Toffee delights
- dan@biali
Re: Toffee delights
That was going to be my next question! Wondered if you had seen the v fabric.
You can create your own fibre lock by using a light dusting of easy composites spray adhesive. It can be helpful when you’ve got a tricky transition and makes the fabric behave a bit like a prepreg.
Still, you’re getting great results doing it your way and often with this that’s part of the battle. I wondered if you’d benefit from a vacuum pump but I’ve found that the challenge is building a support structure to stop the part getting crushed.
When you see how much people charge for this, most people exclaim “how much???!!!” whereas I go, how are they making a profit!
- Lister79
Toffee delights
Totally agree there Dan, I honestly don’t know how people can make a living doing it full time. Must be doing a hell of a lot of parts.
Van dropped off at the bodyshop this morning
, not the best look it’s had…
Wassy78
Re: Toffee delights
Only just joined and love this van I've message few times on Instagram
snuffegull
Re: Toffee delights
Really going all in on the carbon! Gonna be interesting to see this back togehter after paint!
- Lister79
Re: Toffee delights
@Wassy78 good to see you’ve joined, get a build thread started.
@snuffegull so am I. Looking forward to getting it back from the bodyshop and building it back up.
Another batch of parts ready for wet sanding and polishing. B-post trims, side moulding trims, rear bumper diffuser and rear bumper protector. I ran out of the V-groove material (wasted loads
) and with non available I had to do the diffuser in 2 parts. Obviously doesn’t look as neat as the one piece fabric but I’m pleased with how it turning out.
Lacquer applied ready for wet sanding/polishing
Rubbed down ready to apply the base coat
base coat applied
Material added
First layer of epoxy applied
3 further layers of epoxy applied (after rubbing down first)
) and with non available I had to do the diffuser in 2 parts. Obviously doesn’t look as neat as the one piece fabric but I’m pleased with how it turning out.Lacquer applied ready for wet sanding/polishing
base coat applied
Material added
- brooneye
Re: Toffee delights
Vans looking unreal buddy, don’t know how you keep coming up with all the ideas
Wassy78
Re: Toffee delights
Yeah will do mate as I've now started mine just need to read the how to upload pics
- Lister79
Re: Toffee delights
Last batch of Carbon skinned parts lacquered tonight. Complete wing mirrors, side repeaters and the fuel cap done. Tried something different with the cap because I had concerns about the lock getting stuck with epoxy, not sure about it so will see if it lasts.
Only external plastic part visible on the van now is the wiper trim, I’ll most likely have a go at it when I get the van back.
Dreading all the wet sanding and polishing
In work
In work
- Sean1066
Re: Toffee delights
Looks awesome buddy.
And once again it’s show quality
Jirka
Re: Toffee delights
unreal
- hef355
Re: Toffee delights
Carbon work looks top notch as with everything you do Chris!
Can I ask what lacquer you’re using buddy?
- Lister79
Toffee delights
Thanks all, much appreciated.
I use the Churchill brand 2K Crystal Clear anti scratch lacquer (2:1 with 10% thinners). I’ll be honest I’m definitely not a painter, and don’t know if that’s a good or bad lacquer but I’m happy with the results.
- hef355
Re: Toffee delights
Results look great Chris considering Churchill is a cheaper brand. I’ve used it many times but when you start using ppg and sikkens clear coat you see a difference then.
Fair play mate, awesome job and really impressive
Re: Toffee delights
Parts look amazing, hope you get your van back soon so you can tackle that unmodified wiper trim.
- Lister79
Re: Toffee delights
Thanks lads.
Collected the van tonight, so I’m currently a very happy man. No overspray and still have the original engine bay color/paint, which was my main concern. Needs a good clean to get rid of all the dust, as a quick blast off didn’t really do much.
Refit the harness surrounds to the seats that I’ve had painted, rebuilt the grill with painted insert and new VW badge, and put the fuel cap back on. Hopefully get stuck into putting it back together this weekend.
