bfs_2    0    93
ENG253400-ENG261276-Interior_light_router_config-Output_tsg_bfs_3    0    93
ENG253400-ENG258178-Interior_light_router_config-Output_tsg_bfs_4    0    93
ENG253400-ENG260821-Interior_light_router_config-Output_tsg_bfsh_1    0    93
ENG253400-ENG260853-Interior_light_router_config-Output_tsg_bfsh_2    0    93
ENG253400-ENG258859-Interior_light_router_config-Output_tsg_bfsh_3    0    93
ENG253400-ENG261258-Interior_light_router_config-Output_tsg_bfsh_4    0    93
ENG253400-ENG260340-Interior_light_router_config-Output_tsg_fs_1    0    93
ENG253400-ENG258105-Interior_light_router_config-Output_tsg_fs_2    0    93
ENG253400-ENG260046-Interior_light_router_config-Output_tsg_fs_3    0    93
ENG253400-ENG258946-Interior_light_router_config-Output_tsg_fs_4    0    93
ENG253400-ENG259611-Interior_light_router_config-Output_tsg_fsh_1    0    93
ENG253400-ENG258415-Interior_light_router_config-Output_tsg_fsh_2    0    93
ENG253400-ENG260438-Interior_light_router_config-Output_tsg_fsh_3    0    93
ENG253400-ENG259398-Interior_light_router_config-Output_tsg_fsh_4    0    93
ENG253388-ENG247388-Kessyfunktion-beeptime_reunlock    5_ms     4
ENG253388-ENG174170-Kessyfunktion-central_locking_system_selective_sigle_door_kessy_NAR    active     4
ENG253388-ENG259401-Kessyfunktion-Gesamtoeffnung_ueber_Kessy    active     4
ENG253388-ENG258623-Kessyfunktion-Heck_wiederentriegelung_ohne_Auswurf    not active     4
ENG253388-ENG259486-Kessyfunktion-Komfortbedienung_fh_oeffnen_ueber_kessy    not active     4
ENG253388-ENG258699-Kessyfunktion-Komfortbedienung_fh_schliessen_ueber_kessy    active     4
ENG253388-ENG248300-Kessyfunktion-reunlock_beep    active     4
ENG253388-ENG259448-Kessyfunktion-Verriegeln_ueber_Toggle_nur_bei_Aussenhaut_geschlossen    not active     4
ENG253388-ENG259117-Kessyfunktion-Wiederentriegelung_komplett    not_active     4
ENG253388-ENG260947-Kessyfunktion-ZV_Kessy_Toggle_Taster_aktiv    not active     4
ENG172886-MAS10514-lcm-Expanded high beam control    High beam assistant     4
ENG172886-ENG142185-lcm-LCM_blinker    false     4
Jasons6930
Post by Jasons6930 »
Code: Select all
ENG172886-ENG142034-lcm-Light_Control_Module    direkt verbaut     4
ENG253068-ENG261092-Leuchte 0 BLK VL B24-Dimming Direction DEF 0    maximize     20
ENG253068-ENG259139-Leuchte 0 BLK VL B24-Dimming Direction GHI 0    maximize     20
ENG253068-ENG259025-Leuchte 0 BLK VL B24-Dimming Direction JKL 0    maximize     20
ENG253068-ENG259443-Leuchte 0 BLK VL B24-Dimmwert ABC 0    0    20
ENG253068-ENG260613-Leuchte 0 BLK VL B24-Dimmwert DEF 0    0    20
ENG253068-ENG259327-Leuchte 0 BLK VL B24-Dimmwert GHI 0    0    20
ENG253068-ENG261252-Leuchte 0 BLK VL B24-Dimmwert JKL 0    0    20
ENG253068-ENG115875-Leuchte 0 BLK VL B24-Fehlerort mittleres Byte DTC-DFCC 0    0    20
ENG253068-ENG116547-Leuchte 0 BLK VL B24-Lampendefektbit Position 0    0    20
ENG253068-ENG258269-Leuchte 0 BLK VL B24-Lasttyp_0    not_active     20
ENG253068-ENG260373-Leuchte 0 BLK VL B24-Lichtansteuerung HD ABC 0    Always     20
ENG253068-ENG115876-Leuchte 0 BLK VL B24-Lichtfunktion A 0    not active     20
ENG253068-ENG115877-Leuchte 0 BLK VL B24-Lichtfunktion B 0    not active     20
ENG253068-ENG115880-Leuchte 0 BLK VL B24-Lichtfunktion C 0    not active     20
ENG253068-ENG115881-Leuchte 0 BLK VL B24-Lichtfunktion D 0    not active     20
ENG253068-ENG115884-Leuchte 0 BLK VL B24-Lichtfunktion E 0    not active     20
ENG253068-ENG115885-Leuchte 0 BLK VL B24-Lichtfunktion F 0    not active     20
ENG253068-ENG115888-Leuchte 0 BLK VL B24-Lichtfunktion G 0    not active     20
ENG253068-ENG115889-Leuchte 0 BLK VL B24-Lichtfunktion H 0    not active     20
ENG253068-ENG258703-Leuchte 0 BLK VL B24-Lichtfunktion I 0    not active     20
ENG253068-ENG261318-Leuchte 0 BLK VL B24-Lichtfunktion J 0    not active     20
ENG253068-ENG258291-Leuchte 0 BLK VL B24-Lichtfunktion K 0    not active     20
ENG253068-ENG258466-Leuchte 0 BLK VL B24-Lichtfunktion L 0    not active     20
ENG263470-ENG261125-Leuchte 1 BLK VR B9-Dimming Direction DEF 1    maximize     20
ENG263470-ENG259203-Leuchte 1 BLK VR B9-Dimming Direction GHI 1    maximize     20
ENG263470-ENG259792-Leuchte 1 BLK VR B9-Dimming Direction JKL 1    maximize     20
ENG263470-ENG259773-Leuchte 1 BLK VR B9-Dimmwert ABC 1    0    20
ENG263470-ENG259452-Leuchte 1 BLK VR B9-Dimmwert DEF 1    0    20
ENG263470-ENG258945-Leuchte 1 BLK VR B9-Dimmwert GHI 1    0    20
ENG263470-ENG260514-Leuchte 1 BLK VR B9-Dimmwert JKL 1    0    20
ENG263470-ENG115894-Leuchte 1 BLK VR B9-Fehlerort mittleres Byte DTC-DFCC 1    0    20
ENG263470-ENG116548-Leuchte 1 BLK VR B9-Lampendefektbitposition 1    0    20
ENG263470-ENG115892-Leuchte 1 BLK VR B9-Lasttyp 1    not_active     20
ENG263470-ENG258732-Leuchte 1 BLK VR B9-Lichtansteuerung HD ABC 1    Always     20
ENG263470-ENG115895-Leuchte 1 BLK VR B9-Lichtfunktion A 1    not active     20
ENG263470-ENG115896-Leuchte 1 BLK VR B9-Lichtfunktion B 1    not active     20
ENG263470-ENG115899-Leuchte 1 BLK VR B9-Lichtfunktion C 1    not active     20
ENG263470-ENG115900-Leuchte 1 BLK VR B9-Lichtfunktion D 1    not active     20
ENG263470-ENG115903-Leuchte 1 BLK VR B9-Lichtfunktion E 1    not active     20
ENG263470-ENG115904-Leuchte 1 BLK VR B9-Lichtfunktion F 1    not active     20
ENG263470-ENG115907-Leuchte 1 BLK VR B9-Lichtfunktion G 1    not active     20
ENG263470-ENG116549-Leuchte 1 BLK VR B9-Lichtfunktion H 1    not active     20
ENG263470-ENG258834-Leuchte 1 BLK VR B9-Lichtfunktion I 1    not active     20
ENG263470-ENG259586-Leuchte 1 BLK VR B9-Lichtfunktion J 1    not active     20
ENG263470-ENG260282-Leuchte 1 BLK VR B9-Lichtfunktion K 1    not active     20
ENG263470-ENG260467-Leuchte 1 BLK VR B9-Lichtfunktion L 1    not active     20
ENG263477-ENG260590-Leuchte 10 SHUTTER L B23-Dimming Direction DEF 10    maximize     20
ENG263477-ENG260408-Leuchte 10 SHUTTER L B23-Dimming Direction GHI 10    maximize     20
ENG263477-ENG258321-Leuchte 10 SHUTTER L B23-Dimming Direction JKL 10    maximize     20
ENG263477-ENG260576-Leuchte 10 SHUTTER L B23-Dimmwert ABC 10    0    20
ENG263477-ENG258223-Leuchte 10 SHUTTER L B23-Dimmwert DEF 10    0    20
ENG263477-ENG260725-Leuchte 10 SHUTTER L B23-Dimmwert GHI 10    0    20
ENG263477-ENG258779-Leuchte 10 SHUTTER L B23-Dimmwert JKL 10    0    20
ENG263477-ENG116064-Leuchte 10 SHUTTER L B23-Fehlerort mittleres Byte DTC-DFCC 10    0    20
ENG263477-ENG116560-Leuchte 10 SHUTTER L B23-Lampendefektbitposition 10    0    20
ENG263477-ENG116062-Leuchte 10 SHUTTER L B23-Lasttyp 10    not_active     20
ENG263477-ENG260677-Leuchte 10 SHUTTER L B23-Lichtansteuerung HD ABC 10    Always     20
ENG263477-ENG116065-Leuchte 10 SHUTTER L B23-Lichtfunktion A 10    not active     20
ENG263477-ENG116066-Leuchte 10 SHUTTER L B23-Lichtfunktion B 10    not active     20
ENG263477-ENG116069-Leuchte 10 SHUTTER L B23-Lichtfunktion C 10    not active     20
ENG263477-ENG116070-Leuchte 10 SHUTTER L B23-Lichtfunktion D 10    not active     20
ENG263477-ENG116073-Leuchte 10 SHUTTER L B23-Lichtfunktion E 10    not active     20
ENG263477-ENG116074-Leuchte 10 SHUTTER L B23-Lichtfunktion F 10    not active     20
ENG263477-ENG116077-Leuchte 10 SHUTTER L B23-Lichtfunktion G 10    not active     20
ENG263477-ENG116078-Leuchte 10 SHUTTER L B23-Lichtfunktion H 10    not active     20
ENG263477-ENG261127-Leuchte 10 SHUTTER L B23-Lichtfunktion I 10    not active     20
ENG263477-ENG259264-Leuchte 10 SHUTTER L B23-Lichtfunktion J 10    not active     20
ENG263477-ENG258792-Leuchte 10 SHUTTER L B23-Lichtfunktion K 10    not active     20
ENG263477-ENG260117-Leuchte 10 SHUTTER L B23-Lichtfunktion L 10    not active     20
ENG263480-ENG260377-Leuchte 11 SHUTTER R B22-Dimming Direction DEF 11    maximize     20
ENG263480-ENG261238-Leuchte 11 SHUTTER R B22-Dimming Direction GHI 11    maximize     20
ENG263480-ENG258509-Leuchte 11 SHUTTER R B22-Dimming Direction JKL 11    maximize     20
ENG263480-ENG259362-Leuchte 11 SHUTTER R B22-Dimmwert ABC 11    0    20
ENG263480-ENG259167-Leuchte 11 SHUTTER R B22-Dimmwert DEF 11    0    20
ENG263480-ENG259831-Leuchte 11 SHUTTER R B22-Dimmwert GHI 11    0    20
ENG263480-ENG259729-Leuchte 11 SHUTTER R B22-Dimmwert JKL 11    0    20
ENG263480-ENG116083-Leuchte 11 SHUTTER R B22-Fehlerort mittleres Byte DTC-DFCC 11    0    20
ENG263480-ENG116561-Leuchte 11 SHUTTER R B22-Lampendefektbitposition 11    0    20
ENG263480-ENG116081-Leuchte 11 SHUTTER R B22-Lasttyp 11    not_active     20
ENG263480-ENG259732-Leuchte 11 SHUTTER R B22-Lichtansteuerung HD ABC 11    Always     20
ENG263480-ENG116084-Leuchte 11 SHUTTER R B22-Lichtfunktion A 11    not active     20
ENG263480-ENG116085-Leuchte 11 SHUTTER R B22-Lichtfunktion B 11    not active     20
ENG263480-ENG116088-Leuchte 11 SHUTTER R B22-Lichtfunktion C 11    not active     20
ENG263480-ENG116089-Leuchte 11 SHUTTER R B22-Lichtfunktion D 11    not active     20
ENG263480-ENG116092-Leuchte 11 SHUTTER R B22-Lichtfunktion E 11    not active     20
ENG263480-ENG116093-Leuchte 11 SHUTTER R B22-Lichtfunktion F 11    not active     20
ENG263480-ENG116096-Leuchte 11 SHUTTER R B22-Lichtfunktion G 11    not active     20
ENG263480-ENG116097-Leuchte 11 SHUTTER R B22-Lichtfunktion H 11    not active     20
ENG263480-ENG260510-Leuchte 11 SHUTTER R B22-Lichtfunktion I 11    not active     20
ENG263480-ENG258304-Leuchte 11 SHUTTER R B22-Lichtfunktion J 11    not active     20
ENG263480-ENG260059-Leuchte 11 SHUTTER R B22-Lichtfunktion K 11    not active     20
ENG263480-ENG260686-Leuchte 11 SHUTTER R B22-Lichtfunktion L 11    not active     20
ENG263462-ENG259122-Leuchte 12 NL L B45-Dimming Direction DEF 12    maximize     20
ENG263462-ENG260186-Leuchte 12 NL L B45-Dimming Direction GHI 12    maximize     20
ENG263462-ENG258138-Leuchte 12 NL L B45-Dimming Direction JKL 12    maximize     20
ENG263462-ENG261305-Leuchte 12 NL L B45-Dimmwert ABC 12    0    20
ENG263462-ENG258909-Leuchte 12 NL L B45-Dimmwert DEF 12    0    20
ENG263462-ENG261043-Leuchte 12 NL L B45-Dimmwert GHI 12    0    20
ENG263462-ENG261121-Leuchte 12 NL L B45-Dimmwert JKL 12    0    20
ENG263462-ENG116102-Leuchte 12 NL L B45-Fehlerort mittleres Byte DTC-DFCC 12    0    20
ENG263462-ENG116562-Leuchte 12 NL L B45-Lampendefektbitposition 12    0    20
ENG263462-ENG116100-Leuchte 12 NL L B45-Lasttyp 12    not_active     20
ENG263462-ENG258775-Leuchte 12 NL L B45-Lichtansteuerung HD ABC 12    Always     20
ENG263462-ENG116103-Leuchte 12 NL L B45-Lichtfunktion A 12    not active     20
ENG263462-ENG116104-Leuchte 12 NL L B45-Lichtfunktion B 12    not active     20
ENG263462-ENG116107-Leuchte 12 NL L B45-Lichtfunktion C 12    not active     20
ENG263462-ENG116108-Leuchte 12 NL L B45-Lichtfunktion D 12    not active     20
ENG263462-ENG116111-Leuchte 12 NL L B45-Lichtfunktion E 12    not active     20
ENG263462-ENG116112-Leuchte 12 NL L B45-Lichtfunktion F 12    not active     20
ENG263462-ENG116115-Leuchte 12 NL L B45-Lichtfunktion G 12    not active     20
ENG263462-ENG116116-Leuchte 12 NL L B45-Lichtfunktion H 12    not active     20
ENG263462-ENG261188-Leuchte 12 NL L B45-Lichtfunktion I 12    not active     20
ENG263462-ENG260482-Leuchte 12 NL L B45-Lichtfunktion J 12    not active     20
ENG263462-ENG258107-Leuchte 12 NL L B45-Lichtfunktion K 12    not active     20
ENG263462-ENG259735-Leuchte 12 NL L B45-Lichtfunktion L 12    not active     20
ENG263429-ENG258235-Leuchte 13 NL R B5-Dimming Direction DEF 13    maximize     20
ENG263429-ENG258860-Leuchte 13 NL R B5-Dimming Direction GHI 13    maximize     20
ENG263429-ENG261185-Leuchte 13 NL R B5-Dimming Direction JKL 13    maximize     20
ENG263429-ENG260614-Leuchte 13 NL R B5-Dimmwert ABC 13    0    20
ENG263429-ENG258948-Leuchte 13 NL R B5-Dimmwert DEF 13    0    20
ENG263429-ENG261076-Leuchte 13 NL R B5-Dimmwert GHI 13    0    20
ENG263429-ENG260048-Leuchte 13 NL R B5-Dimmwert JKL 13    0    20
ENG263429-ENG116121-Leuchte 13 NL R B5-Fehlerort mittleres Byte DTC-DFCC 13    0    20
ENG263429-ENG116563-Leuchte 13 NL R B5-Lampendefektbitposition 13    0    20
ENG263429-ENG116119-Leuchte 13 NL R B5-Lasttyp 13    not_active     20
ENG263429-ENG259297-Leuchte 13 NL R B5-Lichtansteuerung HD ABC 13    Always     20
ENG263429-ENG116122-Leuchte 13 NL R B5-Lichtfunktion A 13    not active     20
ENG263429-ENG116123-Leuchte 13 NL R B5-Lichtfunktion B 13    not active     20
ENG263429-ENG116564-Leuchte 13 NL R B5-Lichtfunktion C 13    not active     20
ENG263429-ENG116127-Leuchte 13 NL R B5-Lichtfunktion D 13    not active     20
ENG263429-ENG116130-Leuchte 13 NL R B5-Lichtfunktion E 13    not active     20
ENG263429-ENG116131-Leuchte 13 NL R B5-Lichtfunktion F 13    not active     20
ENG263429-ENG116134-Leuchte 13 NL R B5-Lichtfunktion G 13    not active     20
ENG263429-ENG116135-Leuchte 13 NL R B5-Lichtfunktion H 13    not active     20
ENG263429-ENG259477-Leuchte 13 NL R B5-Lichtfunktion I 13    not active     20
ENG263429-ENG259138-Leuchte 13 NL R B5-Lichtfunktion J 13    not active     20
ENG263429-ENG258127-Leuchte 13 NL R B5-Lichtfunktion K 13    not active     20
ENG263429-ENG259174-Leuchte 13 NL R B5-Lichtfunktion L 13    not active     20
ENG263460-ENG260021-Leuchte 16 BLK SL B42_C31-Dimming Direction DEF 16    maximize     20
