mkvanman
Well where do I start service,new front & rear shocks + drop links,cv joint & top mount.Done 356500 miles
page two new cam shaft/followers,head skim,rebuilt injectors & followers + sundries Done 265000 miles
= EMPTY WALLETT but this is my working caddy.
mkvanman
Forgot rear pads.
ant466
How did you do your rear lights like this? and were do you get the wrap from? think it looks well nice!Tommy2k wrote:New member had the van 4 weeks. 64plate 1.6tdi. Lowered on joms and put my new wheels on yesterday. Just needs more lows now.
Today I wrapped the rear lights
Tommy2k
Just got some red tint from eBay stuck it on cubit down then got heat gun for edges mate
ant466
Just ordered me some filmTommy2k wrote:Just got some red tint from eBay stuck it on cubit down then got heat gun for edges mate
Tommy2k
Wont stick round corners so just pit heat gun on.for few secs and shrivels up around thete
- Caddyslack
Nice wheels! What make and size are they?
Our Super Family Car
1.9TDI (BLS) @ 162Hp&360Nm - 5-Speed gearbox (GQQ) - 18" OEM Bristol wheels - Golf MK7R front brakes -Premium cluster - Offroad Grey metallic
billstein9
Do your indicates still look amber/yellow when on and does your reverse light now look pink? Ive wanted to do this mod since I bought my van but cant bare the thought of having to take the lights back in and out if the indicators aren't the right colour ( read as I would sell my van before having to fit the plastic cover back for no reason!)Tommy2k wrote:Just got some red tint from eBay stuck it on cubit down then got heat gun for edges mate
Tommy2k
Yeah reverse light it pink and the indicators are slight pink to mate
billstein9
Correct me if im wrong, I haven't worked on my caddy stereo yet, but don't you just need to relocate the red (positive) wire in the connection block rather than wiring it up to the fuse box? This is what I have done for my other VWs historically.aerobic247 wrote:You will have two power feeds a yellow (permanent live) and a red (ignition live) the red cable will have to be connected to the fusebox via an add-a-fuse cable
Hindsight is a wonderful friend but he's always late !
- maxx007at
If there were a ignition live in it that would work. Mine only has 1 permanent livebillstein9 wrote: Correct me if im wrong, I haven't worked on my caddy stereo yet, but don't you just need to relocate the red (positive) wire in the connection block rather than wiring it up to the fuse box? This is what I have done for my other VWs historically.
Tiguan 5N2 (2.0 TSI (CCZD) 4Motion, REMAP 158 KW/211PS)
Ex Caddy 2k (e.o.2004) (1.9 TDI(BJB), REMAP 103KW/145PS) Ravenna Blue
- paul4314
Finally fixed my poxy implausable signal to me cam sensor
Spent hours stripping loom getting a Ecu that was dead then a new one and got let down by a mate to code it in then I got a AQ Ecu with the immobiliser removed so I could solv the cam issue and get my 6th gear cruise working
Also at the start of it all I fitted 2 cam sensor a cheap from from
Andrew page
Then a top end one from German and Swedish didn't fix it
So gave up after stripping loom and waiting now
I got a digital ociloscope to check sensor and bought a 3rd new sensor
Guess what 7 months later it's now fixed I manage to buy 2 new sensors that were faulty
How's that for luck
At least I have a Ecu waiting to be re immobilised and remapped that works in 6th gear cruise
Andrew page
How's that for luck
- Sneck
mkvanman
Sneck van looks nice & clean
- Sneck
I have had it a week now and my intention is to tax it from the 1st October (so on Sorn at the moment) You wouldn't believe how many hours I have spent on it already, it was a works van.mkvanman wrote:Sneck van looks nice & clean
