silraw
Post by silraw »
Adding another 520 litres, talking about Thule box Image great find on market place, it has a crack that already been professionally glued, but maybe in winter season will do a respray to be cosmetic fit for caddy ImageImage
Rodogg13
Post by Rodogg13 »
Hi, all tho I signed up for to this forum about 10 years ago, I’ve never posted. Bit rubbish with tech etc. but as I have now done quite a bit with my van, would b good to get involved. So have had my van fully painted and have now going through the pain of putting it back together. So have been doin things like fitting bumpers (a million times 😂), modifying parking sensors so I can disconnect them to remove bumper, putting interior back together, made custom mirrors, split my lights and painted them black, so much more as well, hard to find the time, but u just have to make the time and get out there even if it’s an hour. Going van will b ready for the road early next year, maybe even ultimate dubs. Then I will b looking into TFSi swap.
@Norcaddymk4 hi mate, it wasn't cheap to get put in, let's say that! Because of the emulator needed to get it working.
Everything works apart from the heating,
Getting that to work is a whole other ball game!!!
the67al
Post by the67al »
Touran door cards installed, everything working and fitting well, also a speaker upgrade, not pretty but a big improvement.
gatebil
Post by gatebil »
Fitted the Caddy 3 Barn door handle to my Caddy 4 and tested the full Project Camper Thermo window covers.
Mk4Murphy
Post by Mk4Murphy »
gatebil wrote: Fri Oct 18, 2024 7:52 pm Fitted the Caddy 3 Barn door handle to my Caddy 4 and tested the full Project Camper Thermo window covers.
Nice work is the handle easy to fit? Plan on doing one myself was going to do lanyard trick but think proper handle looks a lot better
Mk4Murphy
Candy White Mk4 1.6
My Build
https://caddy2k.com/forum/viewtopic.php?t=57570
gatebil
Post by gatebil »
Pretty much. All the fixing points are there and you only have to cut the opening for the handle.
Partnumbers are:
Handle 2K0829309A 9B9
Cover 2K0827699A
3x Screw 1N90940001
Connecting Rod 2K0829323
Clip 7H0827947
Clip 2K0829145
Poffe
Post by Poffe »
Did a modification with no turning back today. Those are always a little bit scarier.
Installed a semi flexible solar panel on the roof.
Chose a panel with the cable coming out on the back of the panel for a neater installation. Still had to make a hole in the roof for it.
Sent from my Nokia 3310
Neat solution.
Nice low profile.
Poffe
Post by Poffe »
petrev wrote:Neat solution.
Nice low profile.
Thx Petrev! Hope it stuck real good with the glue and stays low as well
adeybroth
Post by adeybroth »
Finally got my 18s on Image
Rodogg13
Post by Rodogg13 »
Busy weekend on the van. Had the glass fitted few weekends ago, so first job I got the aerial bolted and connected back up, and roof liner etc. then decide to have a little drive up the road, it’s been off the road 5 years, and managed to blow a pipe off, so parked it back up and changed jobs to a little paint work, and got some of my badges painted up. Last job of the weekend was to modify the rear arch add on piece for the bumper (like the caddy alltrack). As I have a hybrid bumper it is deeper that the standard one, so needed to extend this piece to fit. So got it sized up, hot stables and plastic welded to fix the two pieces together, then filled and 2k primed. So all in all a good weekends work
Poffe
Post by Poffe »
Todays job were more like of the cosmetic kind. Reupholster the inner roof with more of the foam backed suede fabric. The inner roof comes from a caddy maxi life -16.
Poffe
Post by Poffe »
Finally got my newly reupholstered suede head liner in the car. 8/9 clips snapped in nicely with some persuasion. The 9th I probably will have to try to exchange. My girlfriend is very happy not having it in the living room anymore.
All going on again ImageImageImageImage