ENG263460-ENG258735-Leuchte 16 BLK SL B42_C31-Dimming Direction GHI 16    maximize     20
ENG263460-ENG260912-Leuchte 16 BLK SL B42_C31-Dimming Direction JKL 16    maximize     20
ENG263460-ENG260010-Leuchte 16 BLK SL B42_C31-Dimmwert ABC 16    100    20
ENG263460-ENG258276-Leuchte 16 BLK SL B42_C31-Dimmwert DEF 16    0    20
ENG263460-ENG259552-Leuchte 16 BLK SL B42_C31-Dimmwert GHI 16    0    20
ENG263460-ENG260945-Leuchte 16 BLK SL B42_C31-Dimmwert JKL 16    0    20
ENG263460-ENG116178-Leuchte 16 BLK SL B42_C31-Fehlerort mittleres Byte DTC-DFCC 16    17    20
ENG263460-ENG116567-Leuchte 16 BLK SL B42_C31-Lampendefektbitposition 16    39    20
ENG263460-ENG116176-Leuchte 16 BLK SL B42_C31-Lasttyp 16    Blinkleuchten     20
ENG263460-ENG258626-Leuchte 16 BLK SL B42_C31-Lichtansteuerung HD ABC 16    Always     20
ENG263460-ENG116179-Leuchte 16 BLK SL B42_C31-Lichtfunktion A 16    Blinken links Hellphase     20
ENG263460-ENG116180-Leuchte 16 BLK SL B42_C31-Lichtfunktion B 16    not active     20
ENG263460-ENG116183-Leuchte 16 BLK SL B42_C31-Lichtfunktion C 16    not active     20
ENG263460-ENG116184-Leuchte 16 BLK SL B42_C31-Lichtfunktion D 16    not active     20
ENG263460-ENG116187-Leuchte 16 BLK SL B42_C31-Lichtfunktion E 16    not active     20
ENG263460-ENG116188-Leuchte 16 BLK SL B42_C31-Lichtfunktion F 16    not active     20
ENG263460-ENG116191-Leuchte 16 BLK SL B42_C31-Lichtfunktion G 16    not active     20
ENG263460-ENG116192-Leuchte 16 BLK SL B42_C31-Lichtfunktion H 16    not active     20
ENG263460-ENG261052-Leuchte 16 BLK SL B42_C31-Lichtfunktion I 16    not active     20
ENG263460-ENG258938-Leuchte 16 BLK SL B42_C31-Lichtfunktion J 16    not active     20
ENG263460-ENG258710-Leuchte 16 BLK SL B42_C31-Lichtfunktion K 16    not active     20
ENG263460-ENG259847-Leuchte 16 BLK SL B42_C31-Lichtfunktion L 16    not active     20
ENG253179-ENG258693-Leuchte 17 BLK_SR B4_A61-Dimming Direction DEF 17    maximize     20
ENG253179-ENG259225-Leuchte 17 BLK_SR B4_A61-Dimming Direction GHI 17    maximize     20
ENG253179-ENG260036-Leuchte 17 BLK_SR B4_A61-Dimming Direction JKL 17    maximize     20
ENG253179-ENG259305-Leuchte 17 BLK_SR B4_A61-Dimmwert ABC 17    100    20
ENG253179-ENG260736-Leuchte 17 BLK_SR B4_A61-Dimmwert DEF 17    0    20
ENG253179-ENG261209-Leuchte 17 BLK_SR B4_A61-Dimmwert GHI 17    0    20
ENG253179-ENG260649-Leuchte 17 BLK_SR B4_A61-Dimmwert JKL 17    0    20
ENG253179-ENG116197-Leuchte 17 BLK_SR B4_A61-Fehlerort mittleres Byte DTC-DFCC 17    19    20
ENG253179-ENG116568-Leuchte 17 BLK_SR B4_A61-Lampendefektbitposition 17    43    20
ENG253179-ENG116195-Leuchte 17 BLK_SR B4_A61-Lasttyp 17    Blinkleuchten     20
ENG253179-ENG259860-Leuchte 17 BLK_SR B4_A61-Lichtansteuerung HD ABC 17    Always     20
ENG253179-ENG116198-Leuchte 17 BLK_SR B4_A61-Lichtfunktion A 17    Blinken rechts Hellphase     20
ENG253179-ENG116569-Leuchte 17 BLK_SR B4_A61-Lichtfunktion B 17    not active     20
ENG253179-ENG116202-Leuchte 17 BLK_SR B4_A61-Lichtfunktion C 17    not active     20
ENG253179-ENG116203-Leuchte 17 BLK_SR B4_A61-Lichtfunktion D 17    not active     20
ENG253179-ENG116206-Leuchte 17 BLK_SR B4_A61-Lichtfunktion E 17    not active     20
ENG253179-ENG116207-Leuchte 17 BLK_SR B4_A61-Lichtfunktion F 17    not active     20
ENG253179-ENG116210-Leuchte 17 BLK_SR B4_A61-Lichtfunktion G 17    not active     20
ENG253179-ENG116211-Leuchte 17 BLK_SR B4_A61-Lichtfunktion H 17    not active     20
ENG253179-ENG258378-Leuchte 17 BLK_SR B4_A61-Lichtfunktion I 17    not active     20
ENG253179-ENG259950-Leuchte 17 BLK_SR B4_A61-Lichtfunktion J 17    not active     20
ENG253179-ENG259363-Leuchte 17 BLK_SR B4_A61-Lichtfunktion K 17    not active     20
ENG253179-ENG259816-Leuchte 17 BLK_SR B4_A61-Lichtfunktion L 17    not active     20
ENG263478-ENG260141-Leuchte 18 BLK HL A60-Dimming Direction DEF 18    maximize     20
ENG263478-ENG258397-Leuchte 18 BLK HL A60-Dimming Direction GHI 18    maximize     20
ENG263478-ENG259980-Leuchte 18 BLK HL A60-Dimming Direction JKL 18    maximize     20
ENG263478-ENG261250-Leuchte 18 BLK HL A60-Dimmwert ABC 18    100    20
ENG263478-ENG258343-Leuchte 18 BLK HL A60-Dimmwert DEF 18    0    20
ENG263478-ENG258799-Leuchte 18 BLK HL A60-Dimmwert GHI 18    0    20
ENG263478-ENG259813-Leuchte 18 BLK HL A60-Dimmwert JKL 18    0    20
ENG263478-ENG116216-Leuchte 18 BLK HL A60-Fehlerort mittleres Byte DTC-DFCC 18    16    20
ENG263478-ENG116570-Leuchte 18 BLK HL A60-Lampendefektbitposition 18    8    20
ENG263478-ENG116214-Leuchte 18 BLK HL A60-Lasttyp 18    LED_Blinkleuchten     20
ENG263478-ENG258246-Leuchte 18 BLK HL A60-Lichtansteuerung HD ABC 18    Always     20
ENG263478-ENG116217-Leuchte 18 BLK HL A60-Lichtfunktion A 18    Blinken links Hellphase     20
ENG263478-ENG116218-Leuchte 18 BLK HL A60-Lichtfunktion B 18    not active     20
ENG263478-ENG116221-Leuchte 18 BLK HL A60-Lichtfunktion C 18    not active     20
ENG263478-ENG116222-Leuchte 18 BLK HL A60-Lichtfunktion D 18    not active     20
ENG263478-ENG116225-Leuchte 18 BLK HL A60-Lichtfunktion E 18    not active     20
ENG263478-ENG116226-Leuchte 18 BLK HL A60-Lichtfunktion F 18    not active     20
ENG263478-ENG116229-Leuchte 18 BLK HL A60-Lichtfunktion G 18    not active     20
ENG263478-ENG116230-Leuchte 18 BLK HL A60-Lichtfunktion H 18    not active     20
ENG263478-ENG259904-Leuchte 18 BLK HL A60-Lichtfunktion I 18    not active     20
ENG263478-ENG260450-Leuchte 18 BLK HL A60-Lichtfunktion J 18    not active     20
ENG263478-ENG258383-Leuchte 18 BLK HL A60-Lichtfunktion K 18    not active     20
ENG263478-ENG261100-Leuchte 18 BLK HL A60-Lichtfunktion L 18    not active     20
ENG263431-ENG258368-Leuchte 19 BLK HR C27-Dimming Direction DEF 19    maximize     20
ENG263431-ENG260517-Leuchte 19 BLK HR C27-Dimming Direction GHI 19    maximize     20
ENG263431-ENG260100-Leuchte 19 BLK HR C27-Dimming Direction JKL 19    maximize     20
ENG263431-ENG259136-Leuchte 19 BLK HR C27-Dimmwert ABC 19    100    20
ENG263431-ENG260521-Leuchte 19 BLK HR C27-Dimmwert DEF 19    0    20
ENG263431-ENG260131-Leuchte 19 BLK HR C27-Dimmwert GHI 19    0    20
ENG263431-ENG259140-Leuchte 19 BLK HR C27-Dimmwert JKL 19    0    20
ENG263431-ENG116235-Leuchte 19 BLK HR C27-Fehlerort mittleres Byte DTC-DFCC 19    18    20
ENG263431-ENG116571-Leuchte 19 BLK HR C27-Lampendefektbitposition 19    18    20
ENG263431-ENG116233-Leuchte 19 BLK HR C27-Lasttyp 19    LED_Blinkleuchten     20
ENG263431-ENG258684-Leuchte 19 BLK HR C27-Lichtansteuerung HD ABC 19    Always     20
ENG263431-ENG116236-Leuchte 19 BLK HR C27-Lichtfunktion A 19    Blinken rechts Hellphase     20
ENG263431-ENG116237-Leuchte 19 BLK HR C27-Lichtfunktion B 19    not active     20
ENG263431-ENG116240-Leuchte 19 BLK HR C27-Lichtfunktion C 19    not active     20
ENG263431-ENG116241-Leuchte 19 BLK HR C27-Lichtfunktion D 19    not active     20
ENG263431-ENG116244-Leuchte 19 BLK HR C27-Lichtfunktion E 19    not active     20
ENG263431-ENG116245-Leuchte 19 BLK HR C27-Lichtfunktion F 19    not active     20
ENG263431-ENG116248-Leuchte 19 BLK HR C27-Lichtfunktion G 19    not active     20
ENG263431-ENG116249-Leuchte 19 BLK HR C27-Lichtfunktion H 19    not active     20
ENG263431-ENG258386-Leuchte 19 BLK HR C27-Lichtfunktion I 19    not active     20
ENG263431-ENG261194-Leuchte 19 BLK HR C27-Lichtfunktion J 19    not active     20
ENG263431-ENG260240-Leuchte 19 BLK HR C27-Lichtfunktion K 19    not active     20
ENG263431-ENG258090-Leuchte 19 BLK HR C27-Lichtfunktion L 19    not active     20
ENG263453-ENG259538-Leuchte 2 SL VL B20-Dimming Direction DEF 2    maximize     20
ENG263453-ENG259039-Leuchte 2 SL VL B20-Dimming Direction GHI 2    maximize     20
ENG263453-ENG261192-Leuchte 2 SL VL B20-Dimming Direction JKL 2    maximize     20
ENG263453-ENG260561-Leuchte 2 SL VL B20-Dimmwert ABC 2    100    20
ENG263453-ENG259420-Leuchte 2 SL VL B20-Dimmwert DEF 2    0    20
ENG263453-ENG258177-Leuchte 2 SL VL B20-Dimmwert GHI 2    0    20
ENG263453-ENG260473-Leuchte 2 SL VL B20-Dimmwert JKL 2    0    20
ENG263453-ENG115912-Leuchte 2 SL VL B20-Fehlerort mittleres Byte DTC-DFCC 2    29    20
ENG263453-ENG116550-Leuchte 2 SL VL B20-Lampendefektbitposition 2    0A     20
ENG263453-ENG115910-Leuchte 2 SL VL B20-Lasttyp 2    allgemeine_LED_mit_Open_Load_Diagnose_12W     20
ENG263453-ENG259674-Leuchte 2 SL VL B20-Lichtansteuerung HD ABC 2    Always     20
ENG263453-ENG115913-Leuchte 2 SL VL B20-Lichtfunktion A 2    Position lamps     20
ENG263453-ENG115914-Leuchte 2 SL VL B20-Lichtfunktion B 2    Parking light left     20
ENG263453-ENG115917-Leuchte 2 SL VL B20-Lichtfunktion C 2    not active     20
ENG263453-ENG115918-Leuchte 2 SL VL B20-Lichtfunktion D 2    not active     20
ENG263453-ENG115921-Leuchte 2 SL VL B20-Lichtfunktion E 2    not active     20
ENG263453-ENG115922-Leuchte 2 SL VL B20-Lichtfunktion F 2    not active     20
ENG263453-ENG115925-Leuchte 2 SL VL B20-Lichtfunktion G 2    not active     20
ENG263453-ENG115926-Leuchte 2 SL VL B20-Lichtfunktion H 2    not active     20
ENG263453-ENG261008-Leuchte 2 SL VL B20-Lichtfunktion I 2    not active     20
ENG263453-ENG259089-Leuchte 2 SL VL B20-Lichtfunktion J 2    not active     20
ENG263453-ENG259764-Leuchte 2 SL VL B20-Lichtfunktion K 2    not active     20
ENG263453-ENG261215-Leuchte 2 SL VL B20-Lichtfunktion L 2    not active     20
ENG263476-ENG258998-Leuchte 20 BR L A71-Dimming Direction DEF 20    minimze     20
ENG263476-ENG260228-Leuchte 20 BR L A71-Dimming Direction GHI 20    minimze     20
ENG263476-ENG258824-Leuchte 20 BR L A71-Dimming Direction JKL 20    maximize     20
ENG263476-ENG261006-Leuchte 20 BR L A71-Dimmwert ABC 20    100    20
ENG263476-ENG260784-Leuchte 20 BR L A71-Dimmwert DEF 20    0    20
ENG263476-ENG260188-Leuchte 20 BR L A71-Dimmwert GHI 20    0    20
ENG263476-ENG258358-Leuchte 20 BR L A71-Dimmwert JKL 20    0    20
ENG263476-ENG116254-Leuchte 20 BR L A71-Fehlerort mittleres Byte DTC-DFCC 20    2B     20
ENG263476-ENG116572-Leuchte 20 BR L A71-Lampendefektbitposition 20    9    20
ENG263476-ENG116252-Leuchte 20 BR L A71-Lasttyp 20    LED_Bremsleuchten     20
ENG263476-ENG259045-Leuchte 20 BR L A71-Lichtansteuerung HD ABC 20    Always     20
ENG263476-ENG116255-Leuchte 20 BR L A71-Lichtfunktion A 20    Brake lamp     20
ENG263476-ENG116256-Leuchte 20 BR L A71-Lichtfunktion B 20    not active     20
ENG263476-ENG116259-Leuchte 20 BR L A71-Lichtfunktion C 20    not active     20
ENG263476-ENG116260-Leuchte 20 BR L A71-Lichtfunktion D 20    not active     20
ENG263476-ENG116263-Leuchte 20 BR L A71-Lichtfunktion E 20    not active     20
ENG263476-ENG116264-Leuchte 20 BR L A71-Lichtfunktion F 20    not active     20
ENG263476-ENG116267-Leuchte 20 BR L A71-Lichtfunktion G 20    not active     20
ENG263476-ENG116268-Leuchte 20 BR L A71-Lichtfunktion H 20    not active     20
ENG263476-ENG259111-Leuchte 20 BR L A71-Lichtfunktion I 20    not active     20
ENG263476-ENG259768-Leuchte 20 BR L A71-Lichtfunktion J 20    not active     20
ENG263476-ENG260741-Leuchte 20 BR L A71-Lichtfunktion K 20    not active     20
ENG263476-ENG258272-Leuchte 20 BR L A71-Lichtfunktion L 20    not active     20
ENG263446-ENG259371-Leuchte 21 BR R C8-Dimming Direction DEF 21    minimze     20
ENG263446-ENG261222-Leuchte 21 BR R C8-Dimming Direction GHI 21    minimze     20
ENG263446-ENG260449-Leuchte 21 BR R C8-Dimming Direction JKL 21    maximize     20
ENG263446-ENG260142-Leuchte 21 BR R C8-Dimmwert ABC 21    100    20
ENG263446-ENG259169-Leuchte 21 BR R C8-Dimmwert DEF 21    0    20
ENG263446-ENG258330-Leuchte 21 BR R C8-Dimmwert GHI 21    0    20
ENG263446-ENG260224-Leuchte 21 BR R C8-Dimmwert JKL 21    0    20
ENG263446-ENG116273-Leuchte 21 BR R C8-Fehlerort mittleres Byte DTC-DFCC 21    2D     20
ENG263446-ENG116573-Leuchte 21 BR R C8-Lampendefektbitposition 21    19    20
ENG263446-ENG116271-Leuchte 21 BR R C8-Lasttyp 21    LED_Bremsleuchten     20
ENG263446-ENG259749-Leuchte 21 BR R C8-Lichtansteuerung HD ABC 21    Always     20
ENG263446-ENG116274-Leuchte 21 BR R C8-Lichtfunktion A 21    Brake lamp     20
ENG263446-ENG116275-Leuchte 21 BR R C8-Lichtfunktion B 21    not active     20
ENG263446-ENG116278-Leuchte 21 BR R C8-Lichtfunktion C 21    not active     20
ENG263446-ENG116279-Leuchte 21 BR R C8-Lichtfunktion D 21    not active     20
ENG263446-ENG116282-Leuchte 21 BR R C8-Lichtfunktion E 21    not active     20
ENG263446-ENG116283-Leuchte 21 BR R C8-Lichtfunktion F 21    not active     20
ENG263446-ENG116286-Leuchte 21 BR R C8-Lichtfunktion G 21    not active     20
ENG263446-ENG116287-Leuchte 21 BR R C8-Lichtfunktion H 21    not active     20
ENG263446-ENG260531-Leuchte 21 BR R C8-Lichtfunktion I 21    not active     20
ENG263446-ENG258267-Leuchte 21 BR R C8-Lichtfunktion J 21    not active     20
ENG263446-ENG261265-Leuchte 21 BR R C8-Lichtfunktion K 21    not active     20
ENG263446-ENG261356-Leuchte 21 BR R C8-Lichtfunktion L 21    not active     20
ENG263487-ENG261009-Leuchte 22 BR M A57-Dimming Direction DEF 22    maximize     20
ENG263487-ENG259558-Leuchte 22 BR M A57-Dimming Direction GHI 22    maximize     20
ENG263487-ENG258098-Leuchte 22 BR M A57-Dimming Direction JKL 22    maximize     20
