Mr. P
Post by Mr. P »
Mine have been on order since the 8th
PodgeyPerfections
paul4314
Post by paul4314 »
Oh shouldn't be long then u will probably get a text soon saying
U have a parcel booked for interlink
Then u no it will be there the next day
Strath25
Post by Strath25 »
Got some spare time so got round to fitting my RNS 315, Passat W8 interior lamp with Bluetooth mic housing and mk6 Golf seats I was donated (do the job meantime)
Over the moon it all works together and shows all info on the highline cluster and fully controlled by the steering wheel Image
Gibbo
Post by Gibbo »
If you have vcds you can change the display to having a side loading door and not opening door like you have at moe !! I've done mine just got to search how to, cause I can't remember
Strath25
Post by Strath25 »
Yeah I was hoping someone could help with that as my friend has vcds
Gibbo
Post by Gibbo »
Strath25 wrote:Yeah I was hoping someone could help with that as my friend has vcds
ok so what do you need just instructions on how to ?!
Neo
Post by Neo »
paul4314 wrote: All fitted now
And if anyone is interested in getting new rear shocks
I would highly recommend these
They are well worth the money and smooth as silk to
I quite fancy a pair of these. Are they the shortened shock for lowered Caddys?
What did you order exactly?
Strath25
Post by Strath25 »
Gibbo wrote:ok so what do you need just instructions on how to ?!
Yeah basically where and what to change Image
Gibbo
Post by Gibbo »
Strath25 wrote: Yeah basically where and what to change Image
ill see if I can find instructions mate
paul4314
Post by paul4314 »
Hi yea they are shorter for the lowered caddy they should be able to make full length if needes as they
Are made to order
And u just need to contact them and they will ask for details of your van
And weather it's lowered
Geraout
Post by Geraout »
Tried the VW seat covers but found them to be a bit uncomfortable in hot weather so to protect the seats in my new van I swapped them for a pair of older style leatherette trimmed ones which seem a lot more robust than the original ones.
Seems a bit extravagant but the seats were actually £30 less than the seat covers were and in excellent nick!
Adam87
Post by Adam87 »
Fitted new rear lights all wired in and working will get some pics up later
shizzle2000
Post by shizzle2000 »
Friday whilst still on my camping holiday and next to the tent I got the insulation fitted. What an exercise in tedium. I used about 35m2 of double foil bubble wrap with the would be window areas 8 layers thick and in the doors and above the rear wheel arches about 4 to 6 layers.
Pain in the ass and like everything else it's just as you finish you get the nack.
shaunmods
Post by shaunmods »
Adam87 wrote:Fitted new rear lights all wired in and workingImage will get some pics up later
Looking forward to seeing some pics Adam :D
Neo
Post by Neo »
Are made to order
Thanks. Now on my list :)
