My Caddy 4, 1.4 TSI, Acapulco blue
activeviii
Re: My Caddy 4, 1.4 TSI, Acapulco blue
Looking good.
Just finishing off the carpeting in my maxi. I only want it a little quieter. If cut most the bulkhead out as to keep the side trimmed as I want it open.
Just about to insulate and infill the window areas. I have the tins still for the rear. Just working out if I can still use or have to cut tighter fitting ply.
Want to put cruise control on but struggling to find anyone to code it after I fit. My head will not hold information so no point in my sorting out vcds for my own use. Ideally need someone that know what their doing as I would stuff it up big time.
I see your in the shire. Don't suppose I could twist your arm to do some coding from my please lol
Glen G
Van looks great like what you have done so far.. And love that colour something about it ♥
- Giddy
Thanks lads, carpeting in progress at the moment. Couldn't finish it last weekend because of the terrible weather, so only one side is done so far. But getting there... slowly
@activeviii I don't mind to help, but I would need to purchase extra VINs, which is quite expensive. You would be better off with getting your own vcds or finding somebody who already has unlimited VINs.
pastica
That carpeting looks fantastic! How did you get it to mould around everything so well? Also, were the seats a direct bolt in? Or did the rails require some modifications?
- Giddy
Thanks mate. Carpeting required some time and patience
This was my firs attempt to carpet the van and I was working on my own, so spent whole weekend doing one side. Three weekends in total to finish all the back to the standard I'm happy with. Mechanically seats are straight fit on Touran bases.
- Giddy
So, finally finished carpeting all the back. Pretty happy with how it came out. Roof liner is also done, just need to wire in some LED spotlights. Also I've put some recycled plastic insulation and dodo superliner where was practical to do so and wired in 12V sockets and USB charger.
- Giddy
Also removed all the gray plastics in the cabin as I want them to be trimmed in black. And while I was there, I've put some dodo mat and dodo superliner to the roof.
- Giddy
Picked up some black bits from vw for my interior conversion.
- BradleyB
Looking good mate
Should make the cabin complement them seats
Froggy89
Van is looking unreal! Just about to sound deaden mine. Just wondering how many sheets of Dodomat you used mate. Yes I’m looking to cover everywhere like yourself and not just the back. Cheers.
- Giddy
Thanks mate, it's getting there slowly...
I've done it in few stages. First I have used 3mm Silent Coat volume pack for the wheel arches and 2mm Silent Coat bulk pack for the side panels and the roof. Then I decided to do entire floor, so I've bought 50 sheet Dodo Mat pack for the cabin and rear floor. Also I have bought 1x6mm Dodo Supeliner roll and 2x12mm Dodo Superliner rolls to cover entire cabin floor, entire roof and side panels where possible. Have some leftovers, but the front door is not done yet, so I think it will be enough for the front door too. Hope this helps
- Guy94
Good work dude
Do you have the part numbers for those black bits? Mainly the interior light
Think the black will look the business
Think the black will look the business Sent from my iPhone using Tapatalk
- Giddy
@Guy94 Yes I do, I'll put them in the "useful part numbers" thread, so they wont be lost.
- Guy94
Nice one mate, thank you.
Froggy89
Yes mate. A big help. CheersGiddy wrote: ↑Tue Oct 15, 2019 6:09 pm Thanks mate, it's getting there slowly...
I've done it in few stages. First I have used 3mm Silent Coat volume pack for the wheel arches and 2mm Silent Coat bulk pack for the side panels and the roof. Then I decided to do entire floor, so I've bought 50 sheet Dodo Mat pack for the cabin and rear floor. Also I have bought 1x6mm Dodo Supeliner roll and 2x12mm Dodo Superliner rolls to cover entire cabin floor, entire roof and side panels where possible. Have some leftovers, but the front door is not done yet, so I think it will be enough for the front door too. Hope this helps![]()
