White MK3 Facelift
STP
Re: White MK3 ex work van
Post by STP »
Ok, got a few things done today, more tomorrow.
Fitted the iSpeed wind deflectors
Next, started putting in my AutoVox wireless camera system
Comes with plug in, and a hardwire kit.
Removed the mirror, mounted the wireless monitor on the mirror stalk ball, superb. Still to fit the camera itself and splice into the reverse lights. I have relays and a power box so may fit that too so I have a low current trigger to the other devices since I also have a radar park assist system to fit if I decide to use both.
The power box is for a boat, has a bank of switches and 12v sockets so the intention is to fit it to the rear and find a live main supply to use for it to distribute as required for rear lights, camera, reversing radar unit etc. One circuit I'll reserve for triggering from the reverse lights.
Tomorrow I'm doing the rear limo tints and wiper delete among other things.
STP
Post by STP »
Also ordered 5mm ply pre cut plates for the bulkhead grilles, going to carpet the cabin side and mat-black the edges and rear face.
Have a white gloss wiper delete kit with a neoprene seal, and carpet to do the rear floor - going to carpet the sides and fit LED down lights in the rear roof panel after carpeting that too.
Tried to fit the Ultinon LEDs in the DRLs but they are twin filament brake & tail bulbs so will use the Ultinons in the reverse lights and get different ones for the DRLs. I also have to collect LEDs for the rear number plate lights (Integrated units)
Also ordered black Turtle roof rails from DSL for him, to be fitted next week when they arrive.
(My wife names my vans, this one is Vinny and he's a boy. Her car is a girl, a Countryman All4, called Mags....)
Javito
Post by Javito »
STP wrote:I might give those a try! Where did you get them from and have you passed an MOT with these? Loads of counterfeit stuff on one online sales platform (not wanting to name them here but I'm sure you can guess)
Not that it's a huge issue to stick regular bulbs in for the MOT of course.
Sorry, I just saw your message. The van had them on already when I bought it but you can get them on Amazon, at least here in France.
As far as I know they're legal and I've passed several french MOT's with them. Also I don't think I'm blinding people. They would definitely let me know if I were.
Also, I read a comment from someone who said he/she was very disappointed with them. I haven't actually tried anything other than factory halogens and I think these are a big upgrade.
STP
Post by STP »
Sounds good, I may try those after all. You never know!
Sokoloosky
Post by Sokoloosky »
Did you test this rear camera ? Can you give some opinion about it ?
STP
Post by STP »
I've tested it on the bench, it works perfectly and links up instantly to the monitor when the camera is powered up, and the picture is superb.
Still to mount and wire the camera, I've been fitting the roof rails and the front privacy panels on the partition.
STP
Post by STP »
So the camera from this AutoVox kit is way too big and obscures the numberplate so it's a bust. Next plan is to fit the mirror monitor I have, over the internal mirror and use a different (smaller) camera. I have a wireless link kit which sends any camera to any monitor or input device which saves running cables through the van. Might get a brake light camera and fit that if I can find a good quality one. Dynamic Sounds have one which looks really good but I grudge paying £90 for a brake light camera...
Post by stu_b »
If there is no cable / wire, how does it get power ??
STP
Post by STP »
Ok, so the video signal is wireless. 2.4ghz between a little transmitter and receiver pair. Tiny little things so easy to conceal inside the rear door panel and above the windscreen or behind the stereo.
Each end needs power and the camera plugs into the transmitter and the receiver plugs into the monitor, whether it's a stereo, mirror monitor etc as long as it has the yellow RCA plug or socket for video composite IN then this works with it.
The transmitter even powers the camera itself so only one connection to 12v power is required at the rear end (use a relay with a diode from Halfords and switch a permanent or ignition live as before) to the transmitter and the camera plugs into it.
Here's a link, just under a tenner https://www.ebay.co.uk/itm/364016035412 ... media=COPY
Fantastic gadget and video quality is superb, super fast to switch on too. No delay. And no wires need to run through the van to the front from the back.
Post by stu_b »
Looks n sounds like a good (and affordable) solution
Do you think you could operate 4x cameras ie N,E,S,W ?
All recordable at the same time ?
Quite like a 360° camera, albeit they would be patched as such and not one continuous image
STP
Post by STP »
You could certainly fit 4 sets of these as each pair take one video signal on an RCA yellow plug if the input device had 4 inputs.
Sent from my moto g34 5G using Tapatalk
Post by stu_b »
Promising
Have yo look more into it
STP
Post by STP »
So now have roof rails on, crossbars and rear blackout tints. Ditched the scabby wheel trims and rocking black steelies. Quite like the look. Went from this:
To this:
STP
Post by STP »
Next installment. Rear camera.
Fitted a camera to the rear door black trim and used my transmitter set to beam to video to the mirror monitor without wires between front and back.
Drilled 1.5mm holes in the rear trim to take 2.3x10 laptop repair screws.
Fitted the camera frame and camera itself
Used sticky cable catchers and dremeled a path for the cable
Installed the transmitter in the door. Used the ignition live and ground from the old wiper plug. This was for testing but I'll use this live for the relay main feed to get power for the camera once completed. The reverse lights will switch the relay on.
Passed the camera cable through the grommet for number plate lights
Buttoned Up
STP
Post by STP »
New brakes going on this weekend. Can't wait. Squealing at low speed braking is driving me nuts.
Got these:
Full brake kit inc. carriers
New back plates
New carrier bolts
New threadlocked Bremtech slide pins
