Windows misting
Posted: Tue Dec 04, 2018 7:43 am
by mintydrummerman
Recently carpeted the back of my van. Anyone else suffering with the front windows misting up recently?
Sent from my H8216 using Tapatalk
Re: Windows misting
Posted: Tue Dec 04, 2018 8:36 am
by brooneye
If it’s on the inside it’s normally a bit of dampness somewhere inside. Such as a damp carpet
Re: Windows misting
Posted: Tue Dec 04, 2018 10:03 am
by dan@biali
Could also be worth checking the pollen filter but as brooneye says, points to moisture somewhere. Could it be the water in the adhesive you used for carpeting the rear evaporating?
Re: Windows misting
Posted: Tue Dec 04, 2018 2:18 pm
by mintydrummerman
I've just realised I sponged down the bulkheads and hosed them and don't think I let them dry enough. Doh!
Re: Windows misting
Posted: Tue Dec 04, 2018 8:21 pm
by punkCK
campers and converted vans are meant to have trickle or air vents to stop condensation happening.
My old T25 and T4 had them and once id insulated and carpeted they only just managed.
With the veltrim type carpets on walls and roof it captures moisture every time you've got the door or windows open, even worse in this cold damp time of year.
Another thing with modern vehicles is you can't manually turn the cabin heat direction to recycle when you park it up at night to stop any cold air coming in.
Or does it auto stay on recycle when you shut down the engine??
Maybe worth retro fitting something?
Re: Windows misting
Posted: Tue Dec 04, 2018 9:43 pm
by loglifter
Check underneath any flooring you’ve laid, mine was sodden, I had run the carpet lining down off the wheel arches onto the floor, also did same round rear door frame and water somehow percolated in past door seal , along carpet on floor then dripped down onto carpet in foot well behind/under drivers seat leaving it soaking and stinking. Cured it by trimming all excess carpet back, hope this helps
Re: Windows misting
Posted: Tue Dec 04, 2018 10:20 pm
by mintydrummerman
Thanks for the comments all
Re: Windows misting
Posted: Thu Dec 06, 2018 8:40 am
by m90stw
I had a small amount of water in the pan under the drivers seat, dried it & put in a dehumidifier & no more misty windows
Re: Windows misting
Posted: Sat Dec 08, 2018 5:31 pm
by mintydrummerman
So I reckon I've discovered the issue. The van would have a clicking sound when reversing and spraying the washer fluid. When pressing the recirc button I get the clicking.before it goes into the garage I guess it's the recirculation valve
Re: Windows misting
Posted: Sat Dec 08, 2018 6:48 pm
by Yeti
dan@biali wrote: ↑Tue Dec 04, 2018 10:03 am
Always worth a quick look, the one in my dads fabia had half a pint of water in.
Re: Windows misting
Posted: Sat Dec 08, 2018 7:11 pm
by ViralEye
I only got my van a week ago and with the cold nights drawing in I had misted windows the other day. I've now got 2 silica bags on the dashboard permanently and not had the problem dince!. Worth a try
Re: Windows misting
Posted: Mon Dec 17, 2018 11:22 pm
by dj54mmy
pollen filter
Re: Windows misting
Posted: Fri Dec 28, 2018 5:09 pm
by mintydrummerman
I've changed the pollen filter as suggested. It still isn't right and today I've taken the lh speaker out due to an unrelated issue. Turns out there is moisture in between the door panel so I'm thinking this could be the culprit
Re: Windows misting
Posted: Sat Jan 05, 2019 5:29 pm
by mintydrummerman
Further update - removed both door cards and got water in both doors. Any suggestions as to the cause?
Re: Windows misting
Posted: Sat Jan 05, 2019 10:53 pm
by Southcoastcaddy
This has been happening to ours but nothing seems damp carpetwise, didn't think to check the pollen filter, thanks.
