My Mountain Biking Camper Caddy build
shameus
Re: My Mountain Biking Camper Caddy build
Post by shameus »
@papabear thanks for the heads up on those wasn't familiar with either, not sure they're what I'm after but definitely an option!
Papa Bear
Post by Papa Bear »
Black
Marmite lover!!!
VCDS
shameus
Post by shameus »
I was looking at those alright.. nifty little product but my van is a barndoor model unfortunately. The window grills are a nice idea but make it very obvious that someones sleeping inside, which I'm not keen on
Papa Bear
Post by Papa Bear »
Black
Marmite lover!!!
VCDS
Gary.8
Post by Gary.8 »
I used the barn door one like @Papa Bear linked to tell I somehow lost the thing ..
worked well with the windows cracked down level with the heko wind deflectors allowed the air to circulate better. Would definitely get another one.
shameus
Post by shameus »
Nice one boys might try one of those first cause there's no going back on a big hole in your roof! Would be interested to hear what OP thinks of his roof vent all the same
aerobic247
Post by aerobic247 »
shameus wrote:Nice one boys might try one of those first cause there's no going back on a big hole in your roof! Would be interested to hear what OP thinks of his roof vent all the same
I like to crack the front window so they are inline with the wind deflector and turn the roof fan on when I leave my van somewhere hot, don’t fancy leaving the back door partially open
my Mountain Biking Camper build viewtopic.php?f=12&t=24530
VWGilbert101
Post by VWGilbert101 »
Nice build mate, where have you earthed the leisure battery to? cheers
cwdwb65
Post by cwdwb65 »
Word of warning....I done a motorhome conversion for a pal and he'd bought that recycled insultion shown (B&Q?) I tested a piece of it in water and it soaked it up. Against my advice he insisted on just using it anyway but suspect it will do the same to any moisture between panels and will all end in tears.
aerobic247
VWGilbert101 wrote: Sat Jul 25, 2020 9:31 pm Nice build mate, where have you earthed the leisure battery to? cheers
one of the bolts of the passenger seat
aerobic247
cwdwb65 wrote: Mon Jul 27, 2020 4:00 pm Word of warning....I done a motorhome conversion for a pal and he'd bought that recycled insultion shown (B&Q?) I tested a piece of it in water and it soaked it up. Against my advice he insisted on just using it anyway but suspect it will do the same to any moisture between panels and will all end in tears.
no shit Sherlock, you immersed something in water and it got wet?
and of course moisture will get in to the insulation if you don't install a vapour barrier
cwdwb65
Post by cwdwb65 »
aerobic247 wrote: Mon Jul 27, 2020 4:40 pm no shit Sherlock, you immersed something in water and it got wet?
There's always one SA who's PM and has far too much to say even when others are only trying to be helpful for those who are novices. For those of you who aren't going the full hog and putting in sealed vapour barriers...alI I was trying to highlight is that type of insulation will just soak up ANY moisture and RETAIN it....dont use it and simply get the correct stuff from the outset. Wind your neck in and stop putting off others who are eager to help....if youve nothing nice to say don't say anthing at all.
Hodgie2k
Post by Hodgie2k »
aerobic247 wrote: Sat Sep 26, 2015 5:52 pm Pulling out the plywood so i can sound deaden the van
Would you say the sound deadening makes a big enough difference? Carpeting the back of mine out soon as was wondering weather or not to bother
Dwalton12345
Post by Dwalton12345 »
Loving this build! I've recently bought a caddy already converted. Looking to do the Nc500 soon needs a few little details sorting and fixing but your build has gave me some motivation ha ImageImage
Sent from my SM-N976B using Tapatalk
IainH91
Post by IainH91 »
Got any better pictures of the battery box?
