Gmancan1
Post
by Gmancan1 »
Little more done to grill
Plan to smooth in where masking tape is and do gloss black to match grill
Gmancan1
Post
by Gmancan1 »
Coming along nicely
This is just tape mock up
With the badge on
Gmancan1
Post
by Gmancan1 »
Started to feel like Hell raiser
“Plastic welded”
Soild now to work the edges in and smooth
(Wee mock up the silver likes going red)
Gmancan1
Post
by Gmancan1 »
Stuck on badge choice
(The line will be taped Red)
Custom tdi with red behind (i have a caddy to match)
R badge with white sticker
Tdi with white sticker
(Its black below might keep and use gloss black vw badge)
Gmancan1
Post
by Gmancan1 »
Gmancan1
Post
by Gmancan1 »
Little more done
Alot more grinding
Gmancan1
Post
by Gmancan1 »
Top coat then sand flat and spray
Dwr85
Post
by Dwr85 »
Gmancan1 wrote:Little tester/teaser of plans for Bay ive a Cover coming to
Plan to make head look like pipe coming out his mouth or side his head
You didn't see this on a little green lupo and take inspiration from it by any chance did you?
Sent using Tapatalk
Gmancan1
Post
by Gmancan1 »
Ive seen done on loads
Defo seen that lupo tho!
Seen on a mini too (was gonna do yo mine)
Nothing new under the sun
Brutus1989
Post
by Brutus1989 »
Dwr85 wrote: ↑Fri Nov 03, 2023 8:22 am
Sent using Tapatalk
Another great white caddy van! How simple was the touran centre console? Do I need the front kick trims too?
Gmancan1
Post
by Gmancan1 »
Easy buddy just screw old off no your caddy ones should be grand
I do like the white doesnt take much to set off
Gmancan1
Post
by Gmancan1 »
Sorted the bit round badge was trying to fiberglass andbwas going to use filler but if it flexed it might crack so “plastic welded”
Smooth and paint!! Baby steps
Gmancan1
Post
by Gmancan1 »
Alot more smoothing
But its one
Gmancan1
Post
by Gmancan1 »
Mock up idea
Gmancan1
Post
by Gmancan1 »
Used sander (forgot i had)
Helped loads!
Just need to fill the low spots then sand again see what happends
(Btw noo idea what im doing)
