HI All,
Have any of you ever experienced a variation in idle when you release the clutch , like a dip/rise in idle then it sits back at the correct range ?
Any thoughts or suggestions ?
Clutch release idle fluctuation
Re: Clutch release idle fluctuation
Is normal for some fluctuations in the idle speed to happen but no more than say 50rpm. How bad is yours?
If it is very bad it might be a sign your gearbox is having problems. Worse case it may be a crank problem.
If it's a 1.6TDI and it's had replacement injectors, the injector offset can cause this if it has not been set.
Its not bad at all but noticeable , was just curious as you will normally always get a blip when coming to a traffic light etc and you release the clutch .
its the 1.6tdi 102 but mapped to 140 , injectors have not been done to my knowledge and don't look to be new either .
appreciate the response .
I have the same problem on mine, it takes turns when I actuate the clutch pedal or brakes. 1.6 tdi 102
Is this to do with a hill start assist or am I thinking of something else , my BG van does it but like Doc says it’s about 50ish rpm .
