Toffee delights
Lister79
Toffee delights
Post by Lister79 »
It’s been a while since I added the full mod list to the thread and as I’ve recently updated it for the insurance I thought I’d add it.
I often forget just how far it’s come. I think it’s because with using it so much I become blind to it, I need to find a stock toffee one to get some photos Image.
Anyway mod list below:
Base van:
2014 Toffee Brown 1.6 TDi Trendline.
Engine Bay:
Custom Audi S3 Engine cover with 034 Motorsport Carbon fibre over cover.
Funk Motorsport gold heat shielding and multiple gold and Carbon fibre cable heat sleeves.
Racingline Billet Coolant reservoir cap.
ECS Carbon fibre coolant bottle cover.
Racingline Billet Screen wash Bottle cap.
Racingline Billet Dipstick, oil filter housing and filler cap.
MK4 Caddy Screen wash bottle.
Screenwash level sensor.
Heated Carbon fibre skinned washer jets.
Polished MK4 Caddy Air conditioning pipes with Carbon fibre skinned mounting clamp.
MK7 Golf Dual tone horn.
Genuine Bonnet sound deadening (Silent coat also applied).
Rival steel under tray.
MK5 Golf wiper nut covers and scuttle panel bungs.
Carbon Fibre bonnet lift strut.
Carbon fibre skinned headlight fillet plates.
Carbon fibre skinned slam panel.
Carbon fibre skinned bulkhead corner plates.
Carbon fibre skinned timing chain cover.
Carbon fibre bulkhead plate (full composite part).
Carbon fibre skinned Wiper scuttle panel
Carbon fibre skinned fuse box.
Carbon fibre N/S/F cable tray
Carbon fibre skinned starter motor cover.
Carbon fibre skinned battery box.
Carbon fibre skinned dipstick tube
Carbon fibre radiator cover
Carbon fibre fan pack cover.
Carbon fibre skinned coolant pipes (x3).
Carbon fibre skinned Alternator cover
Carbon fibre throttle housing covers.
Carbon fibre brake fluid reservoir
Carbon fibre skinned battery tray.
Polished Alternator.
Polished engine mount and cradle.
Engine and Gearbox:
EA888 Gen 3 engine conversion (CJX engine code from 2015 Golf R).
Littco L380X Turbo.
Funk Motorsport Turbo Blanket.
Ramair Turbo Elbow.
Ramair Turbo muffler delete.
GFB DVX Blow off valve.
BCS Powervalve 100 cell Catalytic Converter downpipe with V-banded exit.
Funk Motorsport Carbon Heat wrap on downpipe and mid-section.
CSK Race exhausts custom 3” Stainless steel V-banded cat back exhaust system with 3.5” titanium pie cut down swept tail pipe.
Uprated Darkside developments S3 Intercooler with 70mm inlets.
Creation Motorsport hard pipe kit and silicone pipes.
Darkside developments Intercooler charge pipes.
Genuine Audi RS7 spark plugs.
APR red ignition coil’s.
APR Carbon intake pipe.
APR open Carbon intake kit with custom made Carbon fibre skinned intake duct and Carbon fibre skinned mounts.
Genuine VW petrol Caddy fuel tank with custom hybrid 2017 Caddy/Audi TTRS Low Pressure Fuel pump.
Rolling road tuned by Uber tuning to 417.5BHP /545Nm
6 speed SQZ code gearbox (from 2017 Scirroco).
RTS Twin plate Clutch
Forge Motorsport adjustable quick shift kit (both throw and side).
48 Draft Designs gear selector cable bushes.
HEL Performance Clutch Bleeder Block.
HEL braided Clutch hose.
Suspension and Chassis:
Grinds G1 air suspension management system with Bluetooth module, fully hidden system with twin Grinds competition compressors housed within enclosure on custom underslung mounting plate,
2 Airlift auto drain water traps, 1 Grinds manual drain water trap,
3 gallon MOA seamless tank,
2 SMC AK2000 check valves and stainless steel fitting throughout.
ABP air suspension front struts.
Whiteline 24mm adjustable front antiroll bar.
Whiteline adjustable front antiroll bar drop links.
Aluminium subframe with Deadset kit fitted.
034 Motorsport Dog bone bush.
Full Powerflex anti lift and black series poly bush kit in Passat aluminium lower arms.
Superpro adjustable ball joints.
MK5 Golf GTi Aluminum subframe.
ABP air suspension bags and split leaf springs.
Bilstein rear shocks.
Axle flip with Retrofication weld on saddles and ABP hanger kit.
Rear hanger blocks.
Relocated antiroll bar.
Powder coated rear axle.
Whiteline 24mm adjustable rear antiroll bar.
Powerflex Black series bush kit in rear springs and chassis mount.
