Page 190 of 1073
Posted: Fri Jul 31, 2015 6:34 pm
by Emac152
Fitted led lights in the back and door lights just need to get them coded. Can anyone let me know how this is done?
Posted: Fri Jul 31, 2015 8:38 pm
by S.w.blackwell
Fitted engine under tray.
All adding up to a quieter caddy!
Steve
Posted: Fri Jul 31, 2015 9:28 pm
by Sitys
Little trip to south lakes, to collect these..
Pleased with my bargain...
Posted: Fri Jul 31, 2015 9:36 pm
by islander
Bought an used roof box, when both seats are in there are not much room left, about a foot in the trunk, i just fit the Chicco Lightway Stroller (if yo take of the front wheels)..
"Cute" was the word my oldest daughter called it.
Posted: Fri Jul 31, 2015 11:27 pm
by rsjohn
Posted: Sat Aug 01, 2015 7:20 am
by shizzle2000
AdCNC wrote:I modified my axle brackets to pull the wheels back in line. Took about 40mins to take them off re machine them and pop them back on. Heres a pic of my beautiful assistant holding the bottom clamp with the elongated clearance hole i had just machined in.
and heres a pic of the other being machined out on the mill.
This way saved me adding an extra chunk of steel and lowering even further. Keep it simple i always say
Hello going to order my suspension asap. Can you tell us in bit more detail what you have done what you have used and why its necessary? Ta james.
Posted: Sat Aug 01, 2015 9:58 am
by AdCNC
Sure. In the rear lowering kit there is 3 plates one with two welded scollops on to locate onto the axel, this you do not modify! The other two plates i modified as to pull the axle back in line. The plate you see in the picture is the bracket that sits underneath the axle and spring (very bottom clamp) the hole in this is just a clearance hole to allow the centring pin in the spring to locate in the upper plate. Now the other plate i have not pictured comes from factory with a single 15mm hole in to allow the spring to locate. As i needed to move the axle back 15mm i drilled an hole off to one side of the original hole for the locating stud to drop in.
Posted: Sat Aug 01, 2015 11:37 am
by Alan1572
Took my caddy back to stereo installer after they somehow broke the heater fan ( temporarily I hope)
Posted: Sat Aug 01, 2015 12:58 pm
by drw42
qu'Est-ce que c'est and Combien der what is it i.e. part number and how much. Looks great Cheers Woody
Posted: Sat Aug 01, 2015 1:32 pm
by Dan21
Posted: Sat Aug 01, 2015 1:53 pm
by ksink
hey all,
new around here. yesterday I bought my maxi life 1.9 tdi. Hope i can learn a lot from all of you!
Posted: Sat Aug 01, 2015 2:47 pm
by maxx007at
Started to put some plywood in on the passengerside:
In case anybody is wondering, the white plate is for my trailer, and the black boxes are from an ECS towbar wiring kit.
Next step is the driversside.
Posted: Sat Aug 01, 2015 3:39 pm
by drw42
Alan1572 wrote:Took my caddy back to stereo installer after they somehow broke the heater fan ( temporarily I hope)
I did the same when I fitted the stereo myself. Blew a fuse which is located in the fuse box under the bonnet.
Posted: Sat Aug 01, 2015 3:46 pm
by drw42
Posted an update at
viewtopic.php?f=13&t=18091&start=60
portholes
danglers
and sticks
cheers Woody
Posted: Sat Aug 01, 2015 6:39 pm
by skidmark
Fitted some extra USB outlets in each side, was only just deep enough to clear.
