Sat in my caddy broken down
My 2011 ex bg died on me. It will crank start and run for 5 secs and revs splutter to a stop. Repeat same thing. Got home picked up laptop and vcds cable and returned to van..vcds no error codes shown. It's as if no fuel supply. Even ran the fuel pump prime program. 3/4 tank of diesel. Awaiting green flag.
2011 1.6 102ps ex BG
225/40/18 ps3 Santiago wheels
Re: Sat in my caddy broken down
sounds like immobilizer
- r1lea
+1
Cheers guys anything I can do diagnostic wise with vcds or a multimeter. Lots of rain in Manchester possibly a culprit? Would ezee start keep it running as a test. Don't fancy going to jobs in my 89 mk2 golf gti tomorrow!
try your other key
Eck only have one key
any faults in the instrument cluster?
did you do an autoscan or?
Sent from my ASUS_X00ID using Tapatalk
Did the autoscan. Nothing. Apart from steering angle sensor after the battery went flat from cranking him and the usual traction control light. Which resets after moving a couple of meters. I am really in the doo doo on this. Would prefer an injector fail.
if it starts and revs i doubt its immo.
its got to be a bad sensor or fuel, im guessing when it starts revs are over say 300?
Accelerator does nothing. Won't rev over 1100.
No eml light when it conks
try unpluging your camshaft sensor and see if it will start and keep running.
i had the same symptoms before from a damaged cam hub (basically bad readings from the cam sensor)
Where is it located please??
Unplugged camshaft sensor. It fired cutout and wouldn't start again with flashing glow plug symbol. If it helps the caddy had been driving for 10 mins when it spluttered to a stop. Does the immobiliser and key only get checked on startup or is it done constantly whilst engine is running? I'm considering getting a a new key made to eliminate the possibility that the key is faulty unless there is a way to prove it is working
If it was an immobiliser problem your have a symbol on the dash. It's a car silhouette with a key inside.
It is only checked on startup so it won't be that which caused you to splutter to a stop.
Definitely sounds fuel related to me. Have you checked the filter housing?
Thanks doc for posting. You are the font of all knowledge! No key symbol and gen filter fitted from tps a few thousand miles ago. Am going to look tonight. Sprrk from terminal when reconnected battery though.