ENG263487-ENG260824-Leuchte 22 BR M A57-Dimmwert ABC 22    127    20
ENG263487-ENG261330-Leuchte 22 BR M A57-Dimmwert DEF 22    0    20
ENG263487-ENG260249-Leuchte 22 BR M A57-Dimmwert GHI 22    0    20
ENG263487-ENG260794-Leuchte 22 BR M A57-Dimmwert JKL 22    0    20
ENG263487-ENG116292-Leuchte 22 BR M A57-Fehlerort mittleres Byte DTC-DFCC 22    2C     20
ENG263487-ENG116574-Leuchte 22 BR M A57-Lampendefektbitposition 22    29    20
ENG263487-ENG116290-Leuchte 22 BR M A57-Lasttyp 22    LED_dritte_Bremsleuchte     20
ENG263487-ENG259134-Leuchte 22 BR M A57-Lichtansteuerung HD ABC 22    Always     20
ENG263487-ENG116293-Leuchte 22 BR M A57-Lichtfunktion A 22    Brake lamp     20
ENG263487-ENG116294-Leuchte 22 BR M A57-Lichtfunktion B 22    not active     20
ENG263487-ENG116297-Leuchte 22 BR M A57-Lichtfunktion C 22    not active     20
ENG263487-ENG116298-Leuchte 22 BR M A57-Lichtfunktion D 22    not active     20
ENG263487-ENG116301-Leuchte 22 BR M A57-Lichtfunktion E 22    not active     20
ENG263487-ENG116302-Leuchte 22 BR M A57-Lichtfunktion F 22    not active     20
ENG263487-ENG116305-Leuchte 22 BR M A57-Lichtfunktion G 22    not active     20
ENG263487-ENG116306-Leuchte 22 BR M A57-Lichtfunktion H 22    not active     20
ENG263487-ENG261266-Leuchte 22 BR M A57-Lichtfunktion I 22    not active     20
ENG263487-ENG259294-Leuchte 22 BR M A57-Lichtfunktion J 22    not active     20
ENG263487-ENG258164-Leuchte 22 BR M A57-Lichtfunktion K 22    not active     20
ENG263487-ENG259578-Leuchte 22 BR M A57-Lichtfunktion L 22    not active     20
ENG263433-ENG259710-Leuchte 23 SL HL C10-Dimming Direction DEF 32    minimze     20
ENG263433-ENG258905-Leuchte 23 SL HL C10-Dimming Direction GHI 32    maximize     20
ENG263433-ENG260532-Leuchte 23 SL HL C10-Dimming Direction JKL 32    maximize     20
ENG263433-ENG259737-Leuchte 23 SL HL C10-Dimmwert ABC 32    127    20
ENG263433-ENG259346-Leuchte 23 SL HL C10-Dimmwert DEF 32    0    20
ENG263433-ENG260258-Leuchte 23 SL HL C10-Dimmwert GHI 32    0    20
ENG263433-ENG260382-Leuchte 23 SL HL C10-Dimmwert JKL 32    0    20
ENG263433-ENG116482-Leuchte 23 SL HL C10-Fehlerort mittleres Byte DTC-DFCC 32    0    20
ENG263433-ENG116584-Leuchte 23 SL HL C10-Lampendefektbitposition 32    0    20
ENG263433-ENG116480-Leuchte 23 SL HL C10-Lasttyp 32    LED_Kleinleistung_ohne_Open_Load_Diagnose     20
ENG263433-ENG259035-Leuchte 23 SL HL C10-Lichtansteuerung HD ABC 32    Always     20
ENG263433-ENG116483-Leuchte 23 SL HL C10-Lichtfunktion A 32    Blinken links aktiv     20
ENG263433-ENG116484-Leuchte 23 SL HL C10-Lichtfunktion B 32    Blinken rechts aktiv     20
ENG263433-ENG116487-Leuchte 23 SL HL C10-Lichtfunktion C 32    Nebelschlusslicht wenn kein Anhaenger gesteckt     20
ENG263433-ENG116488-Leuchte 23 SL HL C10-Lichtfunktion D 32    not active     20
ENG263433-ENG116491-Leuchte 23 SL HL C10-Lichtfunktion E 32    not active     20
ENG263433-ENG116492-Leuchte 23 SL HL C10-Lichtfunktion F 32    not active     20
ENG263433-ENG116495-Leuchte 23 SL HL C10-Lichtfunktion G 32    not active     20
ENG263433-ENG116496-Leuchte 23 SL HL C10-Lichtfunktion H 32    not active     20
ENG263433-ENG258763-Leuchte 23 SL HL C10-Lichtfunktion I 32    not active     20
ENG263433-ENG259842-Leuchte 23 SL HL C10-Lichtfunktion J 32    not active     20
ENG263433-ENG258857-Leuchte 23 SL HL C10-Lichtfunktion K 32    not active     20
ENG263433-ENG260175-Leuchte 23 SL HL C10-Lichtfunktion L 32    not active     20
ENG263475-ENG260709-Leuchte 24 SL HR A65-Dimming Direction DEF 24    minimze     20
ENG263475-ENG258518-Leuchte 24 SL HR A65-Dimming Direction GHI 24    maximize     20
ENG263475-ENG258189-Leuchte 24 SL HR A65-Dimming Direction JKL 24    maximize     20
ENG263475-ENG259150-Leuchte 24 SL HR A65-Dimmwert ABC 24    127    20
ENG263475-ENG259120-Leuchte 24 SL HR A65-Dimmwert DEF 24    0    20
ENG263475-ENG259774-Leuchte 24 SL HR A65-Dimmwert GHI 24    0    20
ENG263475-ENG259393-Leuchte 24 SL HR A65-Dimmwert JKL 24    0    20
ENG263475-ENG116330-Leuchte 24 SL HR A65-Fehlerort mittleres Byte DTC-DFCC 24    0    20
ENG263475-ENG116576-Leuchte 24 SL HR A65-Lampendefektbitposition 24    0    20
ENG263475-ENG116328-Leuchte 24 SL HR A65-Lasttyp 24    LED_Kleinleistung_ohne_Open_Load_Diagnose     20
ENG263475-ENG258842-Leuchte 24 SL HR A65-Lichtansteuerung HD ABC 24    Always     20
ENG263475-ENG116331-Leuchte 24 SL HR A65-Lichtfunktion A 24    Blinken links aktiv     20
ENG263475-ENG116332-Leuchte 24 SL HR A65-Lichtfunktion B 24    Blinken rechts aktiv     20
ENG263475-ENG116335-Leuchte 24 SL HR A65-Lichtfunktion C 24    Nebelschlusslicht wenn kein Anhaenger gesteckt     20
ENG263475-ENG116336-Leuchte 24 SL HR A65-Lichtfunktion D 24    not active     20
ENG263475-ENG116339-Leuchte 24 SL HR A65-Lichtfunktion E 24    not active     20
ENG263475-ENG116340-Leuchte 24 SL HR A65-Lichtfunktion F 24    not active     20
ENG263475-ENG116343-Leuchte 24 SL HR A65-Lichtfunktion G 24    not active     20
ENG263475-ENG116344-Leuchte 24 SL HR A65-Lichtfunktion H 24    not active     20
ENG263475-ENG260865-Leuchte 24 SL HR A65-Lichtfunktion I 24    not active     20
ENG263475-ENG260414-Leuchte 24 SL HR A65-Lichtfunktion J 24    not active     20
ENG263475-ENG260577-Leuchte 24 SL HR A65-Lichtfunktion K 24    not active     20
ENG263475-ENG260598-Leuchte 24 SL HR A65-Lichtfunktion L 24    not active     20
ENG263447-ENG260768-Leuchte 25 KZL H A59-Dimming Direction DEF 25    maximize     20
ENG263447-ENG259422-Leuchte 25 KZL H A59-Dimming Direction GHI 25    maximize     20
ENG263447-ENG258848-Leuchte 25 KZL H A59-Dimming Direction JKL 25    maximize     20
ENG263447-ENG258210-Leuchte 25 KZL H A59-Dimmwert ABC 25    100    20
ENG263447-ENG260749-Leuchte 25 KZL H A59-Dimmwert DEF 25    0    20
ENG263447-ENG258574-Leuchte 25 KZL H A59-Dimmwert GHI 25    0    20
ENG263447-ENG259896-Leuchte 25 KZL H A59-Dimmwert JKL 25    0    20
ENG263447-ENG116349-Leuchte 25 KZL H A59-Fehlerort mittleres Byte DTC-DFCC 25    30    20
ENG263447-ENG116577-Leuchte 25 KZL H A59-Lampendefektbitposition 25    28    20
ENG263447-ENG116347-Leuchte 25 KZL H A59-Lasttyp 25    allgemeine_Gluehlampe_6W_auch_H6W     20
ENG263447-ENG259553-Leuchte 25 KZL H A59-Lichtansteuerung HD ABC 25    Always     20
ENG263447-ENG116350-Leuchte 25 KZL H A59-Lichtfunktion A 25    Position lamps     20
ENG263447-ENG116351-Leuchte 25 KZL H A59-Lichtfunktion B 25    not active     20
ENG263447-ENG116354-Leuchte 25 KZL H A59-Lichtfunktion C 25    not active     20
ENG263447-ENG116355-Leuchte 25 KZL H A59-Lichtfunktion D 25    not active     20
ENG263447-ENG116358-Leuchte 25 KZL H A59-Lichtfunktion E 25    not active     20
ENG263447-ENG259247-Leuchte 25 KZL H A59-Lichtfunktion F25    not active     20
ENG263447-ENG116362-Leuchte 25 KZL H A59-Lichtfunktion G 25    not active     20
ENG263447-ENG116363-Leuchte 25 KZL H A59-Lichtfunktion H 25    not active     20
ENG263447-ENG260931-Leuchte 25 KZL H A59-Lichtfunktion I 25    not active     20
ENG263447-ENG258654-Leuchte 25 KZL H A59-Lichtfunktion J 25    not active     20
ENG263447-ENG260798-Leuchte 25 KZL H A59-Lichtfunktion K 25    not active     20
ENG263447-ENG258935-Leuchte 25 KZL H A59-Lichtfunktion L 25    not active     20
ENG263489-ENG259412-Leuchte 26 NSL L A72-Dimming Direction DEF 26    maximize     20
ENG263489-ENG259883-Leuchte 26 NSL L A72-Dimming Direction GHI 26    maximize     20
ENG263489-ENG260584-Leuchte 26 NSL L A72-Dimming Direction JKL 26    maximize     20
ENG263489-ENG261357-Leuchte 26 NSL L A72-Dimmwert ABC 26    100    20
ENG263489-ENG260958-Leuchte 26 NSL L A72-Dimmwert DEF 26    0    20
ENG263489-ENG258546-Leuchte 26 NSL L A72-Dimmwert GHI 26    0    20
ENG263489-ENG259662-Leuchte 26 NSL L A72-Dimmwert JKL 26    0    20
ENG263489-ENG116368-Leuchte 26 NSL L A72-Fehlerort mittleres Byte DTC-DFCC 26    2E     20
ENG263489-ENG116578-Leuchte 26 NSL L A72-Lampendefektbitposition 26    0C     20
ENG263489-ENG116366-Leuchte 26 NSL L A72-Lasttyp 26    allgemeine_LED_mit_Open_Load_Diagnose_12W     20
ENG263489-ENG260640-Leuchte 26 NSL L A72-Lichtansteuerung HD ABC 26    Always     20
ENG263489-ENG116369-Leuchte 26 NSL L A72-Lichtfunktion A 26    Nebelschlusslicht wenn kein Anhaenger gesteckt     20
ENG263489-ENG116370-Leuchte 26 NSL L A72-Lichtfunktion B 26    not active     20
ENG263489-ENG116373-Leuchte 26 NSL L A72-Lichtfunktion C 26    not active     20
ENG263489-ENG116374-Leuchte 26 NSL L A72-Lichtfunktion D 26    not active     20
ENG263489-ENG116377-Leuchte 26 NSL L A72-Lichtfunktion E 26    not active     20
ENG263489-ENG116378-Leuchte 26 NSL L A72-Lichtfunktion F 26    not active     20
ENG263489-ENG116381-Leuchte 26 NSL L A72-Lichtfunktion G 26    not active     20
ENG263489-ENG116382-Leuchte 26 NSL L A72-Lichtfunktion H 26    not active     20
ENG263489-ENG258650-Leuchte 26 NSL L A72-Lichtfunktion I 26    not active     20
ENG263489-ENG258937-Leuchte 26 NSL L A72-Lichtfunktion J 26    not active     20
ENG263489-ENG259765-Leuchte 26 NSL L A72-Lichtfunktion K 26    not active     20
ENG263489-ENG260970-Leuchte 26 NSL L A72-Lichtfunktion L 26    not active     20
ENG263468-ENG259400-Leuchte 27 NSL R C6-Dimming Direction DEF 27    maximize     20
ENG263468-ENG260627-Leuchte 27 NSL R C6-Dimming Direction GHI 27    maximize     20
ENG263468-ENG260547-Leuchte 27 NSL R C6-Dimming Direction JKL 27    maximize     20
ENG263468-ENG259742-Leuchte 27 NSL R C6-Dimmwert ABC 27    100    20
ENG263468-ENG258926-Leuchte 27 NSL R C6-Dimmwert DEF 27    0    20
ENG263468-ENG259009-Leuchte 27 NSL R C6-Dimmwert GHI 27    0    20
ENG263468-ENG260084-Leuchte 27 NSL R C6-Dimmwert JKL 27    0    20
ENG263468-ENG116387-Leuchte 27 NSL R C6-Fehlerort mittleres Byte DTC-DFCC 27    2F     20
ENG263468-ENG116579-Leuchte 27 NSL R C6-Lampendefektbitposition 27    1C     20
ENG263468-ENG116385-Leuchte 27 NSL R C6-Lasttyp 27    allgemeine_LED_mit_Open_Load_Diagnose_12W     20
ENG263468-ENG258715-Leuchte 27 NSL R C6-Lichtansteuerung HD ABC 27    Always     20
ENG263468-ENG116388-Leuchte 27 NSL R C6-Lichtfunktion A 27    Nebelschlusslicht wenn kein Anhaenger gesteckt     20
ENG263468-ENG116389-Leuchte 27 NSL R C6-Lichtfunktion B 27    not active     20
ENG263468-ENG116392-Leuchte 27 NSL R C6-Lichtfunktion C 27    not active     20
ENG263468-ENG116393-Leuchte 27 NSL R C6-Lichtfunktion D 27    not active     20
ENG263468-ENG116396-Leuchte 27 NSL R C6-Lichtfunktion E 27    not active     20
ENG263468-ENG116397-Leuchte 27 NSL R C6-Lichtfunktion F 27    not active     20
ENG263468-ENG116400-Leuchte 27 NSL R C6-Lichtfunktion G 27    not active     20
ENG263468-ENG116401-Leuchte 27 NSL R C6-Lichtfunktion H 27    not active     20
ENG263468-ENG258753-Leuchte 27 NSL R C6-Lichtfunktion I 27    not active     20
ENG263468-ENG258206-Leuchte 27 NSL R C6-Lichtfunktion J 27    not active     20
ENG263468-ENG260268-Leuchte 27 NSL R C6-Lichtfunktion K 27    not active     20
ENG263468-ENG259071-Leuchte 27 NSL R C6-Lichtfunktion L 27    not active     20
ENG263472-ENG258565-Leuchte 28 RFL L C11-Dimming Direction DEF 28    maximize     20
ENG263472-ENG258532-Leuchte 28 RFL L C11-Dimming Direction GHI 28    maximize     20
ENG263472-ENG259396-Leuchte 28 RFL L C11-Dimming Direction JKL 28    maximize     20
ENG263472-ENG259919-Leuchte 28 RFL L C11-Dimmwert ABC 28    100    20
ENG263472-ENG258647-Leuchte 28 RFL L C11-Dimmwert DEF 28    0    20
ENG263472-ENG261179-Leuchte 28 RFL L C11-Dimmwert GHI 28    0    20
ENG263472-ENG260446-Leuchte 28 RFL L C11-Dimmwert JKL 28    0    20
ENG263472-ENG116406-Leuchte 28 RFL L C11-Fehlerort mittleres Byte DTC-DFCC 28    31    20
ENG263472-ENG116580-Leuchte 28 RFL L C11-Lampendefektbitposition 28    0B     20
ENG263472-ENG116404-Leuchte 28 RFL L C11-Lasttyp 28    allgemeine_LED_mit_Open_Load_Diagnose_12W     20
ENG263472-ENG258804-Leuchte 28 RFL L C11-Lichtansteuerung HD ABC 28    Always     20
ENG263472-ENG116407-Leuchte 28 RFL L C11-Lichtfunktion A 28    Rueckfahrlicht     20
ENG263472-ENG116408-Leuchte 28 RFL L C11-Lichtfunktion B 28    not active     20
ENG263472-ENG116411-Leuchte 28 RFL L C11-Lichtfunktion C 28    not active     20
ENG263472-ENG116412-Leuchte 28 RFL L C11-Lichtfunktion D 28    not active     20
ENG263472-ENG116415-Leuchte 28 RFL L C11-Lichtfunktion E 28    not active     20
ENG263472-ENG116416-Leuchte 28 RFL L C11-Lichtfunktion F 28    not active     20
ENG263472-ENG116419-Leuchte 28 RFL L C11-Lichtfunktion G 28    not active     20
ENG263472-ENG116420-Leuchte 28 RFL L C11-Lichtfunktion H 28    not active     20
ENG263472-ENG260485-Leuchte 28 RFL L C11-Lichtfunktion I 28    not active     20
ENG263472-ENG260652-Leuchte 28 RFL L C11-Lichtfunktion J 28    not active     20
ENG263472-ENG258363-Leuchte 28 RFL L C11-Lichtfunktion K 28    not active     20
ENG263472-ENG260174-Leuchte 28 RFL L C11-Lichtfunktion L 28    not active     20
ENG263492-ENG261198-Leuchte 29 RFL R A64-Dimming Direction DEF 29    maximize     20
ENG263492-ENG259250-Leuchte 29 RFL R A64-Dimming Direction GHI 29    maximize     20
ENG263492-ENG260299-Leuchte 29 RFL R A64-Dimming Direction JKL 29    maximize     20
ENG263492-ENG259879-Leuchte 29 RFL R A64-Dimmwert ABC 29    100    20
ENG263492-ENG260443-Leuchte 29 RFL R A64-Dimmwert DEF 29    0    20
