C Chis
Re: Let the build begin - VR6 and air on the way!
Post by C Chis »
Compressors, driers and relay all wired in along with installing the air receiver and the air lines to/from it.
Air receiver has had a few coats of stone chip for a little added protection against the coming winter and the tubing and wires have a bit of protection with the flexible conduit.
Controller wiring to complete tomorrow and then time to test prior to fitting the air bags and stuff.
Looks like a nice job you’re doing there mate.
Sean1066
Post by Sean1066 »
Nice work there buddy.
Your have up and before you know it 😁
Caddy maxi 3.2 VR6 EX BG
My build thread
C Chis
Post by C Chis »
Cheers guys!
For some reason I thought this install would only take a couple of days
C Chis
Let the build begin - Plushed VR6
Post by C Chis »
Well… after 4(ish) days of hair pulling and head scratching…
It’s 98% completed!
The ride is super nice, firm but not harsh like my old coil overs
How the underneath looks at the moment, quite tidy, discrete, little bit of tidying up to do, that’s next weekends task.
Flexible hose from the bag to the body fixed to a custom made and welded on bracket with 1/4bsp to 6mm bulkhead fitting
Rear bag, shortened and updated Bilstein shock absorbers (axle has since been cleaned and stone chipped.
And van at full height to get over the pavement and down into my drive. Kinda scary the first time as I’d sold the idea of air suspension on the premise that I’d still be able to get in and out of our steep drive without scraping ImageImage
And finally… managed to buy some R32 pedals for my feet Image oh, and excuse the mess, took the picture before cleaning everything up Image
Time to sell the 6 month old Bilstein B4’s, drop links, lowering springs and rear shocks to replenish a little bit of the secret Caddy fund!
Re: Let the build begin - Plushed VR6
Amazing, great job.
Lister79
Post by Lister79 »
Looking good Colin, nice to see another properly done air install without the air lines cable tied on.
With your front leader hose, and depending on your bulkhead bracket position, you should be able to route it round the front of the strut, attaching it to the existing sensor bracket with a P-clip. That way you won’t need to loop the hose.
Also when aired out just make sure the rear antiroll bar mount (part welded to axle) isn’t catching your fuel filler neck. It’s easily relocated further down (using some plate) if it’s close.
C Chis
Post by C Chis »
Cheers guys!
Chris, thanks! I was wondering how to sort out the front hoses and I never thought about the rear bracket, I’ll check it out before going lower! I can reposition the welded on brackets if required.
I haven’t notched the front rails for now however…
Lister79
Post by Lister79 »
No worries at all mate, if you have a look in my build thread (end of April time last year) there will be some photos.
C Chis
Post by C Chis »
Cheers! Just away to have a look!
Definitely worth the 4 days of head scratching and hair pulling, looks class.
JWcaddy
Post by JWcaddy »
Love how this just started out as "I'll just do the back for the mountain bikes" :D
I like the idea of those clamps in the back, but mine and the wife's bikes won't fit with wheels on (hers does, mine doesn't).
The VR6 is awesome though!
benny_bassline
Post by benny_bassline »
very tidy :D
Vanmandan
Post by Vanmandan »
Do you have a choice of wheel in mind?
2015 VW Caddy Maxi 1.6TDI 102BHP
C Chis
Post by C Chis »
[mention]JWcaddy [/mention] me too, mrs C a little less so!
I love the VR noise, looking to modify the exhaust to include the original exhaust valve for a little extra VR vroom…
[mention]benny_bassline [/mention] cheers bud!
[mention]Vanmandan [/mention] if you mean steering wheel, then yes, looking to get hold of an R32 MFSW to keep the look
