anoneamus wrote:
So this will also work with AC? Because that I could definitely use!
You must have WEBASTO installed. Thermo Call is "only" to operate it via GSM.
WEBASTO has got a ventilation mode but in your location even the ventilation mode it's not useful so as WEBASTO itself;)
Impressive economy, did you put a larger fueltank in the back of the van?
Tiguan 5N2 (2.0 TSI (CCZD) 4Motion, REMAP 158 KW/211PS)
Ex Caddy 2k (e.o.2004) (1.9 TDI(BJB), REMAP 103KW/145PS) Ravenna Blue Passat 3C heated front seats, Premium 3D Color Cluster
chrisellis211 wrote:Hi Samuel, the lights I used were £15 from b&m home stores. There an enigizer kit designed for under a kitchen cabinet. They came with a 240 to 12v invertor. I cut the end of the plug and wired it in to a constant live in the fuse box. Number 43 I think but I can check if you need. The cable that come with it were not quite long enough between each light so I just cut and extended as required. As for the earth that is just earthed to the chassis. I also have put a switch in so have taken a loop between the fusebox and the first light. If you need anymore help just ask.
Thanks Chris, I appreciate the help.
(Sorry for the slight thread jack)
NBMike wrote:I bought a 5 metre self adhesive led strip light and fitted it in the cargo section of my van. I have fitted this before and it gives a great light, just right for finding small tools in among the junk. (It's a working van) I had some trouble getting it to stick and have ordered some self adhesive clips from Beal.com. At some point I must have pressed too hard and shorted it and blown the interior light fuse. Can anyone advise where to find this fuse. I have checked below steering wheel and next to battery. I have also done a search on forum and although this question has been asked before-it has never been answered( that I could find)
Anyone.??? It gets dark about 4.30 and it's really hard to find stuff in the back without ANY interior lights!
I don't have enough posts yet to access all areas of this site. So I am relying on you guys. Can anyone please have a look in their owners manual to see where the interior light fuse is located?
jimc wrote:Big difference that's not just a bulb is it?
No it has a ballast as well
The one I bought is below but you can get them cheaper especially if you buy from China but I wanted UK stock (for 12month warranty) and also the seller had the h1 and h11 kits in the same colour so all my lights match .
