Page 16 of 18
Posted: Sun Dec 26, 2021 4:53 pm
by Hooligan_Harv
@robblowen your build look awesome, might have to steal your idea for the roof lights, was thinking of running LED around the edges but I do like the look of the inverted island, nice work
Posted: Mon Dec 27, 2021 10:38 pm
by robblowen
@Hooligan_Harv cheers man, it's a work in progress but it's getting closer! Glad its given you some inspiration, good luck with the roof lining, get some pics up on your build thread when you get it done.
Posted: Mon Jan 31, 2022 9:33 pm
by robblowen
I've not had much time recently for the van, but I managed to get a few little jobs done today. First gave it a well needed bath and then got around to fitting the 2WD and Caddy2k decals I've had sitting around forever!!!
Hopefully get some more bits done this week, I've still got the rear windows to tint, bcm to change, stan's footwell lights to fit, wheel arches to fit, stalks and mfsw to swap.
Posted: Fri Feb 11, 2022 10:31 pm
by robblowen
Managed to strip both sets of stalks today to delete the trip buttons off the wiper stalk, then fitted my MFSW. Had a brief 10 minute panic, thinking I'd fucked something up when my wipers/washers wouldn't work! Plugged the laptop in to test the stalk outputs, everything was correct. Started to get really confused until Irealised I was staring at my bonnet. Which was still up from disconnecting and reconnecting the battery!
Everything working as it should and the new wheel feels so much better than the original!!!
Also got the passenger door part of my footwell lighting loom. Hopefully get the rest of it fitted and working next week!
Posted: Fri Feb 11, 2022 11:31 pm
by sewi
Nice work mate! I didn't like this particular steering wheel initially but it is growing on me. Well they did use it in Passat too up to B7.
Posted: Tue Feb 15, 2022 11:54 am
by robblowen
@sewi cheers mate, I can't justify anything Gucci as the van spends a lot of time in the hills, climbing, walking, biking, etc. So gets abused a bit. Needed an upgrade to the standard thin plastic thing though!
Posted: Fri Mar 11, 2022 8:58 pm
by robblowen
Finally got round to ordering some Team Heko wind deflectors, really happy with the fit and look!
Posted: Fri Mar 11, 2022 9:02 pm
by robblowen
Ordered some mk4 tinted tail lights from LLLPARTS. They came this morning, so following @Doc brilliant write up it took all of 20 minutes to remove the old lights, repin the plugs, fit the new lights and test everything works! Spot on write up, cheers doc. Looks so much better than standard! Just need to get the bottom bar and reverse error light coded now and I'll be happy!
Posted: Wed Mar 16, 2022 5:51 am
by robblowen
Posted: Wed Apr 13, 2022 7:56 am
by Afterthesend
@robblowen
What year Caddy do you have and what year touran matting did you get? Did you have to make any adjustments to it?
Posted: Wed Apr 13, 2022 6:01 pm
by robblowen
@Afterthesend mines a 2014, I'm pretty sure any Touran from 05-15 will fit, but its a long time since I had to think about it so double check. Definitely 10-15 does. No adjustments needed mate, they just drop straight in.
Posted: Wed Apr 13, 2022 10:41 pm
by Afterthesend
Nice one cheers dude.
Posted: Thu Apr 14, 2022 2:40 pm
by Afterthesend
Hi Rob,
Sorry me again. Do you have the part number for that backet? Also do you have any images of the seat belt configuration?
robblowen wrote: ↑Wed May 01, 2019 9:34 pm
....I managed to find the replacement beam that the front brackets fasten to, about £50 from TPS....
Posted: Sun Apr 17, 2022 2:52 pm
by BlackEdition
absolutely fantastic build thread couple of questions
what size battery did you put in the rear wheel arch section fantastic idea to hide it out the way
also don't suppose you have the part number for the seat mounting bracket is that the proper part for the caddy so you dont need to modify the touran bracket
Posted: Sun Apr 17, 2022 5:21 pm
by Pman1984
If you mean for the rear seats I'm pretty sure it's the proper front bracket to fit the OEM maxi life/maxi crew cab seats only. If you have touran seats you have to use the brackets cut from the donor touran.
Sent from my POCOPHONE F1 using Tapatalk
