Emac152
Post by Emac152 »
Fitted led lights in the back and door lights just need to get them coded. Can anyone let me know how this is done?
S.w.blackwell
Post by S.w.blackwell »
Fitted engine under tray.
All adding up to a quieter caddy!
Steve
Sitys
Post by Sitys »
Little trip to south lakes, to collect these..ImageImage
Pleased with my bargain...
islander
Post by islander »
Bought an used roof box, when both seats are in there are not much room left, about a foot in the trunk, i just fit the Chicco Lightway Stroller (if yo take of the front wheels)..
"Cute" was the word my oldest daughter called it.
rsjohn
Post by rsjohn »
shizzle2000
Post by shizzle2000 »
AdCNC wrote:I modified my axle brackets to pull the wheels back in line. Took about 40mins to take them off re machine them and pop them back on. Heres a pic of my beautiful assistant holding the bottom clamp with the elongated clearance hole i had just machined in. Image and heres a pic of the other being machined out on the mill. Image
This way saved me adding an extra chunk of steel and lowering even further. Keep it simple i always say Image
Hello going to order my suspension asap. Can you tell us in bit more detail what you have done what you have used and why its necessary? Ta james.
AdCNC
Post by AdCNC »
Sure. In the rear lowering kit there is 3 plates one with two welded scollops on to locate onto the axel, this you do not modify! The other two plates i modified as to pull the axle back in line. The plate you see in the picture is the bracket that sits underneath the axle and spring (very bottom clamp) the hole in this is just a clearance hole to allow the centring pin in the spring to locate in the upper plate. Now the other plate i have not pictured comes from factory with a single 15mm hole in to allow the spring to locate. As i needed to move the axle back 15mm i drilled an hole off to one side of the original hole for the locating stud to drop in.
If it ain't broke, brake it and make it better :P
www.protocnc.co.uk
Alan1572
Post by Alan1572 »
Took my caddy back to stereo installer after they somehow broke the heater fan ( temporarily I hope)
drw42
Post by drw42 »
rsjohn wrote:ImageImage
qu'Est-ce que c'est and Combien der what is it i.e. part number and how much. Looks great Cheers Woody
Dan21
Post by Dan21 »
Washed the Caddy after a week of commuting up and down country roads in the rain... Much better now!
ksink
Post by ksink »
hey all,
new around here. yesterday I bought my maxi life 1.9 tdi. Hope i can learn a lot from all of you!
maxx007at
Post by maxx007at »
Started to put some plywood in on the passengerside:
In case anybody is wondering, the white plate is for my trailer, and the black boxes are from an ECS towbar wiring kit.
Next step is the driversside.
Tiguan 5N2 (2.0 TSI (CCZD) 4Motion, REMAP 158 KW/211PS)
Ex Caddy 2k (e.o.2004) (1.9 TDI(BJB), REMAP 103KW/145PS) Ravenna Blue
drw42
Post by drw42 »
Alan1572 wrote:Took my caddy back to stereo installer after they somehow broke the heater fan ( temporarily I hope)
I did the same when I fitted the stereo myself. Blew a fuse which is located in the fuse box under the bonnet.
drw42
Post by drw42 »
Posted an update at viewtopic.php?f=13&t=18091&start=60
portholes Image
danglers Image
and sticks Image
cheers Woody
skidmark
Post by skidmark »
Fitted some extra USB outlets in each side, was only just deep enough to clear.
2018 Trendline 1.0 Petrol
