White cluster upgrade
Re: White cluster upgrade
Awesome thanks can you explain that coding… I tried coding it myself and turned Tpms off and saved worked ok and the. Drop down box to select caddy 2k said refused lol… chuffed anyway but I wanted to let you know about this module change
That's the coding as standard on a 1K0-907-379AF equipped caddy.
If I remember correctly, VCDS doesn't have a breakdown of the coding.