ENG263492-ENG260415-Leuchte 29 RFL R A64-Dimmwert GHI 29    0    20
ENG263492-ENG260684-Leuchte 29 RFL R A64-Dimmwert JKL 29    0    20
ENG263492-ENG116425-Leuchte 29 RFL R A64-Fehlerort mittleres Byte DTC-DFCC 29    32    20
ENG263492-ENG116581-Leuchte 29 RFL R A64-Lampendefektbitposition 29    1B     20
ENG263492-ENG116423-Leuchte 29 RFL R A64-Lasttyp 29    allgemeine_LED_mit_Open_Load_Diagnose_12W     20
ENG263492-ENG260077-Leuchte 29 RFL R A64-Lichtansteuerung HD ABC 29    Always     20
ENG263492-ENG116426-Leuchte 29 RFL R A64-Lichtfunktion A 29    Rueckfahrlicht     20
ENG263492-ENG116427-Leuchte 29 RFL R A64-Lichtfunktion B 29    not active     20
ENG263492-ENG116429-Leuchte 29 RFL R A64-Lichtfunktion C 29    not active     20
ENG263492-ENG116431-Leuchte 29 RFL R A64-Lichtfunktion D 29    not active     20
ENG263492-ENG116434-Leuchte 29 RFL R A64-Lichtfunktion E 29    not active     20
ENG263492-ENG116435-Leuchte 29 RFL R A64-Lichtfunktion F 29    not active     20
ENG263492-ENG116438-Leuchte 29 RFL R A64-Lichtfunktion G 29    not active     20
ENG263492-ENG116439-Leuchte 29 RFL R A64-Lichtfunktion H 29    not active     20
ENG263492-ENG260646-Leuchte 29 RFL R A64-Lichtfunktion I 29    not active     20
ENG263492-ENG259712-Leuchte 29 RFL R A64-Lichtfunktion J 29    not active     20
ENG263492-ENG259236-Leuchte 29 RFL R A64-Lichtfunktion K 29    not active     20
ENG263492-ENG259606-Leuchte 29 RFL R A64-Lichtfunktion L 29    not active     20
ENG263454-ENG260476-Leuchte 3 SL VR B32-Dimming Direction DEF 3    maximize     20
ENG263454-ENG259703-Leuchte 3 SL VR B32-Dimming Direction GHI 3    maximize     20
ENG263454-ENG259508-Leuchte 3 SL VR B32-Dimming Direction JKL 3    maximize     20
ENG263454-ENG258539-Leuchte 3 SL VR B32-Dimmwert ABC 3    100    20
ENG263454-ENG259082-Leuchte 3 SL VR B32-Dimmwert DEF 3    0    20
ENG263454-ENG260713-Leuchte 3 SL VR B32-Dimmwert GHI 3    0    20
ENG263454-ENG261150-Leuchte 3 SL VR B32-Dimmwert JKL 3    0    20
ENG263454-ENG115931-Leuchte 3 SL VR B32-Fehlerort mittleres Byte DTC-DFCC 3    2A     20
ENG263454-ENG116551-Leuchte 3 SL VR B32-Lampendefektbitposition 3    1A     20
ENG263454-ENG115929-Leuchte 3 SL VR B32-Lasttyp 3    allgemeine_LED_mit_Open_Load_Diagnose_12W     20
ENG263454-ENG260316-Leuchte 3 SL VR B32-Lichtansteuerung HD ABC 3    Always     20
ENG263454-ENG115932-Leuchte 3 SL VR B32-Lichtfunktion A 3    Position lamps     20
ENG263454-ENG115933-Leuchte 3 SL VR B32-Lichtfunktion B 3    Parking light right     20
ENG263454-ENG115936-Leuchte 3 SL VR B32-Lichtfunktion C 3    not active     20
ENG263454-ENG115937-Leuchte 3 SL VR B32-Lichtfunktion D 3    not active     20
ENG263454-ENG115940-Leuchte 3 SL VR B32-Lichtfunktion E 3    not active     20
ENG263454-ENG116552-Leuchte 3 SL VR B32-Lichtfunktion F 3    not active     20
ENG263454-ENG115944-Leuchte 3 SL VR B32-Lichtfunktion G 3    not active     20
ENG263454-ENG115945-Leuchte 3 SL VR B32-Lichtfunktion H 3    not active     20
ENG263454-ENG260399-Leuchte 3 SL VR B32-Lichtfunktion I 3    not active     20
ENG263454-ENG260155-Leuchte 3 SL VR B32-Lichtfunktion J 3    not active     20
ENG263454-ENG260622-Leuchte 3 SL VR B32-Lichtfunktion K 3    not active     20
ENG263454-ENG258091-Leuchte 3 SL VR B32-Lichtfunktion L 3    not active     20
ENG263428-ENG260857-Leuchte 30 FR L C72-Dimming Direction DEF 30    maximize     20
ENG263428-ENG258841-Leuchte 30 FR L C72-Dimming Direction GHI 30    maximize     20
ENG263428-ENG259433-Leuchte 30 FR L C72-Dimming Direction JKL 30    maximize     20
ENG263428-ENG259620-Leuchte 30 FR L C72-Dimmwert ABC 30    0    20
ENG263428-ENG260960-Leuchte 30 FR L C72-Dimmwert DEF 30    0    20
ENG263428-ENG260191-Leuchte 30 FR L C72-Dimmwert GHI 30    0    20
ENG263428-ENG259143-Leuchte 30 FR L C72-Dimmwert JKL 30    0    20
ENG263428-ENG116444-Leuchte 30 FR L C72-Fehlerort mittleres Byte DTC-DFCC 30    0    20
ENG263428-ENG116582-Leuchte 30 FR L C72-Lampendefektbitposition 30    0    20
ENG263428-ENG116442-Leuchte 30 FR L C72-Lasttyp 30    not_active     20
ENG263428-ENG261067-Leuchte 30 FR L C72-Lichtansteuerung HD ABC 30    Always     20
ENG263428-ENG116445-Leuchte 30 FR L C72-Lichtfunktion A 30    not active     20
ENG263428-ENG116446-Leuchte 30 FR L C72-Lichtfunktion B 30    not active     20
ENG263428-ENG116449-Leuchte 30 FR L C72-Lichtfunktion C 30    not active     20
ENG263428-ENG116450-Leuchte 30 FR L C72-Lichtfunktion D 30    not active     20
ENG263428-ENG116453-Leuchte 30 FR L C72-Lichtfunktion E 30    not active     20
ENG263428-ENG116454-Leuchte 30 FR L C72-Lichtfunktion F 30    not active     20
ENG263428-ENG116457-Leuchte 30 FR L C72-Lichtfunktion G 30    not active     20
ENG263428-ENG116458-Leuchte 30 FR L C72-Lichtfunktion H 30    not active     20
ENG263428-ENG260108-Leuchte 30 FR L C72-Lichtfunktion I 30    not active     20
ENG263428-ENG260034-Leuchte 30 FR L C72-Lichtfunktion J 30    not active     20
ENG263428-ENG259668-Leuchte 30 FR L C72-Lichtfunktion K 30    not active     20
ENG263428-ENG258691-Leuchte 30 FR L C72-Lichtfunktion L 30    not active     20
ENG263445-ENG260925-Leuchte 31 AMBL 1 C61-Dimming Direction DEF 31    maximize     20
ENG263445-ENG259991-Leuchte 31 AMBL 1 C61-Dimming Direction GHI 31    maximize     20
ENG263445-ENG259114-Leuchte 31 AMBL 1 C61-Dimming Direction JKL 31    maximize     20
ENG263445-ENG261277-Leuchte 31 AMBL 1 C61-Dimmwert ABC 31    0    20
ENG263445-ENG259981-Leuchte 31 AMBL 1 C61-Dimmwert DEF 31    0    20
ENG263445-ENG260837-Leuchte 31 AMBL 1 C61-Dimmwert GHI 31    0    20
ENG263445-ENG258112-Leuchte 31 AMBL 1 C61-Dimmwert JKL 31    0    20
ENG263445-ENG116463-Leuchte 31 AMBL 1 C61-Fehlerort mittleres Byte DTC-DFCC 31    0    20
ENG263445-ENG116583-Leuchte 31 AMBL 1 C61-Lampendefektbitposition 31    0    20
ENG263445-ENG116461-Leuchte 31 AMBL 1 C61-Lasttyp 31    not_active     20
ENG263445-ENG260205-Leuchte 31 AMBL 1 C61-Lichtansteuerung HD ABC 31    Always     20
ENG263445-ENG116464-Leuchte 31 AMBL 1 C61-Lichtfunktion A 31    not active     20
ENG263445-ENG116465-Leuchte 31 AMBL 1 C61-Lichtfunktion B 31    not active     20
ENG263445-ENG116468-Leuchte 31 AMBL 1 C61-Lichtfunktion C 31    not active     20
ENG263445-ENG116469-Leuchte 31 AMBL 1 C61-Lichtfunktion D 31    not active     20
ENG263445-ENG116472-Leuchte 31 AMBL 1 C61-Lichtfunktion E 31    not active     20
ENG263445-ENG116473-Leuchte 31 AMBL 1 C61-Lichtfunktion F 31    not active     20
ENG263445-ENG116476-Leuchte 31 AMBL 1 C61-Lichtfunktion G 31    not active     20
ENG263445-ENG116477-Leuchte 31 AMBL 1 C61-Lichtfunktion H 31    not active     20
ENG263445-ENG260861-Leuchte 31 AMBL 1 C61-Lichtfunktion I 31    not active     20
ENG263445-ENG260553-Leuchte 31 AMBL 1 C61-Lichtfunktion J 31    not active     20
ENG263445-ENG259999-Leuchte 31 AMBL 1 C61-Lichtfunktion K 31    not active     20
ENG263445-ENG260353-Leuchte 31 AMBL 1 C61-Lichtfunktion L 31    not active     20
ENG263449-ENG259710-Leuchte 32 AMBL 2 C35-Dimming Direction DEF 32    maximize     20
ENG263449-ENG258905-Leuchte 32 AMBL 2 C35-Dimming Direction GHI 32    maximize     20
ENG263449-ENG260532-Leuchte 32 AMBL 2 C35-Dimming Direction JKL 32    maximize     20
ENG263449-ENG259737-Leuchte 32 AMBL 2 C35-Dimmwert ABC 32    0    20
ENG263449-ENG259346-Leuchte 32 AMBL 2 C35-Dimmwert DEF 32    0    20
ENG263449-ENG260258-Leuchte 32 AMBL 2 C35-Dimmwert GHI 32    0    20
ENG263449-ENG260382-Leuchte 32 AMBL 2 C35-Dimmwert JKL 32    0    20
ENG263449-ENG116482-Leuchte 32 AMBL 2 C35-Fehlerort mittleres Byte DTC-DFCC 32    0    20
ENG263449-ENG116584-Leuchte 32 AMBL 2 C35-Lampendefektbitposition 32    0    20
ENG263449-ENG116480-Leuchte 32 AMBL 2 C35-Lasttyp 32    not_active     20
ENG263449-ENG259035-Leuchte 32 AMBL 2 C35-Lichtansteuerung HD ABC 32    Always     20
ENG263449-ENG116483-Leuchte 32 AMBL 2 C35-Lichtfunktion A 32    not active     20
ENG263449-ENG116484-Leuchte 32 AMBL 2 C35-Lichtfunktion B 32    not active     20
ENG263449-ENG116487-Leuchte 32 AMBL 2 C35-Lichtfunktion C 32    not active     20
ENG263449-ENG116488-Leuchte 32 AMBL 2 C35-Lichtfunktion D 32    not active     20
ENG263449-ENG116491-Leuchte 32 AMBL 2 C35-Lichtfunktion E 32    not active     20
ENG263449-ENG116492-Leuchte 32 AMBL 2 C35-Lichtfunktion F 32    not active     20
ENG263449-ENG116495-Leuchte 32 AMBL 2 C35-Lichtfunktion G 32    not active     20
ENG263449-ENG116496-Leuchte 32 AMBL 2 C35-Lichtfunktion H 32    not active     20
ENG263449-ENG258763-Leuchte 32 AMBL 2 C35-Lichtfunktion I 32    not active     20
ENG263449-ENG259842-Leuchte 32 AMBL 2 C35-Lichtfunktion J 32    not active     20
ENG263449-ENG258857-Leuchte 32 AMBL 2 C35-Lichtfunktion K 32    not active     20
ENG263449-ENG260175-Leuchte 32 AMBL 2 C35-Lichtfunktion L 32    not active     20
ENG263439-ENG258755-Leuchte 33 AMBL 3 C36-Dimming Direction DEF 33    maximize     20
ENG263439-ENG258237-Leuchte 33 AMBL 3 C36-Dimming Direction GHI 33    maximize     20
ENG263439-ENG259038-Leuchte 33 AMBL 3 C36-Dimming Direction JKL 33    maximize     20
ENG263439-ENG259476-Leuchte 33 AMBL 3 C36-Dimmwert ABC 33    0    20
ENG263439-ENG260461-Leuchte 33 AMBL 3 C36-Dimmwert DEF 33    0    20
ENG263439-ENG261181-Leuchte 33 AMBL 3 C36-Dimmwert GHI 33    0    20
ENG263439-ENG258425-Leuchte 33 AMBL 3 C36-Dimmwert JKL 33    0    20
ENG263439-ENG116501-Leuchte 33 AMBL 3 C36-Fehlerort mittleres Byte DTC-DFCC 33    0    20
ENG263439-ENG116585-Leuchte 33 AMBL 3 C36-Lampendefektbitposition 33    0    20
ENG263439-ENG116499-Leuchte 33 AMBL 3 C36-Lasttyp 33    not_active     20
ENG263439-ENG259471-Leuchte 33 AMBL 3 C36-Lichtansteuerung HD ABC 33    Always     20
ENG263439-ENG116502-Leuchte 33 AMBL 3 C36-Lichtfunktion A 33    not active     20
ENG263439-ENG116503-Leuchte 33 AMBL 3 C36-Lichtfunktion B 33    not active     20
ENG263439-ENG116506-Leuchte 33 AMBL 3 C36-Lichtfunktion C 33    not active     20
ENG263439-ENG116507-Leuchte 33 AMBL 3 C36-Lichtfunktion D 33    not active     20
ENG263439-ENG116510-Leuchte 33 AMBL 3 C36-Lichtfunktion E 33    not active     20
ENG263439-ENG116511-Leuchte 33 AMBL 3 C36-Lichtfunktion F 33    not active     20
ENG263439-ENG116514-Leuchte 33 AMBL 3 C36-Lichtfunktion G 33    not active     20
ENG263439-ENG116515-Leuchte 33 AMBL 3 C36-Lichtfunktion H 33    not active     20
ENG263439-ENG260403-Leuchte 33 AMBL 3 C36-Lichtfunktion I 33    not active     20
ENG263439-ENG261239-Leuchte 33 AMBL 3 C36-Lichtfunktion J 33    not active     20
ENG263439-ENG260953-Leuchte 33 AMBL 3 C36-Lichtfunktion K 33    not active     20
ENG263439-ENG261234-Leuchte 33 AMBL 3 C36-Lichtfunktion L 33    not active     20
ENG263434-ENG259648-Leuchte 34 AMBL 4 C37-Dimming Direction DEF 34    maximize     20
ENG263434-ENG259188-Leuchte 34 AMBL 4 C37-Dimming Direction GHI 34    maximize     20
ENG263434-ENG260464-Leuchte 34 AMBL 4 C37-Dimming Direction JKL 34    maximize     20
ENG263434-ENG259524-Leuchte 34 AMBL 4 C37-Dimmwert ABC 34    0    20
ENG263434-ENG260705-Leuchte 34 AMBL 4 C37-Dimmwert DEF 34    0    20
ENG263434-ENG258677-Leuchte 34 AMBL 4 C37-Dimmwert GHI 34    0    20
ENG263434-ENG259924-Leuchte 34 AMBL 4 C37-Dimmwert JKL 34    0    20
ENG263434-ENG116520-Leuchte 34 AMBL 4 C37-Fehlerort mittleres Byte DTC-DFCC 34    0    20
ENG263434-ENG116586-Leuchte 34 AMBL 4 C37-Lampendefektbitposition 34    0    20
ENG263434-ENG116518-Leuchte 34 AMBL 4 C37-Lasttyp 34    not_active     20
ENG263434-ENG259804-Leuchte 34 AMBL 4 C37-Lichtansteuerung HD ABC 34    Always     20
ENG263434-ENG116521-Leuchte 34 AMBL 4 C37-Lichtfunktion A 34    not active     20
ENG263434-ENG116522-Leuchte 34 AMBL 4 C37-Lichtfunktion B 34    not active     20
ENG263434-ENG116525-Leuchte 34 AMBL 4 C37-Lichtfunktion C 34    not active     20
ENG263434-ENG116526-Leuchte 34 AMBL 4 C37-Lichtfunktion D 34    not active     20
ENG263434-ENG116529-Leuchte 34 AMBL 4 C37-Lichtfunktion E 34    not active     20
ENG263434-ENG116530-Leuchte 34 AMBL 4 C37-Lichtfunktion F 34    not active     20
ENG263434-ENG116533-Leuchte 34 AMBL 4 C37-Lichtfunktion G 34    not active     20
ENG263434-ENG116534-Leuchte 34 AMBL 4 C37-Lichtfunktion H 34    not active     20
ENG263434-ENG259061-Leuchte 34 AMBL 4 C37-Lichtfunktion I 34    not active     20
ENG263434-ENG258125-Leuchte 34 AMBL 4 C37-Lichtfunktion J 34    not active     20
ENG263434-ENG259670-Leuchte 34 AMBL 4 C37-Lichtfunktion K 34    not active     20
ENG263434-ENG260771-Leuchte 34 AMBL 4 C37-Lichtfunktion L 34    not active     20
ENG141657-ENG258314-Leuchte 35 LED Warnblinktaster C48-Dimming Direction DEF 35    maximize     20
ENG141657-ENG260208-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GHI 35    maximize     20
ENG141657-ENG260869-Leuchte 35 LED Warnblinktaster C48-Dimming Direction JKL 35    maximize     20
ENG141657-ENG259780-Leuchte 35 LED Warnblinktaster C48-Dimmwert ABC 35    100    20
ENG141657-ENG258175-Leuchte 35 LED Warnblinktaster C48-Dimmwert DEF 35    0    20
ENG141657-ENG259257-Leuchte 35 LED Warnblinktaster C48-Dimmwert GHI 35    0    20
ENG141657-ENG260977-Leuchte 35 LED Warnblinktaster C48-Dimmwert JKL 35    0    20
ENG141657-ENG258758-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 35    0    20