Chassis fully sealed with Dinitrol Metallic and all components powder coated/repainted.
Brakes:
Brembo 18Z front Callipers (painted yellow) with PW Motorsport mounting kit.
Golf R32 disc backing plates.
352mm ECS Tuning 2 piece Drilled and Grooved discs with Brembo pads.
HEL Braided brake hoses.
Custom Dual rear calliper setup with Brembo 4 pot callipers (service brake) and Golf R32 callipers (handbrake), Both painted yellow with 310mm ECS Tuning 2 piece Drilled and Grooved discs.
HEL braided brake hoses.
Body:
Hybrid MK7.5 Golf GTi front bumper with genuine LED fog lights.
Genuine Oettinger lower front spoiler and splitter.
Carbon fiber skinned lower grill.
Carbon fibre skinned air deflectors/ grill locks.
Carbon fibre skinned bumper trims.
Carbon Fibre skinned Touran front grill.
MK4 Caddy Alltrack rear bumper smoothed and painted with Carbon fibre skinned lower diffuser.
Carbon fiber rear bumper protector.
Custom Carbon fibre skinned Touran/Caddy wing mirrors with puddle lights and dynamic indicators.
Edition 30 Side mouldings with Carbon fibre skinned top strips.
Edition 35 style side skirts.
Caddy Alltrack lower door trims, smoothed and painted.
Modified Vanstyle MK4 Caddy arch kit.
Rear spoiler.
Painted number plate light handle.
Side rail cover (with correct rail).
Carbon fibre skinned rear VW Badge with painted backing.
Custom EM Tuning Bi-Xenon headlights with twin honeycomb etched projectors.
Carbon fibre skinned MK4 Caddy side repeaters.
MK4 Caddy rear light units with LHD version fit to driver’s side.
HEKO Wind deflectors.
Scirocco bonnet catch
Carbon fibre skinned external B-post trims.
MK4 Caddy (16” wheel), rear wheel arch liners (with spray flap) modified for extra clearance.
Caddy Life front wing sound deadening.
Carbon Fibre skinned rear light trims.
Carbon Fibre skinned rear door latches and release handle.
Carbon fibre skinned fuel tank cap.
Custom made Carbon fibre mud flaps.
LED Bulbs throughout.
14” 4D gel number plates.
Interior:
Fully sound deadened and insulated (front and back).
Rear fully carpeted in Anthracite carpet (with ply panel inserts).
USB charging point in rear.
Coffee Ash real wood flooring in rear.
Armour plates on rear doors.
Rear door interior release handle.
Touran rear seat conversion fully heated and reupholstered in Bridge of Weir Leather with Golf GTD Tartan centres and suede trimmed plastics.
Touran Carpets (front and Rear).
Rear under seat floor vent covers.
Touran seat bases trimmed in suede.
Heated Recaro R32 Wingback front seats reupholstered in Bridge of Weir Leather with Golf GTD Tartan centres and Suede trimmed plastics (wired with stans loom).
Touran Dashboard upholstered in Bridge of Weir leather and suede.
Premium 3D colour instrument cluster with facelift Scirroco dial foils in a custom Scirroco facia surround.
Scirroco additional gauge cluster mounted in custom made suede trimmed housing.
Custom facelift Touran centre vent housing with Tiguan Hazard switch.
Full Touran Climatronic heater/air conditioning system with late model control unit.
Custom heater control surround with MK7 Golf satin chrome button trim.
Can bus controlled PTC heater with original VW loom.
Caddy life sliding door interior panel upholstered in Bridge of Weir Leather, Golf GTD Tartan and suede.
Custom made drivers side rear panel upholstered in Bridge of Weir Leather, Golf GTD Tartan and suede.
Oracol wrapped dash trims.
Shadow chrome door catch covers
Facelift Touran side vents.
Facelift Touran ESP switch unit (satin chrome trimmed).
Touran centre console with custom made sliding tray, trimmed in suede with armrest trimmed in Bridge of Weir leather.
Handbrake trimmed in Bridge of Weir leather with satin chrome release button.
Yellow Seatbelts (front and rear).
MK7 Golf GTi gearknob with shortened lever and Bridge of Weir leather gear lever cover.
MK5 Golf GTi foot pedals.
MK7 Golf R flat bottom MF steering wheel, reupholstered in perforated Leather and Suede with yellow stitching and centreline.
XHorse steering wheel module.
MK7 Golf hybrid indicator/wiper stalks.
Passat W8 interior light.
Auto headlights.
White LED door and floor courtesy lighting (door open).
Red ambient floor, dash and door pocket lighting (front and back).
Touran front Door panels, reupholstered in Suede with Bridge of Weir leather armrests and top sections, with Golf GTD tartan door centres.
