GibboVW
Post by GibboVW »
ben_faulkner wrote:beautiful seats, i decided to go with the leather R32's but love the pattern on these seats. what does the extension do?
Just to raise them to a similar height to standard seats, means I can store stuff under the seats too.
S.w.blackwell
Post by S.w.blackwell »
tovtm wrote:Do they need coding?
No coding. The standard lamps are wired to the BCM on the same outputs as the interior light. ( no footwell dedicated circuit on a caddy)
The red LEDs are wired to the illumination circuit ( back of esp switch for me)
Steve
tovtm
Post by tovtm »
S.w.blackwell wrote: No coding. The standard lamps are wired to the BCM on the same outputs as the interior light. ( no footwell dedicated circuit on a caddy)
Steve
Be great to see some night time photos :) nice little mod
aerobic247
Post by aerobic247 »
i finally got round to connecting the illumination wire on the back of my Pioneer head unit, i was sick of getting blinded when driving in the dark, i connected it to the ESP (traction control) button, grey wire with a blue stripe if anyone else needs to do it
my Mountain Biking Camper build viewtopic.php?f=12&t=24530
Freewilly
Post by Freewilly »
Sorry if this is in the wrong thread but would an armrest and seats from a 13 golf fit into a 12 caddy
Geraout
Post by Geraout »
S.w.blackwell wrote: I can have a look but unless you have the same LED the resistance may not be ideal, you should base your resistor on the LED voltage and mA. Plenty of calculators if you google.
Steve
Thanks for the reply Steve. I'll have a google. What happens if you just wire in an LED without a resistor.
I've got some pre wired ones that seem to work OK if I connect them across a 12v battery...
Geraout
Post by Geraout »
maxx007at wrote:Changed the BCM from lowline to highline.
Al to enable from foglights, chlh and cornering lights (front foglight on the side that you're turning to turns on in the corner and turns of when you're straight again)
Both fogs also come on when reversing....
bundie
Post by bundie »
Steve
I can turn them on and Off on my cluster.
Only no lights mounted
anoneamus
Post by anoneamus »
Arrived today! :)
(a few days late for the Caddy's 1st birthday)
maxx007at
Post by maxx007at »
anoneamus wrote:Image
Arrived today! :)
They look good
Tiguan 5N2 (2.0 TSI (CCZD) 4Motion, REMAP 158 KW/211PS)
Ex Caddy 2k (e.o.2004) (1.9 TDI(BJB), REMAP 103KW/145PS) Ravenna Blue
anoneamus
Post by anoneamus »
Also arrived today! :D
anoneamus
Post by anoneamus »
Turned on the air-conditioning!
maxx007at
Post by maxx007at »
Nice temperature reading. Your Air conditioning will have to work to cool down your car Image
anoneamus
Post by anoneamus »
Fitted these today. Left is RHD, Right is LHD (so that there are 2 reverse lights). Will sort out a dual-filament fog lamp (like the old ones) in due course (or not, as fog lamp is not a legal or practical requirement in South Africa).
Geraout
Post by Geraout »
Steve
Very nice little mod.
Can you wire the leds straight into the illumination circuit or do they need any kind of resistor etc?