ENG141657-ENG258551-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 35    0    20
ENG141657-ENG259566-Leuchte 35 LED Warnblinktaster C48-Lasttyp 35    LED_Kleinleistung_ohne_Open_Load_Diagnose     20
ENG141657-ENG260595-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD ABC 35    Always     20
ENG141657-ENG260217-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 35    Warnblink Taster Suchbeleuchtung     20
ENG141657-ENG259017-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 35    not active     20
ENG141657-ENG259618-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 35    not active     20
ENG141657-ENG259584-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 35    not active     20
ENG141657-ENG259128-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 35    not active     20
ENG141657-ENG258995-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 35    not active     20
ENG141657-ENG258137-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 35    not active     20
ENG141657-ENG259014-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 35    not active     20
ENG141657-ENG258258-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion I 35    not active     20
ENG141657-ENG260608-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion J 35    not active     20
ENG141657-ENG260082-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion K 35    not active     20
ENG141657-ENG261046-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion L 35    not active     20
Jasons6930
Code: Select all
ENG253037-ENG259399-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction DEF 36    maximize     20
ENG253037-ENG260703-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction GHI 36    maximize     20
ENG253037-ENG260112-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction JKL 36    maximize     20
ENG253037-ENG258344-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert ABC 36    0    20
ENG253037-ENG258426-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert DEF 36    0    20
ENG253037-ENG260039-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert GHI 36    0    20
ENG253037-ENG259503-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert JKL 36    0    20
ENG253037-ENG260858-Leuchte 36 LEDNL_PWM_L_B37-Fehlerort mittleres Byte DTC-DFCC 36    0    20
ENG253037-ENG258523-Leuchte 36 LEDNL_PWM_L_B37-Lampendefektbitposition 36    0    20
ENG253037-ENG261341-Leuchte 36 LEDNL_PWM_L_B37-Lasttyp 36    not_active     20
ENG253037-ENG259878-Leuchte 36 LEDNL_PWM_L_B37-Lichtansteuerung HD ABC 36    Always     20
ENG253037-ENG258899-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion A 36    not active     20
ENG253037-ENG260362-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion B 36    not active     20
ENG253037-ENG258356-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion C 36    not active     20
ENG253037-ENG258388-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion D 36    not active     20
ENG253037-ENG258248-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion E 36    not active     20
ENG253037-ENG260017-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion F 36    not active     20
ENG253037-ENG260071-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion G 36    not active     20
ENG253037-ENG259734-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion H 36    not active     20
ENG253037-ENG260720-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion I 36    not active     20
ENG253037-ENG259525-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion J 36    not active     20
ENG253037-ENG259972-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion K 36    not active     20
ENG253037-ENG259404-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion L 36    not active     20
ENG253226-ENG260671-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction DEF 37    maximize     20
ENG253226-ENG258552-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction GHI 37    maximize     20
ENG253226-ENG260966-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction JKL 37    maximize     20
ENG253226-ENG260262-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert ABC 37    0    20
ENG253226-ENG258498-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert DEF 37    0    20
ENG253226-ENG258952-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert GHI 37    0    20
ENG253226-ENG260588-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert JKL 37    0    20
ENG253226-ENG258708-Leuchte 37 LEDNL_PWM_R_B38-Fehlerort mittleres Byte DTC-DFCC 37    0    20
ENG253226-ENG260786-Leuchte 37 LEDNL_PWM_R_B38-Lampendefektbitposition 37    0    20
ENG253226-ENG259218-Leuchte 37 LEDNL_PWM_R_B38-Lasttyp 37    not_active     20
ENG253226-ENG260323-Leuchte 37 LEDNL_PWM_R_B38-Lichtansteuerung HD ABC 37    Always     20
ENG253226-ENG259995-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion A 37    not active     20
ENG253226-ENG259686-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion B 37    not active     20
ENG253226-ENG259495-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion C 37    not active     20
ENG253226-ENG258914-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion D 37    not active     20
ENG253226-ENG258741-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion E 37    not active     20
ENG253226-ENG261001-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion F 37    not active     20
ENG253226-ENG259796-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion G 37    not active     20
ENG253226-ENG258391-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion H 37    not active     20
ENG253226-ENG260757-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion I 37    not active     20
ENG253226-ENG261282-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion J 37    not active     20
ENG253226-ENG258097-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion K 37    not active     20
ENG253226-ENG261120-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion L 37    not active     20
ENG253185-ENG260594-Leuchte 38 Sidemarker_V_B21-Dimming Direction DEF 38    maximize     20
ENG253185-ENG259176-Leuchte 38 Sidemarker_V_B21-Dimming Direction GHI 38    maximize     20
ENG253185-ENG258361-Leuchte 38 Sidemarker_V_B21-Dimming Direction JKL 38    maximize     20
ENG253185-ENG258271-Leuchte 38 Sidemarker_V_B21-Dimmwert ABC 38    0    20
ENG253185-ENG258593-Leuchte 38 Sidemarker_V_B21-Dimmwert DEF 38    0    20
ENG253185-ENG259740-Leuchte 38 Sidemarker_V_B21-Dimmwert GHI 38    0    20
ENG253185-ENG260375-Leuchte 38 Sidemarker_V_B21-Dimmwert JKL 38    0    20
ENG253185-ENG259110-Leuchte 38 Sidemarker_V_B21-Fehlerort mittleres Byte DTC-DFCC 38    0    20
ENG253185-ENG259339-Leuchte 38 Sidemarker_V_B21-Lampendefektbitposition 38    0    20
ENG253185-ENG258774-Leuchte 38 Sidemarker_V_B21-Lasttyp 38    not_active     20
ENG253185-ENG259319-Leuchte 38 Sidemarker_V_B21-Lichtansteuerung HD ABC 38    Always     20
ENG253185-ENG258971-Leuchte 38 Sidemarker_V_B21-Lichtfunktion A 38    not active     20
ENG253185-ENG260328-Leuchte 38 Sidemarker_V_B21-Lichtfunktion B 38    not active     20
ENG253185-ENG258602-Leuchte 38 Sidemarker_V_B21-Lichtfunktion C 38    not active     20
ENG253185-ENG260130-Leuchte 38 Sidemarker_V_B21-Lichtfunktion D 38    not active     20
ENG253185-ENG260126-Leuchte 38 Sidemarker_V_B21-Lichtfunktion E 38    not active     20
ENG253185-ENG260093-Leuchte 38 Sidemarker_V_B21-Lichtfunktion F 38    not active     20
ENG253185-ENG258515-Leuchte 38 Sidemarker_V_B21-Lichtfunktion G 38    not active     20
ENG253185-ENG259657-Leuchte 38 Sidemarker_V_B21-Lichtfunktion H 38    not active     20
ENG253185-ENG259428-Leuchte 38 Sidemarker_V_B21-Lichtfunktion I 38    not active     20
ENG253185-ENG258516-Leuchte 38 Sidemarker_V_B21-Lichtfunktion J 38    not active     20
ENG253185-ENG260994-Leuchte 38 Sidemarker_V_B21-Lichtfunktion K 38    not active     20
ENG253185-ENG259179-Leuchte 38 Sidemarker_V_B21-Lichtfunktion L 38    not active     20
ENG253171-ENG259501-Leuchte 39 Sidemarker_H C26-Dimming Direction DEF 39    maximize     20
ENG253171-ENG260533-Leuchte 39 Sidemarker_H C26-Dimming Direction GHI 39    maximize     20
ENG253171-ENG259331-Leuchte 39 Sidemarker_H C26-Dimming Direction JKL 39    maximize     20
ENG253171-ENG259663-Leuchte 39 Sidemarker_H C26-Dimmwert ABC 39    0    20
ENG253171-ENG260625-Leuchte 39 Sidemarker_H C26-Dimmwert DEF 39    0    20
ENG253171-ENG258607-Leuchte 39 Sidemarker_H C26-Dimmwert GHI 39    0    20
ENG253171-ENG259031-Leuchte 39 Sidemarker_H C26-Dimmwert JKL 39    0    20
ENG253171-ENG260272-Leuchte 39 Sidemarker_H C26-Fehlerort mittleres Byte DTC-DFCC 39    0    20
ENG253171-ENG261342-Leuchte 39 Sidemarker_H C26-Lampendefektbitposition 39    0    20
ENG253171-ENG258910-Leuchte 39 Sidemarker_H C26-Lasttyp 39    not_active     20
ENG253171-ENG261145-Leuchte 39 Sidemarker_H C26-Lichtansteuerung HD ABC 39    Always     20
ENG253171-ENG259436-Leuchte 39 Sidemarker_H C26-Lichtfunktion A 39    not active     20
ENG253171-ENG260471-Leuchte 39 Sidemarker_H C26-Lichtfunktion B 39    not active     20
ENG253171-ENG260554-Leuchte 39 Sidemarker_H C26-Lichtfunktion C 39    not active     20
ENG253171-ENG258988-Leuchte 39 Sidemarker_H C26-Lichtfunktion D 39    not active     20
ENG253171-ENG259727-Leuchte 39 Sidemarker_H C26-Lichtfunktion E 39    not active     20
ENG253171-ENG258355-Leuchte 39 Sidemarker_H C26-Lichtfunktion F 39    not active     20
ENG253171-ENG261095-Leuchte 39 Sidemarker_H C26-Lichtfunktion G 39    not active     20
ENG253171-ENG258577-Leuchte 39 Sidemarker_H C26-Lichtfunktion H 39    not active     20
ENG253171-ENG259902-Leuchte 39 Sidemarker_H C26-Lichtfunktion I 39    not active     20
ENG253171-ENG260202-Leuchte 39 Sidemarker_H C26-Lichtfunktion J 39    not active     20
ENG253171-ENG260436-Leuchte 39 Sidemarker_H C26-Lichtfunktion K 39    not active     20
ENG253171-ENG259237-Leuchte 39 Sidemarker_H C26-Lichtfunktion L 39    not active     20
ENG263459-ENG258414-Leuchte 4 TFL L B3-Dimming Direction DEF 4    maximize     20
ENG263459-ENG260894-Leuchte 4 TFL L B3-Dimming Direction GHI 4    maximize     20
ENG263459-ENG259900-Leuchte 4 TFL L B3-Dimming Direction JKL 4    maximize     20
ENG263459-ENG259665-Leuchte 4 TFL L B3-Dimmwert ABC 4    0    20
ENG263459-ENG260507-Leuchte 4 TFL L B3-Dimmwert DEF 4    0    20
ENG263459-ENG258447-Leuchte 4 TFL L B3-Dimmwert GHI 4    0    20
ENG263459-ENG258461-Leuchte 4 TFL L B3-Dimmwert JKL 4    0    20
ENG263459-ENG115950-Leuchte 4 TFL L B3-Fehlerort mittleres Byte DTC-DFCC 4    0    20
ENG263459-ENG116553-Leuchte 4 TFL L B3-Lampendefektbitposition 4    0    20
ENG263459-ENG115948-Leuchte 4 TFL L B3-Lasttyp 4    not_active     20
ENG263459-ENG259234-Leuchte 4 TFL L B3-Lichtansteuerung HD ABC 4    Always     20
ENG263459-ENG115951-Leuchte 4 TFL L B3-Lichtfunktion A 4    not active     20
ENG263459-ENG115952-Leuchte 4 TFL L B3-Lichtfunktion B 4    not active     20
ENG263459-ENG115955-Leuchte 4 TFL L B3-Lichtfunktion C 4    not active     20
ENG263459-ENG115956-Leuchte 4 TFL L B3-Lichtfunktion D 4    not active     20
ENG263459-ENG115959-Leuchte 4 TFL L B3-Lichtfunktion E 4    not active     20
ENG263459-ENG115960-Leuchte 4 TFL L B3-Lichtfunktion F 4    not active     20
ENG263459-ENG115963-Leuchte 4 TFL L B3-Lichtfunktion G 4    not active     20
ENG263459-ENG115964-Leuchte 4 TFL L B3-Lichtfunktion H 4    not active     20
ENG263459-ENG258442-Leuchte 4 TFL L B3-Lichtfunktion I 4    not active     20
ENG263459-ENG258629-Leuchte 4 TFL L B3-Lichtfunktion J 4    not active     20
ENG263459-ENG259468-Leuchte 4 TFL L B3-Lichtfunktion K 4    not active     20
ENG263459-ENG258421-Leuchte 4 TFL L B3-Lichtfunktion L 4    not active     20
ENG263465-ENG260616-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction DEF 40    maximize     20
ENG263465-ENG259877-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction GHI v    maximize     20
ENG263465-ENG258734-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction JKL 40    maximize     20
ENG263465-ENG258702-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert ABC 40    0    20
ENG263465-ENG259888-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert DEF 40    0    20
ENG263465-ENG258927-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert GHI 40    0    20
ENG263465-ENG258852-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert JKL 40    0    20
ENG263465-ENG260246-Leuchte 40 Zusatz_hecklicht_HL C9-Fehlerort mittleres Byte DTC-DFCC 40    0    20
ENG263465-ENG259652-Leuchte 40 Zusatz_hecklicht_HL C9-Lampendefektbitposition 40    0    20
ENG263465-ENG260978-Leuchte 40 Zusatz_hecklicht_HL C9-Lasttyp 40    not_active     20
ENG263465-ENG259185-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtansteuerung HD ABC 40    Always     20
ENG263465-ENG259008-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion A 40    not active     20
ENG263465-ENG258714-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion B 40    not active     20
ENG263465-ENG258586-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion C 40    not active     20
