2011 Pure Grey
Irish-si
Re: 2011 Pure Grey
They are wired through the module in the doors and work as per the interior light on the door latches, tommyzoom will sort the looms for you and they are activated with Vcds or OBDeleven
Gmancan1
Re: 2011 Pure Grey
Yeah budd i had a wee look into makes since why you would need to have connected in
Bit outta my depth tho look the part!
- Damo2k
Re: 2011 Pure Grey
Thanks mate will look into it
Irish-si
Re: 2011 Pure Grey
Got it back today I’m delighted with the outcome, there’s some soft damage in the driver door skin but I’m not worried about that I may or may not get PDR, it’s a working van after all
Gmancan1
D866
Re: 2011 Pure Grey
Looking good! Serious work to get that done.
Dave here that got the door cards off you!
Would you have the part number of the dash clocks you installed?
Irish-si
Re: 2011 Pure Grey
Hi Dave
Thanks for the kind words, the clocks are not straightforward, you will need to source a set of highline clocks, you’ll have to get 6 leds changed on the board then you’ll have to source the blue needles these are quite expensive, I was lucky enough to find a set of golf r clocks on eBay , once these were made I had to travel from Carlow to Ennis to get them fitted and coded to my van,
I had already changed my BCM and steering control module to highline for the buttons on the wheel to work with it all
I haven’t actually added up how much but quite expensive to put it all together
Gmancan1
Re: 2011 Pure Grey
https://www.ebay.co.uk/itm/143225199137 ... media=COPY
Set of clocks arent cheap at all! But the outcome!!
Irish-si
Re: 2011 Pure Grey
Not a cheap modification by any means but it’s a hobbyGmancan1 wrote: ↑Thu Aug 03, 2023 4:15 pm https://www.ebay.co.uk/itm/143225199137 ... media=COPY
Actarus
Re: 2011 Pure Grey
Great modifications.
I do the same on mine
Irish-si
Re: 2011 Pure Grey
Never really liked the black mk4 dynamic indicators so came across these from another well known car maker and thought they suited the shape better
Irish-si
Irish-si
Re: 2011 Pure Grey
did they just fit right in ...
in the body work
in the connectors
what extra work did you have to do ?
care to share the other mfrr deets
in the body work
in the connectors
Irish-si
Re: 2011 Pure Grey
Bought on Alixpress they plug in to bulb holder, they clip in on one side and had to drill a small hole for a screw, they’re not quite tall enough to fill the hole but I just used black mastic tec7 on the bottom , they do throw up a bulb fault light but us caddy owners are well used to it
