davoc220
Ordered a set of wheels, Audi TTRS Concave alloys, 19” just need to see what tyres il put on them when they arrive
- mirogo
Looking good
Happy Christmas everyone
- Flog_TSC
I drove to the canal then smashed 24 miles on my bike and then wonders why I had no boost in the van and seems to have sorted it self out but that’s a problem for another day
Johnjourno
They look really smart!Flog_TSC wrote:Fitted my new wheels![]()
2011 Caddy CR140
2010 Golf GT TDI
2003 Polo Sport PD100
2010 Golf GT TDI
J1MMY
I did what most people do with a new purchase -
Make a list of what needs doing
Make that list a little longer
Remove all POs stickers
Started buying stuff
Illowminati
I ordered all inspection parts, including all belts, as well as some spare parts.
Poffe
Made a custom innerpanel in order to improve the carpet lining over the wheel arc insulation. So far only done the LH side. Will fit this first and evaluate before doing RH side
Sent from my Nokia 3310
Poffe
Got my hands on a set of MK4 Rear lights. Started searching what was needed repinning wise and in the end I came up with this:
(Mind you, i have a LHD van)
At first, all the functions worked, but there were still some fields that didn’t work. But it turned out to be broken bulbs, had nothing to do with the pinning or coding.
Now, how do I get rid of the broken bulb light on the dashboard? From DTVs video I thought the coding would be an easy fix. But in regular fashion when I’m doing something I have a bit of bad luck. Seems like Caddy’s 2010-2015 have a different BCM (09 Central Electric) than pre facelift. Just Ross tech VCDS doesn’t seem to cut it. Any suggestions on what to do?
STP
It seems you can't get rid of the bulb error with VCDS or Obdeleven. Only VCP can do it (Vag Can Pro) and that will ONLY run on Windows 7x32 bit and nothing else (believe me I've tried) and is also dangerously powerful.
You need the kit from AliExpress with the license dongle and then need to watch the videos on installation. Antivirus goes mental when you try to install it, takes nerves of steel and not on a machine you use for internet banking for example.
It does not work in a virtual machine, or windows 10 or 11.
- Flog_TSC
It must be bad luck month or something haha camshaft sensor is giving me problems starting so Cambelt and water pump Orderd and sponsor .Christmas Day I seemd to
Have no boost then after turning the engine off it came back to
Life now an abs sensor needs doing so that was purchased yesterday for today to fit and I’ve cleaned it after the council sticking more salt on the roads than my local chippy has
jakemcc97
Golf MkIV sunglasses holder, straight (not 100% perfect but close enough) fit - 1J0857465
Jake's Caddy Camper Build
Silver 2017 2.0 TDI Highline
davoc220
@jakemcc97
It was transporter holders I fitted in mine, fit perfectly
Well ...
Last week it was wheel speed sensors and ABS plug issues...
And now - Last night the alarm kept going off all the time and I discovered that the battery was almost flat because the coolant fans were going on and off randomly !
Disconnected the battery in order to get some sleep. Reconnected this morning and charged it, and the fans are still turning on full blast randomly.
No idea what could be causing it ?
Any ideas welcome
Any ideas welcome
STP
Do you have any DPF issues already?petrev wrote: ↑Fri Jan 09, 2026 3:49 pm Well ...
Any ideas welcome