ENG263465-ENG258768-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion D 40    not active     20
ENG263465-ENG259573-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion E 40    not active     20
ENG263465-ENG258923-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion F 40    not active     20
ENG263465-ENG258928-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion G 40    not active     20
ENG263465-ENG259450-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion H 40    not active     20
ENG263465-ENG260309-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion I 40    not active     20
ENG263465-ENG258499-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion J 40    not active     20
ENG263465-ENG261065-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion K 40    not active     20
ENG263465-ENG259658-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion L 40    not active     20
ENG263486-ENG259814-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction DEF 41    maximize     20
ENG263486-ENG259194-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction GHI 41    maximize     20
ENG263486-ENG258697-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction JKL 41    maximize     20
ENG263486-ENG260405-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert ABC 41    0    20
ENG263486-ENG261284-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert DEF 41    0    20
ENG263486-ENG259351-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert GHI 41    0    20
ENG263486-ENG258887-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert JKL 41    0    20
ENG263486-ENG258329-Leuchte 41 Zusatz_hecklicht_HR A67-Fehlerort mittleres Byte DTC-DFCC 41    0    20
ENG263486-ENG258960-Leuchte 41 Zusatz_hecklicht_HR A67-Lampendefektbitposition 41    0    20
ENG263486-ENG261015-Leuchte 41 Zusatz_hecklicht_HR A67-Lasttyp 41    not_active     20
ENG263486-ENG260435-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtansteuerung HD ABC 41    Always     20
ENG263486-ENG260996-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion A 41    not active     20
ENG263486-ENG259966-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion B 41    not active     20
ENG263486-ENG258450-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion C 41    not active     20
ENG263486-ENG259570-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion D 41    not active     20
ENG263486-ENG260906-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion E 41    not active     20
ENG263486-ENG260838-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion F 41    not active     20
ENG263486-ENG258108-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion G 41    not active     20
ENG263486-ENG258430-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion H 41    not active     20
ENG263486-ENG260615-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion I 41    not active     20
ENG263486-ENG260918-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion J 41    not active     20
ENG263486-ENG258150-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion K 41    not active     20
ENG263486-ENG258739-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion L 41    not active     20
ENG253110-ENG261024-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction DEF 42    maximize     20
ENG253110-ENG258668-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction GHI 42    maximize     20
ENG253110-ENG258123-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction JKL 42    maximize     20
ENG253110-ENG258370-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert ABC 42    0    20
ENG253110-ENG258109-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert DEF 42    0    20
ENG253110-ENG261169-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert GHI 42    0    20
ENG253110-ENG259028-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert JKL 42    0    20
ENG253110-ENG259381-Leuchte 42 Wischblinksignal_li C30_B35-Fehlerort mittleres Byte DTC-DFCC 42    0    20
ENG253110-ENG259973-Leuchte 42 Wischblinksignal_li C30_B35-Lampendefektbitposition 42    0    20
ENG253110-ENG258662-Leuchte 42 Wischblinksignal_li C30_B35-Lasttyp 42    not_active     20
ENG253110-ENG258290-Leuchte 42 Wischblinksignal_li C30_B35-Lichtansteuerung HD ABC 42    Always     20
ENG253110-ENG258895-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion A 42    not active     20
ENG253110-ENG260384-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion B 42    not active     20
ENG253110-ENG261085-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion C 42    not active     20
ENG253110-ENG260667-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion D 42    not active     20
ENG253110-ENG260232-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion E 42    not active     20
ENG253110-ENG258671-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion F 42    not active     20
ENG253110-ENG259243-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion G 42    not active     20
ENG253110-ENG259518-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion H 42    not active     20
ENG253110-ENG259526-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion I 42    not active     20
ENG253110-ENG259239-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion J 42    not active     20
ENG253110-ENG258327-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion K 42    not active     20
ENG253110-ENG260944-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion L 42    not active     20
ENG253212-ENG261135-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction DEF 43    maximize     20
ENG253212-ENG258953-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction GHI 43    maximize     20
ENG253212-ENG260351-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction JKL 43    maximize     20
ENG253212-ENG259567-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert ABC 43    0    20
ENG253212-ENG259435-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert DEF 43    0    20
ENG253212-ENG260024-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert GHI 43    0    20
ENG253212-ENG259623-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert JKL 43    0    20
ENG253212-ENG258411-Leuchte 43 Wischblinksignal_re C33_B36-Fehlerort mittleres Byte DTC-DFCC 43    0    20
ENG253212-ENG261311-Leuchte 43 Wischblinksignal_re C33_B36-Lampendefektbitposition 43    0    20
ENG253212-ENG259612-Leuchte 43 Wischblinksignal_re C33_B36-Lasttyp 43    not_active     20
ENG253212-ENG261054-Leuchte 43 Wischblinksignal_re C33_B36-Lichtansteuerung HD ABC 43    Always     20
ENG253212-ENG258146-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion A 43    not active     20
ENG253212-ENG258144-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion B 43    not active     20
ENG253212-ENG258171-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion C 43    not active     20
ENG253212-ENG259397-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion D 43    not active     20
ENG253212-ENG260658-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion E 43    not active     20
ENG253212-ENG260002-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion F 43    not active     20
ENG253212-ENG260698-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion G 43    not active     20
ENG253212-ENG261082-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion H 43    not active     20
ENG253212-ENG260261-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion I 43    not active     20
ENG253212-ENG259097-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion J 43    not active     20
ENG253212-ENG260203-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion K 43    not active     20
ENG253212-ENG258986-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion L 43    not active     20
ENG253108-ENG258231-Leuchte 44 ALV C70-Dimming Direction DEF 44    maximize     20
ENG253108-ENG260416-Leuchte 44 ALV C70-Dimming Direction GHI 44    maximize     20
ENG253108-ENG260409-Leuchte 44 ALV C70-Dimming Direction JKL 44    maximize     20
ENG253108-ENG261347-Leuchte 44 ALV C70-Dimmwert ABC 44    127    20
ENG253108-ENG260630-Leuchte 44 ALV C70-Dimmwert DEF 44    0    20
ENG253108-ENG259610-Leuchte 44 ALV C70-Dimmwert GHI 44    0    20
ENG253108-ENG261335-Leuchte 44 ALV C70-Dimmwert JKL 44    0    20
ENG253108-ENG260566-Leuchte 44 ALV C70-Fehlerort mittleres Byte DTC-DFCC 44    85    20
ENG253108-ENG261036-Leuchte 44 ALV C70-Lampendefektbitposition 44    0    20
ENG253108-ENG258970-Leuchte 44 ALV C70-Lasttyp 44    LED Lichtmodul ohne Open Load Diagnose     20
ENG253108-ENG258540-Leuchte 44 ALV C70-Lichtansteuerung HD ABC 44    Always     20
ENG253108-ENG260079-Leuchte 44 ALV C70-Lichtfunktion A 44    Ambientelichtmodul Versorgung     20
ENG253108-ENG260296-Leuchte 44 ALV C70-Lichtfunktion B 44    not active     20
ENG253108-ENG261154-Leuchte 44 ALV C70-Lichtfunktion C 44    not active     20
ENG253108-ENG259507-Leuchte 44 ALV C70-Lichtfunktion D 44    not active     20
ENG253108-ENG258260-Leuchte 44 ALV C70-Lichtfunktion E 44    not active     20
ENG253108-ENG260714-Leuchte 44 ALV C70-Lichtfunktion F 44    not active     20
ENG253108-ENG260064-Leuchte 44 ALV C70-Lichtfunktion G 44    not active     20
ENG253108-ENG259720-Leuchte 44 ALV C70-Lichtfunktion H 44    not active     20
ENG253108-ENG258947-Leuchte 44 ALV C70-Lichtfunktion I 44    not active     20
ENG253108-ENG260429-Leuchte 44 ALV C70-Lichtfunktion J 44    not active     20
ENG253108-ENG260305-Leuchte 44 ALV C70-Lichtfunktion K 44    not active     20
ENG253108-ENG259925-Leuchte 44 ALV C70-Lichtfunktion L 44    not active     20
ENG253209-ENG259161-Leuchte 45 KRL C56-Dimming Direction DEF 45    maximize     20
ENG253209-ENG260000-Leuchte 45 KRL C56-Dimming Direction GHI 45    maximize     20
ENG253209-ENG258382-Leuchte 45 KRL C56-Dimming Direction JKL 45    maximize     20
ENG253209-ENG258536-Leuchte 45 KRL C56-Dimmwert ABC 45    100    20
ENG253209-ENG261049-Leuchte 45 KRL C56-Dimmwert DEF 45    0    20
ENG253209-ENG258646-Leuchte 45 KRL C56-Dimmwert GHI 45    0    20
ENG253209-ENG258455-Leuchte 45 KRL C56-Dimmwert JKL 45    0    20
ENG253209-ENG258548-Leuchte 45 KRL C56-Fehlerort mittleres Byte DTC-DFCC 45    89    20
ENG253209-ENG259186-Leuchte 45 KRL C56-Lampendefektbitposition 45    0    20
ENG253209-ENG259655-Leuchte 45 KRL C56-Lasttyp 45    LED_Kleinleistung_ohne_Open_Load_Diagnose     20
ENG253209-ENG259881-Leuchte 45 KRL C56-Lichtansteuerung HD ABC 45    Always     20
ENG253209-ENG258376-Leuchte 45 KRL C56-Lichtfunktion A 45    Luggage compartment light     20
ENG253209-ENG260107-Leuchte 45 KRL C56-Lichtfunktion B 45    not active     20
ENG253209-ENG259696-Leuchte 45 KRL C56-Lichtfunktion C 45    not active     20
ENG253209-ENG258534-Leuchte 45 KRL C56-Lichtfunktion D 45    not active     20
ENG253209-ENG258311-Leuchte 45 KRL C56-Lichtfunktion E 45    not active     20
ENG253209-ENG259561-Leuchte 45 KRL C56-Lichtfunktion F 45    not active     20
ENG253209-ENG258655-Leuchte 45 KRL C56-Lichtfunktion G 45    not active     20
ENG253209-ENG258706-Leuchte 45 KRL C56-Lichtfunktion H 45    not active     20
ENG253209-ENG260201-Leuchte 45 KRL C56-Lichtfunktion I 45    not active     20
ENG253209-ENG259692-Leuchte 45 KRL C56-Lichtfunktion J 45    not active     20
ENG253209-ENG259667-Leuchte 45 KRL C56-Lichtfunktion K 45    not active     20
ENG253209-ENG259221-Leuchte 45 KRL C56-Lichtfunktion L 45    not active     20
ENG263430-ENG259519-Leuchte 5 TFL R B4-Dimming Direction DEF 5    maximize     20
ENG263430-ENG258873-Leuchte 5 TFL R B4-Dimming Direction GHI 5    maximize     20
ENG263430-ENG260664-Leuchte 5 TFL R B4-Dimming Direction JKL 5    maximize     20
ENG263430-ENG261164-Leuchte 5 TFL R B4-Dimmwert ABC 5    0    20
ENG263430-ENG259517-Leuchte 5 TFL R B4-Dimmwert DEF 5    0    20
ENG263430-ENG260636-Leuchte 5 TFL R B4-Dimmwert GHI 5    0    20
ENG263430-ENG258543-Leuchte 5 TFL R B4-Dimmwert JKL 5    0    20
ENG263430-ENG115969-Leuchte 5 TFL R B4-Fehlerort mittleres Byte DTC-DFCC 5    0    20
ENG263430-ENG116554-Leuchte 5 TFL R B4-Lampendefektbitposition 5    0    20
ENG263430-ENG115967-Leuchte 5 TFL R B4-Lasttyp 5    not_active     20
ENG263430-ENG258404-Leuchte 5 TFL R B4-Lichtansteuerung HD ABC 5    Always     20
ENG263430-ENG115970-Leuchte 5 TFL R B4-Lichtfunktion A 5    not active     20
ENG263430-ENG115971-Leuchte 5 TFL R B4-Lichtfunktion B 5    not active     20
ENG263430-ENG115974-Leuchte 5 TFL R B4-Lichtfunktion C 5    not active     20
ENG263430-ENG115975-Leuchte 5 TFL R B4-Lichtfunktion D 5    not active     20
ENG263430-ENG115978-Leuchte 5 TFL R B4-Lichtfunktion E 5    not active     20
ENG263430-ENG116555-Leuchte 5 TFL R B4-Lichtfunktion F 5    not active     20
ENG263430-ENG115982-Leuchte 5 TFL R B4-Lichtfunktion G 5    not active     20
ENG263430-ENG115983-Leuchte 5 TFL R B4-Lichtfunktion H 5    not active     20
ENG263430-ENG259352-Leuchte 5 TFL R B4-Lichtfunktion I 5    not active     20
ENG263430-ENG260105-Leuchte 5 TFL R B4-Lichtfunktion J 5    not active     20
ENG263430-ENG261301-Leuchte 5 TFL R B4-Lichtfunktion K 5    not active     20
ENG263430-ENG258882-Leuchte 5 TFL R B4-Lichtfunktion L 5    not active     20
