Mk6 R front bumper on caddy
scatman75
Re: Mk6 R front bumper on caddy
Post by scatman75 »
so were do i go from here,i take it ill need some plastic welder at least to get to the next stage...
scatman75
Post by scatman75 »
i found this in bunnings ,will this be idea to get it welded....
RKDesigns
Post by RKDesigns »
I used a heatgun 660 degrees celcius and special plastic welding end.
scatman75
Post by scatman75 »
i really appriaiate your help mate,did you overlap the bumpers much and what did you use to smooth out the joins...
RKDesigns
Post by RKDesigns »
No overlap at all. You need to keep just some space between both bumpers while the hot staples go in or afterwards cut it a bit open. Melted plastic via the welder tool in the middle of it. I welded it and spreaded it out with the welder head which doesn’t look so nice but it’s strong. In the end filler on top. Used by the way cutted material from the bumpers to weld them together. So it’s 100% pp-epdm <10>
scatman75
Post by scatman75 »
Supply's I got so far,do these look ok mate ...ImageImageImage
Sent from my SM-N960F using Tapatalk
RKDesigns
Post by RKDesigns »
There are many ways to weld plastic together.
You bought some stuff like this...
https://youtu.be/FEGb4ofbGOE
RKDesigns
Post by RKDesigns »
And I have no patience lol so went for “speed welding” 3:24 in the video. You get a thicker effect like you can see at the back close up of my front bumper. There I left it as we will not see it later on. At the front side I spreaded it out.
https://youtu.be/HvV9a3lEe2g
scatman75
Post by scatman75 »
So much good info here ,some pictures of were I cut the caddy bumper. .ImageImageImage
Vandangos
Post by Vandangos »
Looks good! 👍
scatman75
Post by scatman75 »
Lots of sanding still ahead...
Looking good there mate
RKDesigns
Post by RKDesigns »
Looks much better the R bumper on the caddy.
scatman75
Post by scatman75 »
Nearly there,lots of sanding to get the shape right ...
RKDesigns
Post by RKDesigns »
Hours and hours sanding
