Locking and dead locking.
- DaveN
Hello all,
First time caddy owner, with a slight possible issue.
If I click the lock button on my remote it locks everything.
If I double click the lock buttton it locks but then unlocks the back, seems a bit odd as most vehicles tend to deadlock by double clicking lock.
Any ideas? Or guidance?
Dave
Dave
Re: Locking and dead locking.
I'm fairly sure you have a problem if double push on your lock button unlocks the rear.
From memory it is described in the vehicle handbook as the first push deadlocks all doors, a second push releases the deadlock so someone on the inside can get out if they need to.
- DaveN
The front remains locked but all rear doors open
Check your handbook but I'm 99.9% sure that's not correct.
- DaveN
Thank you
hmm, wonder if mine does that
When you say “double click” you mean in quick succession or after a slight pause?
- DaveN
Like within a second or two I’d say.skinnyd wrote:When you say “double click” you mean in quick succession or after a slight pause?
- H11NUM
I've just checked mine first press on the lock button all doors locked with alarm light flashing on top of door card,second press on the button all doors locked however no alarm light flashing,I wonder if the the second press disarm's interior sensors.
- H11NUM
But in your case I'd say you have an issue
Just to clarify....
It's not the "alarm" LED. It signifies whether the deadlocks are activated or not.
One press - deadlocks on - LED fast flashes for a couple of seconds then slow flash every couple of seconds.
Two presses - deadlocks off - LED fast flashes for a couple of seconds then off for 30 seconds then slow flash every couple of seconds.
Two presses does not disarm the interior sensor. This is done from the door pillar button only.
LED permanently on signifies fault.
DaveN - I wonder if your key fob may be faulty. It sounds like the middle button which unlocks back doors only may somehow be being activated.
Have you tried the spare key?
- DaveN
I’m afraid my spare key is the poverty stricken non fob option. So not possible. It is a strange scenario I must say
Is there a solution to this problem ? I’ve just bought a caddy and mine unlocks it’s self when you double press the lock button but only the back door all the others remain locked .
Is this a problem or just a residue of these vehicles being first and foremost a van which may on occasions double up as a crew van/people carrier?
I have not seen this behaviour on our Caddy Maxi but our T5 Transporter does what you describe so it may not be faulty. Single press everything is locked. But if you press a second time immediately after the first, then our T5 Multivan releases the tailgate - but other doors remain locked. Perhaps this is of value to tradesmen who just need to access the load area but wants the cabin secure?
I did try and follow the German language user manual and eventually worked out the simple answer was to only ever use single press. The manual did imply your VW dealer could change the locking options - but what options would be available depend on whether its got one or more sliding doors, and whether it has a tailgate or barn doors.