ENG263442-ENG259123-Leuchte 6 ABL L C5-Dimming Direction DEF 6    maximize     20
ENG263442-ENG258751-Leuchte 6 ABL L C5-Dimming Direction GHI 6    maximize     20
ENG263442-ENG259402-Leuchte 6 ABL L C5-Dimming Direction JKL 6    maximize     20
ENG263442-ENG260099-Leuchte 6 ABL L C5-Dimmwert ABC 6    0    20
ENG263442-ENG259481-Leuchte 6 ABL L C5-Dimmwert DEF 6    0    20
ENG263442-ENG258578-Leuchte 6 ABL L C5-Dimmwert GHI 6    0    20
ENG263442-ENG259931-Leuchte 6 ABL L C5-Dimmwert JKL 6    0    20
ENG263442-ENG115988-Leuchte 6 ABL L C5-Fehlerort mittleres Byte DTC-DFCC 6    0    20
ENG263442-ENG116556-Leuchte 6 ABL L C5-Lampendefektbitposition 6    0    20
ENG263442-ENG115986-Leuchte 6 ABL L C5-Lasttyp 6    not_active     20
ENG263442-ENG260333-Leuchte 6 ABL L C5-Lichtansteuerung HD ABC 6    Always     20
ENG263442-ENG115989-Leuchte 6 ABL L C5-Lichtfunktion A 6    not active     20
ENG263442-ENG115990-Leuchte 6 ABL L C5-Lichtfunktion B 6    not active     20
ENG263442-ENG115993-Leuchte 6 ABL L C5-Lichtfunktion C 6    not active     20
ENG263442-ENG115994-Leuchte 6 ABL L C5-Lichtfunktion D 6    not active     20
ENG263442-ENG115997-Leuchte 6 ABL L C5-Lichtfunktion E 6    not active     20
ENG263442-ENG115998-Leuchte 6 ABL L C5-Lichtfunktion F 6    not active     20
ENG263442-ENG116001-Leuchte 6 ABL L C5-Lichtfunktion G 6    not active     20
ENG263442-ENG116002-Leuchte 6 ABL L C5-Lichtfunktion H 6    not active     20
ENG263442-ENG259152-Leuchte 6 ABL L C5-Lichtfunktion I 6    not active     20
ENG263442-ENG260123-Leuchte 6 ABL L C5-Lichtfunktion J 6    not active     20
ENG263442-ENG258263-Leuchte 6 ABL L C5-Lichtfunktion K 6    not active     20
ENG263442-ENG260915-Leuchte 6 ABL L C5-Lichtfunktion L 6    not active     20
ENG263471-ENG258829-Leuchte 7 ABL R B1-Dimming Direction DEF 7    minimze     20
ENG263471-ENG258643-Leuchte 7 ABL R B1-Dimming Direction GHI 7    maximize     20
ENG263471-ENG260358-Leuchte 7 ABL R B1-Dimming Direction JKL 7    maximize     20
ENG263471-ENG258757-Leuchte 7 ABL R B1-Dimmwert ABC 7    0    20
ENG263471-ENG260928-Leuchte 7 ABL R B1-Dimmwert DEF 7    0    20
ENG263471-ENG258547-Leuchte 7 ABL R B1-Dimmwert GHI 7    0    20
ENG263471-ENG260103-Leuchte 7 ABL R B1-Dimmwert JKL 7    0    20
ENG263471-ENG116007-Leuchte 7 ABL R B1-Fehlerort mittleres Byte DTC-DFCC 7    0    20
ENG263471-ENG116557-Leuchte 7 ABL R B1-Lampendefektbitposition 7    0    20
ENG263471-ENG116005-Leuchte 7 ABL R B1-Lasttyp 7    not_active     20
ENG263471-ENG259256-Leuchte 7 ABL R B1-Lichtansteuerung HD ABC 7    Always     20
ENG263471-ENG116008-Leuchte 7 ABL R B1-Lichtfunktion A 7    not active     20
ENG263471-ENG116009-Leuchte 7 ABL R B1-Lichtfunktion B 7    not active     20
ENG263471-ENG116012-Leuchte 7 ABL R B1-Lichtfunktion C 7    not active     20
ENG263471-ENG116013-Leuchte 7 ABL R B1-Lichtfunktion D 7    not active     20
ENG263471-ENG116016-Leuchte 7 ABL R B1-Lichtfunktion E 7    not active     20
ENG263471-ENG116017-Leuchte 7 ABL R B1-Lichtfunktion F 7    not active     20
ENG263471-ENG116020-Leuchte 7 ABL R B1-Lichtfunktion G 7    not active     20
ENG263471-ENG116021-Leuchte 7 ABL R B1-Lichtfunktion H 7    not active     20
ENG263471-ENG259451-Leuchte 7 ABL R B1-Lichtfunktion I 7    not active     20
ENG263471-ENG259043-Leuchte 7 ABL R B1-Lichtfunktion J 7    not active     20
ENG263471-ENG261166-Leuchte 7 ABL R B1-Lichtfunktion K 7    not active     20
ENG263471-ENG258778-Leuchte 7 ABL R B1-Lichtfunktion L 7    not active     20
ENG263437-ENG260885-Leuchte 8 FL L B39-Dimming Direction DEF 8    maximize     20
ENG263437-ENG259591-Leuchte 8 FL L B39-Dimming Direction GHI 8    maximize     20
ENG263437-ENG259283-Leuchte 8 FL L B39-Dimming Direction JKL 8    maximize     20
ENG263437-ENG259944-Leuchte 8 FL L B39-Dimmwert ABC 8    0    20
ENG263437-ENG258915-Leuchte 8 FL L B39-Dimmwert DEF 8    0    20
ENG263437-ENG261200-Leuchte 8 FL L B39-Dimmwert GHI 8    0    20
ENG263437-ENG259325-Leuchte 8 FL L B39-Dimmwert JKL 8    0    20
ENG263437-ENG116026-Leuchte 8 FL L B39-Fehlerort mittleres Byte DTC-DFCC 8    0    20
ENG263437-ENG116558-Leuchte 8 FL L B39-Lampendefektbitposition 8    0    20
ENG263437-ENG116024-Leuchte 8 FL L B39-Lasttyp 8    not_active     20
ENG263437-ENG261218-Leuchte 8 FL L B39-Lichtansteuerung HD ABC 8    Always     20
ENG263437-ENG116027-Leuchte 8 FL L B39-Lichtfunktion A 8    not active     20
ENG263437-ENG116028-Leuchte 8 FL L B39-Lichtfunktion B 8    not active     20
ENG263437-ENG116031-Leuchte 8 FL L B39-Lichtfunktion C 8    not active     20
ENG263437-ENG116032-Leuchte 8 FL L B39-Lichtfunktion D 8    not active     20
ENG263437-ENG116035-Leuchte 8 FL L B39-Lichtfunktion E 8    not active     20
ENG263437-ENG116036-Leuchte 8 FL L B39-Lichtfunktion F 8    not active     20
ENG263437-ENG116039-Leuchte 8 FL L B39-Lichtfunktion G 8    not active     20
ENG263437-ENG116040-Leuchte 8 FL L B39-Lichtfunktion H 8    not active     20
ENG263437-ENG261106-Leuchte 8 FL L B39-Lichtfunktion I 8    not active     20
ENG263437-ENG259701-Leuchte 8 FL L B39-Lichtfunktion J 8    not active     20
ENG263437-ENG260491-Leuchte 8 FL L B39-Lichtfunktion K 8    not active     20
ENG263437-ENG260880-Leuchte 8 FL L B39-Lichtfunktion L 8    not active     20
ENG263456-ENG260851-Leuchte 9 FL R B2-Dimming Direction DEF 9    maximize     20
ENG263456-ENG260306-Leuchte 9 FL R B2-Dimming Direction GHI 9    maximize     20
ENG263456-ENG261237-Leuchte 9 FL R B2-Dimming Direction JKL 9    maximize     20
ENG263456-ENG260111-Leuchte 9 FL R B2-Dimmwert ABC 9    0    20
ENG263456-ENG260295-Leuchte 9 FL R B2-Dimmwert DEF 9    0    20
ENG263456-ENG259797-Leuchte 9 FL R B2-Dimmwert GHI 9    0    20
ENG263456-ENG260331-Leuchte 9 FL R B2-Dimmwert JKL 9    0    20
ENG263456-ENG116045-Leuchte 9 FL R B2-Fehlerort mittleres Byte DTC-DFCC 9    0    20
ENG263456-ENG116559-Leuchte 9 FL R B2-Lampendefektbitposition 9    0    20
ENG263456-ENG116043-Leuchte 9 FL R B2-Lasttyp 9    not_active     20
ENG263456-ENG258094-Leuchte 9 FL R B2-Lichtansteuerung HD ABC 9    Always     20
ENG263456-ENG116046-Leuchte 9 FL R B2-Lichtfunktion A 9    not active     20
ENG263456-ENG116047-Leuchte 9 FL R B2-Lichtfunktion B 9    not active     20
ENG263456-ENG116050-Leuchte 9 FL R B2-Lichtfunktion C 9    not active     20
ENG263456-ENG116051-Leuchte 9 FL R B2-Lichtfunktion D 9    not active     20
ENG263456-ENG116054-Leuchte 9 FL R B2-Lichtfunktion E 9    not active     20
ENG263456-ENG116055-Leuchte 9 FL R B2-Lichtfunktion F 9    not active     20
ENG263456-ENG116058-Leuchte 9 FL R B2-Lichtfunktion G 9    not active     20
ENG263456-ENG116059-Leuchte 9 FL R B2-Lichtfunktion H 9    not active     20
ENG263456-ENG260691-Leuchte 9 FL R B2-Lichtfunktion I 9    not active     20
ENG263456-ENG260334-Leuchte 9 FL R B2-Lichtfunktion J 9    not active     20
ENG263456-ENG258156-Leuchte 9 FL R B2-Lichtfunktion K 9    not active     20
ENG263456-ENG259184-Leuchte 9 FL R B2-Lichtfunktion L 9    not active     20
ENG253237-IDE03311-Licht Konfig-Abh„ngig-Emergency braking display    active     4
ENG253237-IDE07470-Licht Konfig-Abh„ngig-After-run for park light    No_sidelights_delay     4
ENG253237-ENG142020-Licht Konfig-Abh„ngig-All-weather light    installed     4
ENG253237-ENG258575-Licht Konfig-Abh„ngig-Diskrete_SBBR_links    installed     4
ENG253237-ENG259588-Licht Konfig-Abh„ngig-Diskrete_SBBR_rechts    installed     4
ENG253237-ENG142191-Licht Konfig-Abh„ngig-Signaturlicht HMI-default Anzeige im Kombiinstrument    not active     4
ENG253237-ENG142190-Licht Konfig-Abh„ngig-Signaturlicht_verbaut    not installed     4
ENG253374-ENG246963-Licht_bedienung-Anzeigezeit_LTM_PopUp1    4.0 s    12
ENG253374-ENG246964-Licht_bedienung-Anzeigezeit_LTM_PopUp1_lang    4 s    12
ENG253374-ENG246965-Licht_bedienung-Beleuchtung_Auto_LED_bei_Nebelfunktion    active     12
ENG253374-ENG246966-Licht_bedienung-Beleuchtung_LTM_Auto_LED_58xt_logik    active     12
ENG253374-ENG246978-Licht_bedienung-Licht_anforderung_FAS    not installed     12
ENG253374-ENG246979-Licht_bedienung-Licht_anforderung_Pilopark    not active     12
ENG253374-ENG246980-Licht_bedienung-Licht_Reaktivierungs_grenze    95 m    12
ENG253374-ENG246981-Licht_bedienung-Lichttastermodul    LTM_Zentraltaste     12
ENG253374-ENG246982-Licht_bedienung-LTM_Anzeige_Config    2    12
ENG253374-ENG246983-Licht_bedienung-LTM_Beleuchtung_Geschwindigkeits_Schwelle    10 km/h    12
ENG253374-ENG246984-Licht_bedienung-LTM_BGL_Geschwindigkeitsabh„ngig    active     12
ENG253374-ENG246985-Licht_bedienung-LTM_BGL_Geschwindigkeitsabh„ngig_Parameter    active     12
ENG253374-ENG246986-Licht_bedienung-LTM_BGL_Wegabh„ngig    active     12
ENG253374-ENG246987-Licht_bedienung-LTM_GlobalOFF_Geschwindigkeitsabh„ngig    active     12
ENG253374-ENG246988-Licht_bedienung-LTM_GlobalOFF_Geschwindigkeitsabh„ngig_Parameter    active     12
ENG253374-ENG246989-Licht_bedienung-LTM_GlobalOFF_Wegabh„ngig    active     12
ENG253374-ENG246990-Licht_bedienung-LTM_GlobalOFF_Zndungsabh„ngig    not active     12
ENG253335-ENG259757-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_A    0    28
ENG253335-ENG261031-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_B    0    28
ENG253335-ENG259460-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_C    0    28
ENG253335-ENG261084-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_D    0    28
ENG253335-ENG260307-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_LF_1    0    28
ENG253335-ENG258132-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_LF_2    0    28
ENG253335-ENG258256-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_A    0    28
ENG253335-ENG260342-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_B    0    28
ENG253335-ENG259281-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_C    0    28
ENG253335-ENG260011-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_D    0    28
ENG253335-ENG260245-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_LF_1    0    28
ENG253335-ENG261364-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_LF_2    0    28
ENG253335-ENG260487-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_A    0    28
ENG253335-ENG260833-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_B    0    28
ENG253335-ENG261075-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_C    0    28
ENG253335-ENG260552-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_D    0    28
ENG253335-ENG260964-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_LF_1    0    28
ENG253335-ENG260937-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_LF_2    0    28
ENG253335-ENG261254-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_A    0    28
ENG253335-ENG259240-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_B    0    28
ENG253335-ENG258653-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_C    0    28
ENG253335-ENG258931-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_D    0    28
ENG253335-ENG259853-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_LF_1    0    28
ENG253335-ENG258582-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_LF_2    0    28
ENG174381-MAS00525-light_control-Trailer turn signal indicator lamp    INDIVIDUAL     4
ENG174381-MAS07990-light_control-Comfort flasher    active     4
ENG174381-MAS07991-light_control-Comfort flasher set point    3    4
ENG174381-MAS10538-light_control-Light rotary sw. connection    Data bus LIN 1     4
ENG174381-MAS12415-light_control-Parking lamp indicator lamp    INDIVIDUAL     4
ENG174381-MAS21315-light_control-Convenience flashing cancellation    active     4
ENG174381-ENG142188-light_control-bewusstes Standlicht    Aktive Begrenzung     4
ENG174381-ENG154711-light_control-PreCrash_RECAS    active     4
ENG174381-ENG126817-light_control-Umfeldleuchte als Manoevrierleuchte    not active     4
ENG174381-ENG142004-light_control-Umgreifende_Heckklappe    not installed     4
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1    active     2
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2    active     2
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3    active     2
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4    active     2
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5    active     2
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6    active     2
ENG126648-ENG260631-LIN-Mirrormode-LIN10    active     2
ENG126648-ENG259894-LIN-Mirrormode-LIN11    active     2
ENG126648-ENG260777-LIN-Mirrormode-LIN12    active     2
ENG126648-ENG258456-LIN-Mirrormode-LIN13    active     2
ENG126648-ENG259488-LIN-Mirrormode-LIN14    active     2
ENG126648-ENG260898-LIN-Mirrormode-LIN7    active     2
ENG126648-ENG259836-LIN-Mirrormode-LIN8    active     2
ENG126648-ENG258319-LIN-Mirrormode-LIN9    active     2
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ    not active     2
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen    40 ms    27
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen    40 ms    27
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit    100 ms    27
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt    10 ms    27
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen    40 ms    27
