I'm a window cleaner, and will be fitting a 350lt baffled tank.
I want to know if anyone has installed a water tank into their caddy with a restraining kit that bolts into the chassis?
Someone told me I may have an issue as there may be a false floor in the caddy. I'm not entirely sure if this is true, so if anyone knows about or has done this, could you please let me know if it was straight forward, or was a metal plate required to be welded?
Thanks in advance
Fitting a Baffled Water Tank
