Daily: 2016 Volkswagen Caddy Panel Van 2.0tdi Dsg Stage 3 plus (Stripped and Sold)
- Chris_Fz
Re: Daily: 2016 Volkswagen Caddy Panel Van 2.0tdi Dsg Stage 2Plus
Had some left over carpets.
So ended up cutting some circles out. For the cup holders
Sent from my SM-S908E using Tapatalk
-Vw Caddy Pv 2.0TDI 2015 stage 2 + 110wkw / 376nm -
-Nardo Grey & Black Trim
-Rolling on 19" A-line Hostiles
-Owner of Retrofitters
-+2771 027 5064-
-+2771 027 5064-
- Chris_Fz
The Darkside Intake hose had one flaw
Did not come with a turbo inlet coupling.
So got one made.
Now this intake won't pop off. Or slide off.
So got one made.
-+2771 027 5064-
-+2771 027 5064-
Brilliant, brilliant, brilliant
Looks amazing.
Top read.
Can you give a bit more info on any mods required to fit a LIFE slider to a std. Van. I'm sure there will be others interested too...
Pete
Looks amazing.
Top read.
Pete
- Chris_Fz
Door needs to be trimmed 10 to 13mm by the window area.petrev wrote:Brilliant, brilliant, brilliant
Looks amazing.
Top read.
Pete
That's it.
Rest is bolt on
-+2771 027 5064-
-+2771 027 5064-
- Chris_Fz
Digital cluster is in.
Next is keyless start .
-+2771 027 5064-
-+2771 027 5064-
- fishynos72
Looks fantastic- does the column trim piece not fit into the new cluster housing?
I'll be watching this - Years ago I looked into retrofitting into my mk5 golf- at the time I found so much of the retrofit was still unknown and decided against it.
- Chris_Fz
The trim is for a Tiguan mk1.fishynos72 wrote: Looks fantastic- does the column trim piece not fit into the new cluster housing?
So will work in making it fit more oem
-+2771 027 5064-
-+2771 027 5064-
- Raph71
Yes, comfort is essentially linked to the springs and shock absorbers.
But mounting more rigid brushes could bring additional vibrations. My question was related to these vibrations. Find out if they were more important.
regarding handling, the polybruschs must necessarily improve things because it is the excessive flexibility of the original parts that gives these completely disordered movements of the rear wheels.
I am looking at this subject how to reduce these movements by having a part machined that would block the rear spring supports on the rear cross member of the body, but I am worried about the vibrations that this would cause because we end up with a system without silentblock .
Some very nice touches on that. A good read
- Chris_Fz
Thank uRhinopower wrote:Some very nice touches on that. A good read
-+2771 027 5064-
-+2771 027 5064-
- Chris_Fz
Thank u kindlyMrl wrote:Awesome van!
-+2771 027 5064-
-+2771 027 5064-
- Chris_Fz
Rear floor mats got some love.
Clips fitted .
Looks much neater
Clips fitted .
Looks much neater
-+2771 027 5064-
-+2771 027 5064-
- Chris_Fz
Re: Daily: 2016 Volkswagen Caddy Panel Van 2.0tdi Dsg Stage 3 plus
Aluminum radiator core to go in
-+2771 027 5064-
-+2771 027 5064-
