Caddys in the mags
- Salty
Re: Caddys in the mags
done it last night
mods this month.....bonnet insulation, front fog lamps and the side rail cover
Lookin good bud, look forward to gettin mine now.
Was there much involved in fitting?
- Salty
Doc wrote:Lookin good bud, look forward to gettin mine now.
parts needed.....1xcover..get it painted
1x rail...this needs to be modified by making and fitting a bracket to line up with the holes in the new cover trim and fixing it to the new rail ( do this on the bench before attempting to fit )
1x clip...part number 7HO-843-658-A
tools..... various handtools,plus a number 5 and 8 multispline
1, open sliding door and remove rail fixing screw that's inside the sliding door shut
2, close sliding door and remove trimboard
3, remove centre sliding roller bolts inside the door ( 8 multispline )
4, from outside carefully open sliding door while supporting it's weight, open slightly and remove roller, reshut sliding door back on striker.
5, remove small plastic trim on rear of rail, just pull off from rear
6, remove the rest of the rail fixings
refit in reverse order
good luck
Thanks bud, didn't know about the clip, gonna hafta order that while mine is being painted, hat part is the clip for?
Did you get a new rail or just use your own, I might get one from a breakers and have it all ready to fit.
Seen one of my mates has a sportline spoiler today, he had no problem ordering it, no 20 questions or sportline chassis number needed.
- Salty
Hi Doc, the clip is for the cover at the rear end and clips into the body in the hole vacated by the small plastic trim, I bought a new rail because there are two spot welded brackets with special clips already on it, but it still needs modifing with a bracket, I can't find anything original on the VW parts fische so I had to make one.Doc wrote:Thanks bud, didn't know about the clip, gonna hafta order that while mine is being painted, hat part is the clip for?
Was that rail included in the £26 part?
Have you a part number for it otherwise?
This could turn out to be expensive.
- Salty
rail part number 2K0843871J - LH Rail - £21.14
not a bad price
worth it for tidying the side
not a bad price
- tommyzooom
Thanks Salty
O.K. so it seems you need
Part 2KO-843-795-A..Rail cover (unpainted)
2KO-843-871-J..Rail
7HO-843-658-A..Rear clip
also one home made clip
Did this all come to £26.00 (plus painting?)
Will be ringing my dealer tomorrow if so
2KO-843-871-J..Rail
- Salty
tommyzooom wrote:Thanks Salty
2KO-843-871-J..Rail
cover = £26
rail = £21
clip = can't remember, had to buy a packet so got loads of spares
home made bracket = years of experience of making things
paint = working in the right place
- tommyzooom
Phoned the dealer today to order all the bits, They are on back order from Germany It'll take about two weeks .I guess everybody on here ordered a set!!
btw the rear clip was available@0.75p each
- dan81
Salty wrote:done it last night
hi salty wot size is your wheels
- Salty
17x 7.5 I think
- tommyzooom
Just an update on the side rail, Have fitted mine now,
I saw a caddy life in the showroom and investigated the mysterious front clip! It appears to be pressed metal and is part of the side panel!!!!, certainly nothing that can be ordered separately
