Page 1 of 6
Owner for 4 Weeks - bank balance taken a hit!
Posted: Fri Feb 21, 2020 8:52 am
by CALSCADDY
Bilstein B14 suspension kit
Refurb of 19" Alloys
Michelin pilot 235:35:19’s
ProVan interior load area LED
Fully carpeted anthracite 4 way stretch with suede infills
MK7 Gtd heated seats (Stan the man looms)
Carbon rear nbumper protector
Motexion bulkhead
VW App Connect
Speed wind deflectors
Side rail delete kit
RAD Skid Plate/Sump Guard
Triple R front splitter
Garage Midnight Stud Kit
Sportline rear spoiler (not fitted yet)
Re: Owner for 4 Weeks - bank balance taken a hit!
Posted: Fri Feb 21, 2020 3:17 pm
by Stedlocks
Looking well though!
Posted: Fri Feb 21, 2020 3:23 pm
by caddychris2002
Looking cock on there pal
Posted: Fri Feb 21, 2020 3:43 pm
by rich181
That’s a good list you’ve got through in a short amount of time! Good work!
Posted: Thu Feb 27, 2020 10:08 pm
by Bourn999
Looking good.
What colour did you do the alloys.
Posted: Fri Feb 28, 2020 12:49 pm
by CALSCADDY
I think they refer to it as black chrome
Posted: Fri Feb 28, 2020 11:43 pm
by Bourn999
Cool nice colour
Posted: Sat Feb 29, 2020 11:36 am
by lotusjay1
Looks great
Posted: Tue Mar 03, 2020 2:12 am
by Ripley55
Lovely looking Van @CALSCADDY
Did you do the cover for the sliding door and tailgate ? is that carpet or suede ?, how did you re-fix it afterwards ? are they the OEM clips for the normal panels re-used ?
It's just I want to cover the black hardboard lower section of my Tailgate, and wondered if it's just a case of getting a really tight carpet glued/overlaid, and then re-using the existing clips ?
Posted: Tue Mar 03, 2020 2:25 am
by Sampson
CALSCADDY wrote:I think they refer to it as black chrome
Love those rims, fitment looking spot on
Do you know the width and offset of those 19’s by any chance?
Posted: Tue Mar 03, 2020 6:48 am
by CALSCADDY
Ill have a look at weekend and let you know Sampson
Posted: Tue Mar 03, 2020 7:00 am
by CALSCADDY
Hi Ripley
I used 4 way stretch carpet off E Bay
https://www.ebay.co.uk/itm/4-sqm-EASYLI ... 2749.l2649
Faux Suede available here - used on roof lining and original lower panel inserts
https://www.ebay.co.uk/itm/SUEDETRIM-Va ... 2749.l2649
All original clips removed and rivnuts fitted. I then used these to hold the panels in place
https://www.ebay.co.uk/itm/M6-7075-Alum ... 2749.l2649
https://www.ebay.co.uk/itm/m6-Aluminium ... 2749.l2649
The suede isn't as flexible as the 4 way stretch but fairly easy to fit. Spray the panel and the covering with the spray adhesive and let it become touch dry. Large panels are best done by two people, one holding it off the panel and the other gently pressing/contouring onto the panel. Bit like how they vinyl wrap.
Yes I covered the sliding door. On the top panel siliconed a 9mm ply panel in. Then cut another 9mm panel slightly larger. Covered in 4 way stretch and then used panel adhesive to bond that to the first 9mm panel.
On the tailgate the top panel is 4 way stretch and applied direct to the metal on the inside and then "tucked in" to the recess that runs round it.
CALSCADDY
Posted: Wed Mar 04, 2020 12:49 am
by Ripley55
Hi @CALSCADDY
Thank you that's great
That's why I love this site, I've been mulling over how to fit the panel back in a decent way after carpeting, whilst not using the plasic fixings.
So will get some 6mm rivnuts and some of those black anodised ally fixings and Bingo
did you go for the 12mm, 16mm or 25mm long ones ?
Dave
Posted: Wed Mar 04, 2020 6:21 am
by CALSCADDY
25mm - be careful when drilling out all the holes for the riv nuts - easy to hit the outside skin and you don’t want to do that. A good wrap around of insulation tape on the drill bit will act as a “stop”
Posted: Fri Mar 13, 2020 8:09 am
by CALSCADDY
Rims are 8.5” offset 45
Tyres 235 35 19
