Alloys for 2011 Maxi
Posted: Sat Sep 28, 2019 12:35 pm
by XTX
I have just got a 2011 Caddy Maxi (ex-BG), that has steel wheels fitted, which are battered.
I traded in my 2006 Skoda Octavia Estate but I still have the original alloys for it, which I would like to use on the Caddy if I can.
The label in the Caddy drivers side doorway says 6J x 16 (I don't have a user manual for the van) and the Skoda Alloys are 6.5J x 16 PCD 5 x 112.
Do any of you know if these will fit?
Re: Alloys for 2011 Maxi
Posted: Sat Sep 28, 2019 7:34 pm
by liamcaddy61
Should fit the 5x112 is the bolt pattern and the 6j is the width of alloy, think you can go up to 8/8.5j without the sliding door catching
Posted: Sat Sep 28, 2019 7:42 pm
by XTX
liamcaddy61 wrote: ↑Sat Sep 28, 2019 7:34 pm
Brilliant thanks!
Posted: Sat Sep 28, 2019 8:40 pm
by Skully
What is the offset of the Skoda alloys?
There should be specs cast into the rear of one of the spokes that reads "ET**"
The ** denotes the offset and that is more important than the width of the alloy.
Posted: Sat Sep 28, 2019 8:43 pm
by liamcaddy61
my bad I dont have massive knowledge of alloys
Posted: Sat Sep 28, 2019 9:15 pm
by XTX
Skully wrote: ↑Sat Sep 28, 2019 8:40 pm
I am not sure, I will see if I can find it in the morning.
The spec sheet for the Skoda says ET50 and the alloys were genuine Skoda Octavia alloys, so I assume they would have been to spec.
Posted: Sun Sep 29, 2019 6:58 am
by Tattoocaddy
Morning mate the et would need to be between et47 to et54 to be sure I'm running Audi A-line 19inch alloys on my maxi hope this helps
Sent from my LYA-L29 using Tapatalk
Posted: Sun Sep 29, 2019 6:59 am
by 3_50
There's quite a good
wheel and tire calculator here, and there's quite a lot of room in the caddy arches for bigger wheels, as others have said.
Posted: Sun Sep 29, 2019 8:26 am
by XTX
Thanks guys, very helpful
I need to get my Skoda alloys refurbished now, some of them are not holding air because the paint is flaking in places.
Posted: Sun Sep 29, 2019 9:31 am
by the swan fiend
A good rule of thumb with offset (the ET figure) is to stay with in +/- 5 of the original value. If I remember rightly, the standard 15” steels are ET47, so as low as 42 or as high as 52.
Posted: Sun Sep 29, 2019 11:43 am
by Boonalon
I have A set of Octavia RS alloys they are 7Jx18’s with a ET of 51, no issue at all
Posted: Tue Oct 01, 2019 9:26 am
by the swan fiend
They look well smart boonaloon
Posted: Tue Jan 13, 2026 9:14 pm
by Dantee46
When changing to alloys are you using standard wheel bolts?
Posted: Fri Jan 16, 2026 8:41 am
by STP
Ideally get proper alloy wheel bolts, the part of the bolt under the head which contacts the wheel is a different shape from the steel wheel bolts. Those are domed and the alloy ones aren't from memory. Could bind up or not seat properly.
Posted: Thu Jan 22, 2026 6:40 am
by Roan’s Caddy
Those alloys look insane.