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen    40 ms    27
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v    1 km/h    27
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen    40 ms    27
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen    500 ms    27
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i    0.04    27
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset    4 øC    27
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p    13.00%    27
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh    110 W    27
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen    40 ms    27
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh    25 Hz    27
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg    0    27
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0    39 øC    27
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1    43 øC    27
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2    47 øC    27
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen    40 ms    27
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus    50 øC    27
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen    40 ms    27
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen    40 ms    27
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen    40 ms    27
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung    60 s    27
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh    60 s    27
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display    not installed     2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Horn operation    Always     2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear wiper    not installed     2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition Switch Key Lock Solenoid    not installed     2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation    not installed     2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button    not installed     2
ENG153728-MAS02790-LIN-SMLS_konfig_2-Diagnosis    not active     2
ENG153728-MAS03758-LIN-SMLS_konfig_2-Not assigned    not installed     2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch    not installed     2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch    not installed     2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn    not active     2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked    not active     2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st    not installed     2
ENG253274-ENG260814-Lock Unlock Taster-Lock_Unlock_Taster_diskret    not active     2
ENG253274-ENG258303-Lock Unlock Taster-Lock_Unlock_Taster_Logik    Rocker sw.     2
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0    0.00%    12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1    5.00%    12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2    50.00%    12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3    75.00%    12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4    110    12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5    126.5    12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0    0.00%    12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1    6.00%    12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2    16.00%    12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3    30.00%    12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4    60.00%    12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5    100.00%    12
ENG253158-LWR Basissoftware    15%    16
ENG253042-IDE03638-LWR Konfiguration-Stationary cornering lamp    ECE R48     8
ENG253042-IDE03644-LWR Konfiguration-Highway light    activated     8
ENG253042-MAS02922-LWR Konfiguration-City light    activated     8
ENG253042-MAS07013-LWR Konfiguration-All-weather light    activated     8
ENG253042-MAS07933-LWR Konfiguration-Eco mode    not activated     8
ENG253042-ENG172238-LWR Konfiguration-chassis_unit    Verbundlenkerhinterachse     8
ENG253042-ENG260425-LWR Konfiguration-Function_activation_LWR    activated     8
ENG253042-ENG174374-LWR Konfiguration-LED_Headlight    activated     8
ENG253042-ENG259430-LWR Konfiguration-LWR_konfig    CAN automatic     8
ENG253042-ENG172241-LWR Konfiguration-lwr_sensors    2_sensors     8
ENG253042-ENG171501-LWR Konfiguration-Market    ECE     8
ENG253042-ENG173009-LWR Konfiguration-offroad_light    not activated     8
ENG253042-ENG172245-LWR Konfiguration-rain_light    not activated     8
ENG253042-ENG174637-LWR Konfiguration-Source_height_value    BCM     8
ENG253042-ENG172240-LWR Konfiguration-steering_curve    normal     8
ENG253084-MDK    0    4
ENG249798-MDK_coding-    0    8
ENG249798-ENG253476-MDK_coding-MDK_bBtle_COV    0    8
ENG249798-ENG253477-MDK_coding-MDK_bExtendedScActivation_COV    0    8
ENG253387-mdk_locking_coding    not installed     3
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet    not installed     8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet    installed     8
ENG122979-ENG141953-Networking-Getriebesteuergeraet    not installed     8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG    not installed     8
ENG124714-ENG142044-OCU-DWA_push    active     10
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare    active     10
ENG124714-OCU-    installed     10
ENG124714-ENG259569-OCU-Remote HuF    active     10
ENG124714-ENG142261-OCU-Remote HuF Abbruch    20 km/h    10
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz    3 Hz    10
ENG124714-ENG260662-OCU-Remote HuF maximale Ausfhrungsdauer    30 s    10
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1    80 s    10
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3    2000 ms    10
ENG124714-ENG125657-OCU-Remote_Unlock_Lock    Via BAP / Fazit     10
ENG253051-ENG258966-Par_AutomatikFKT-AutomatikFunktion_Entfernungsschwelle_Wechsel_Zyklus_IDGeberAbwesenheit_Beschleunigtes_Entry    54 dB    27
ENG253051-ENG260817-Par_AutomatikFKT-AutomatikFunktion_Gueltigkeitsdauer_IDGeber_Authentifizierungsstatus_Beschleunigtes_Entry    5.00 s    27
ENG253051-ENG260526-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Inkrement    1    27
ENG253051-ENG261190-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Schwelle    60    27
ENG253051-ENG258545-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Schwelle_Offset    5    27
ENG253051-ENG258184-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Timeout_Dekrement    60 s    27
ENG253051-ENG260053-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Timeout_Inkrement    10 s    27
ENG253051-ENG258738-Par_AutomatikFKT-AutomatikFunktionen_WechselBeiIDGebernInRuhe_Timeout    30 s    27
ENG253051-ENG258350-Par_AutomatikFKT-Automatisches_Verriegeln_Schwelle_FahrendesFzg    20 km/h    27
ENG253051-ENG260570-Par_AutomatikFKT-Automatisches_Verriegeln_Schwelle_StehendesFzg    10 km/h    27
ENG253051-ENG259977-Par_AutomatikFKT-TemporaereSperrungFuerAutomatikFunktionen_Dauer    2 s    27
ENG253220-Par_Bedienstellen    2    7
ENG253257-ENG259939-Par_Dienste-Beeinflussung_StartStopp_DauerWiederstart    500 ms    18
ENG253257-ENG259005-Par_Dienste-Beeinflussung_StartStopp_Timeout    500 ms    18
ENG253257-ENG259811-Par_Dienste-Bereichsueberwachung_Pilotiertes_Parken_Timeout    120 s    18
ENG253257-ENG261028-Par_Dienste-EntryGoDeaktivierung_ZweiteBedienhandlung_Timeout    5 s    18
ENG253257-ENG261102-Par_Dienste-Innenraumsuche_GueltigkeitFuerExterneFunktionen    10 s    18
ENG253257-ENG258558-Par_Dienste-Paketbotenmodus_Timeout    15 min    18
ENG253257-ENG259702-Par_Dienste-Signalisierungsdauer_Ergebnis_IDGebersuche_ext_Funktionen    500 ms    18
ENG253257-ENG260866-Par_Dienste-SpielschutzFuerDienste_Dekrement_Timeout    60 s    18
ENG253257-ENG260031-Par_Dienste-SpielschutzFuerDienste_Schwelle    10    18
ENG253257-ENG258560-Par_Dienste-VIT_Mindest_Empfangs_Dauer_Betaetigt_Start_Suche    10 ms    18
ENG253386-ENG259497-Par_IDGeberSuche-Innenraumsuche_Kl15_Pause    5000 ms    26
ENG253386-ENG258238-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_FahrendesFzg    20 km/h    26
ENG253386-ENG260811-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_FensterGeschlossen    5.00%    26
ENG253386-ENG258295-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_SADGeschlossen    1%    26
ENG253386-ENG259267-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_StehendesFzg    10 km/h    26
ENG253386-ENG261289-Par_IDGeberSuche-Innenraumsuche_Kl15_Wiederholungen    5    26
ENG253386-ENG260801-Par_IDGeberSuche-Innenraumsuche_verzoegertFFBKomfortschlieáen    3200 ms    26
ENG253386-ENG260447-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Heck_ZeitfensterFuerRasten    500 ms    26
ENG253386-ENG260184-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_SchwelleFuer_FensterOffen    100.00%    26
ENG253386-ENG260557-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_SchwelleFuer_SADOffen    5.00%    26
ENG253386-ENG258851-Par_IDGeberSuche-SignalisierungFunkkommunikation_Vorlauf    0 ms    26
ENG253236-ENG260747-Par_Passive_EntryExit_Toggle-BewussteGesamtEntriegelung    5000 ms    6
ENG253236-ENG281088-Par_Passive_EntryExit_Toggle-TemporaereSperrungFuerExit_Dauer    0.0 s    6
ENG253236-ENG281089-Par_Passive_EntryExit_Toggle-Verriegelungskontrolle_Dauer    2.0 s    6
ENG253347-ENG258202-Par_RSAD-Box2Box_Zuordnung_RSAD_HL    3    20
ENG253347-ENG259350-Par_RSAD-Box2Box_Zuordnung_RSAD_HR    3    20
ENG253347-ENG260315-Par_RSAD-Box2Box_Zuordnung_RSAD_IN    1    20
ENG253347-ENG260967-Par_RSAD-Box2Box_Zuordnung_RSAD_VL    1    20
ENG253347-ENG260395-Par_RSAD-Box2Box_Zuordnung_RSAD_VR    1    20
ENG253347-ENG259213-Par_RSAD-maxAbstand_RSAD_innen_Referenzbox    600 cm    20
ENG253347-ENG258615-Par_RSAD-maxAbstand_RSAD_links_rechts    345 cm    20
ENG253347-ENG260439-Par_RSAD-maxAbstand_RSAD_vorne_hinten    600 cm    20
ENG253347-ENG281104-Par_RSAD-minAbstand_RSAD_innen_Referenzbox    210 cm    20
ENG253347-ENG281079-Par_RSAD-minAbstand_RSAD_links_rechts    105 cm    20
ENG253347-ENG281105-Par_RSAD-minAbstand_RSAD_vorne_hinten    210 cm    20
ENG253347-ENG259498-Par_RSAD-RSAD_UWB_aussen_Entfernung    600 cm    20
ENG253347-ENG260842-Par_RSAD-RSAD_UWB_innen_Entfernung    0 cm    20
ENG253347-ENG289610-Par_RSAD-RSAD_UWB_maxAbweichung    45    20
ENG253398-ENG261340-Par_ScanStrat_RetryHandling-anz_GesamtRetries    1    18
ENG253398-ENG260989-Par_ScanStrat_RetryHandling-anz_RetriesAuthentifizierung    2    18
ENG253398-ENG260903-Par_ScanStrat_RetryHandling-Dynamischer_Anteil_Registering    7 ms    18
ENG253398-ENG259602-Par_ScanStrat_RetryHandling-RetryAuthentifizierung_Entry_UWB    80 ms    18
ENG253398-ENG258787-Par_ScanStrat_RetryHandling-Timeout_Go_Authentifizierungsphase    160 ms    18
ENG253398-ENG260198-Par_ScanStrat_RetryHandling-Wartezeit_Challenge_Retry_Challenge_Entry    6 ms    18
ENG253398-ENG259374-Par_ScanStrat_RetryHandling-Wartezeit_Registering_Challenge_Entry    4 ms    18
ENG253398-ENG261047-Par_ScanStrat_RetryHandling-Wartezeit_Registering_Challenge_Go    35 ms    18
ENG253136-IDE02456-Passive_EntryExit_Toggle-Passive entry right rear door handle    not activated     8
ENG253136-IDE02457-Passive_EntryExit_Toggle-Passive entry left rear door handle    not activated     8
ENG253136-IDE02458-Passive_EntryExit_Toggle-Passive entry frt.pass. door handle    not activated     8
ENG253136-IDE02459-Passive_EntryExit_Toggle-Passive entry driver door handle    not activated     8
ENG253136-IDE02460-Passive_EntryExit_Toggle-Passive exit right rear door handle    not activated     8
ENG253136-IDE02461-Passive_EntryExit_Toggle-Passive exit left rear door handle    not activated     8
ENG253136-IDE02462-Passive_EntryExit_Toggle-Passive exit frt. pass. door handle    not activated     8
ENG253136-IDE02463-Passive_EntryExit_Toggle-Passive exit driver door handle    not activated     8
ENG253136-IDE03178-Passive_EntryExit_Toggle-Unlocking by electr. sliding door    not activated     8
ENG253136-MAS18905-Passive_EntryExit_Toggle-Passive entry via control section rear    not activated     8
ENG253136-MAS18906-Passive_EntryExit_Toggle-Passive entry by rear sensor    not activated     8
ENG253136-MAS18907-Passive_EntryExit_Toggle-Monitoring of locking by pulling door handle    activated     8
ENG253136-MAS18912-Passive_EntryExit_Toggle-Passive exit door handle control section rear    not activated     8
ENG253136-MAS18913-Passive_EntryExit_Toggle-Lock/unlock button on driver door active    not activated     8
ENG253136-MAS18914-Passive_EntryExit_Toggle-Lock/unlock button on front passenger door active    not activated     8
ENG253136-MAS18915-Passive_EntryExit_Toggle-Lock/unlock button on rear driver side active    not activated     8
ENG253136-MAS18916-Passive_EntryExit_Toggle-Lock/unlock button on front passenger side active    not activated     8
ENG253136-MAS18917-Passive_EntryExit_Toggle-Lock/unlock button control section rear active    not activated     8
ENG253136-ENG259242-Passive_EntryExit_Toggle-TemporaerSperrungFuerExit_aktiv    not activated     8
ENG253136-ENG260214-Passive_EntryExit_Toggle-Verriegelungskontrolle_Heck_aktiv    not activated     8
ENG129043-PASSIVE_GO    activated     4
