MartyPL wrote:Mainland Europe has RHT (right hand traffic) with LHD (left hand drive) vehicles and the UK has LHT with RHD vehicles.
So ... Yes. My steering wheel is on the left side and that's what LHD means:) or maybe it means where the driver seat is;) Doesn't matter. We are LHD;)
Allrighty then. Could you share the partnumbers for the mirrors then?
Tiguan 5N2 (2.0 TSI (CCZD) 4Motion, REMAP 158 KW/211PS)
Ex Caddy 2k (e.o.2004) (1.9 TDI(BJB), REMAP 103KW/145PS) Ravenna Blue Passat 3C heated front seats, Premium 3D Color Cluster
[quote="Caddyshack57"]Got myself these items to fit on my Caddy today ,,,, Well pleased Problem now is I need someone to fit and re code them for me
shame I don't have any software to do the immobiliser or I could have helped u out
U already got a cruise control stalk if not get one also what years the van
Caddyshack57 wrote:
Its 05 reg mate , no I've not got a cruise control stalk do I need to change both stalks to add this one ? or does it replace my indicator stalk ?
It will replace your indicator stalk u need to look for the comprehensive cruise control fitting guide as I think the 2005 needed an extra wire fitting to make cruise function when activated u may a swell go the whole nine yards if ur doing mfsw and midline cluster
Paul,
Would you know If the vehicle that I got the mfsw and midline cluster from would be suitable as it is available to buy still at £35.00 (golf mk5 2007)
Today I figured out a use for all the cup holders in the caddy and that the wired slot pocket by the handbrake fits a nougat wafer ice cream pretty well!
Hindsight is a wonderful friend but he's always late !
S.w.blackwell wrote:
I used 5mm flat top wide angle red leds, I have these from other projects but you can get them from RS, FARNELL, CPC, MAPLIN (don't forget an inline resistor)
The passenger door I added a Tamiya 2 pole connector (left over from something else so the door card can be removed)
They go to pin 17 as shown by the yellow wire and share the -Ve (pin 19) from the door warning lights. (note my van is 2015 Black edition / highline)
I had to use VCDS on the door modules to get them to work. (think it was +8, but it is listed on the helper)