Satin Chrome Touran Door handles.
Touran Satin Chrome mirror switch.
VW Beetle Satin chrome tipped window switches.
Audi A8 door handle lighting diffusers (red).
Genuine VW Bulkhead delete B post trims trimmed in suede.
Front headlining tray trimmed in suede with fibre optic star lighting.
Bulkhead delete B-post covers land sill trims trimmed in suede.
A pillars, roof lining & roof trims all retrimmed in Suede.
Custom rear roof lining trimmed in suede with fibre optic star lighting and additional LED roof lighting (on separate switch).
Custom made lower rear door panels trimmed in Tartan and suede.
Audison APK165 speakers in front doors and tweeters in dashboard.
Alpine 6x9’s installed under front seats.
RNS510 DAB (Navigation) head unit with reverse camera.
Genuine VW Touran carpet mats (front and rear).
Genuine VW rubber mats (front only).
Wheels:
20” Custom forged 2 piece wheels (8.5”wide ET48). Ceramic polished and gold tint lacquered centers, Ceramic polished rims with silver powder coated barrels.
Continental Contact Sport 6 tyres (225/30 20).
or
20” Genuine Audi A6, original silver (8.5” wide ET43).
Falken tyres (225/30 20).
Self levelling Audi wheel centres.
or
20” OZ Superturismo Dakar, silver (8.5” wide ET45).
or
19” Genuine Mercedes AMG, powder coated in BMW Ferric Grey with diamond cut faces and powder lacquered, (8.5” wide ET44).
Goodyear Eagle F1 Asymmetric tyres (225/35 19).
Custom made self levelling wheel centres.
RacingLine Wheel stud conversion
ABS based tyre pressure monitoring.
Security:
Yes Image
Dav02
Re: Toffee delights
Post by Dav02 »
Security yes :lol: very wise ;)
Also, think someone needs to sell a set of wheels or two????
2016 Caddy Highline. 2.0 TDi 102ps (ReMapped to 180)
Build Thread
Re: Toffee delights
Post by stu_b »
I certainly hope your Mrs never sees that list 😆 💰 😆 💰 😆 💰 😆
So tell all, what's your security to protect all that
A rottweiler with an attitude that lives in the car ?
Lister79
Toffee delights
Post by Lister79 »
Sell a set…! How very dare you Dav. . As you know Dav a couple of sets aren’t too pretty at the minute, so would be a bit pointless.
she isn’t daft.
Secured by lions and tigers and bears.
Re: Toffee delights
How you remember that list is beyond me! I can’t even remember some of the things I’ve done to mine and I’ve done nothing compared to you!
Lister79
Toffee delights
Post by Lister79 »
MOT time, and another clean entry on its history. 5th MOT in my ownership, 7th in total. Can’t believe it will be 10 year old this time next year. Image
Gmancan1
Re: Toffee delights
Post by Gmancan1 »
That list how do you keep track suppose this helps 🤣😂
Sabbunsingh
Re: Toffee delights
Post by Sabbunsingh »
When u think this van can not get any better, you find something to make more awesome. Love the attention to detail. Bravo
When does this ever stop!!
Lister79
Re: Toffee delights
Post by Lister79 »
@Gmancan1 yeah everything that’s done to it is documented on this forum, plus I do try to keep the list relatively up to date as it just makes things easier for insurance renewals.
@Sabbunsingh that’s very much, just trying to make it perfect for me and what I use it for.
Re: Toffee delights
That's some mod list, took me 4 cups of tea to read through it. Love the recent shots of your van.
Lister79
Toffee delights
Post by Lister79 »
ImageImage that must have been to keep you awake. Cheers mate, just a shame it’s back to my boring photos of general maintenance and cleaning.
Started trying to get the van clean and ready for Tatton Park show. Wheels off and all the brakes, suspension and wheel arches cleaned. Wheels took a bit of cleaning as the barrels and fixings were black with keeping the wheels on for daily duties, I don’t think I’ll be doing that again.
Hopefully get some dry nights this coming week to get the paint work washed off and some wax on Image
Gmancan1
Re: Toffee delights
Post by Gmancan1 »
Still looks good in “boring pics” 😂😂
supercaldo
Re: Toffee delights
Post by supercaldo »
Incredible build 👏🏻 My thumb was getting sore scrolling the spec list, some amount of work has went in to this. And the three “or” for the wheels made me laugh, quite the collection!
Lister79
Re: Toffee delights
Post by Lister79 »
Thanks both.
Spent the morning dodging showers, and turning my fingers black re-polishing the metal work and cleaning the engine bay. That’s the two worst, but most satisfying jobs done ready for next weekend.
Re: Toffee delights
That looks immaculate mate
