Page 2 of 2
Re: 2021-Lockdown-Project-Maxi-Life
Posted: Mon Apr 05, 2021 10:58 am
by DragonWorld
Then for the first bit of carpet. The creases were from the carpet being folded in the box and I didn't manage to get enough glue on the inside so will be re-doing it
Posted: Mon Apr 05, 2021 11:03 am
by DragonWorld
The next task is to fill the gaps on the floor and edge it after the flooring is in and to try and make a box for the wheel arches....This is something I don't look forward to as my enthusiasm far out weighs my skill level
Posted: Mon Apr 05, 2021 11:04 am
by DragonWorld
@Eyteyek - Good work - Glad to help buddy.
Posted: Sat Apr 10, 2021 11:28 pm
by Smithers61
Thanks for posting this build, I'm a newb hoping to do something similar so it's very helpful.
Posted: Fri Apr 16, 2021 3:55 pm
by DragonWorld
Posted: Fri Apr 16, 2021 3:57 pm
by DragonWorld
The handles were recycled from the ramp and attached onto the rear tailgate so the storage under the floor could be accessed.
A little bit of hammerite for the screws is all that is needed.
Posted: Fri Apr 16, 2021 4:00 pm
by DragonWorld
Next was the roof carpeting. This could have gone better....I felt like I needed two pairs of hands :-)
Still the edges where the glue hasn't taken will be covered with the designs I have for the 30cm x 36cm recesses.
Posted: Fri Apr 16, 2021 4:03 pm
by DragonWorld
Posted: Fri Apr 16, 2021 7:23 pm
by Giddy
Are you using the right stuff? Doesn't look like it's a 4-way stretch carpet
Posted: Sat Apr 17, 2021 11:03 am
by DragonWorld
It bought the one from
https://www.megavanmats.com/lining-carpet-info/
I suspect this is my cack practical skills
Posted: Sat Apr 17, 2021 11:09 am
by DragonWorld
Interestingly the top trims in the rear are able to be vinyl wrapped which is a bit different. So you can create your own designs. The 1m printable material is £85 but an option
Posted: Sat Apr 17, 2021 11:34 am
by Tdsmithuk
What are you planning on doing with the ramp section? Is there room for storage or something underneath?
Posted: Sat Apr 17, 2021 12:19 pm
by DragonWorld
I have the underneath as storage yeah, the handles pull down and gives access. It's really handy.
Posted: Thu May 06, 2021 3:25 pm
by Sjp123
HI dragon world,
The conversion looks great. I've just started converting my caddy maxi life. just wondering if you glued or screwed your ply floor down and are the boxed over the wheel arches screwed in also?
Keep posting updates,
BW
Sam
Posted: Thu Jul 22, 2021 12:16 pm
by trmatthe
Hi DragonWorld,
I've been looking through the forums for some sound deadening/thermal insulation and the Dodo stuff seems to crop up quite regularly. Given that yours has been in a while now, how would you rate it?
I'm looking to line some/most of the rear of a maxi but I'm going to be limited to walls and roof as the floor will have dog crates and an area for the dog to just sit. There is currently the ex-BG rubber floor mat so I think the floor is ok, and is probably the best solution for a quite chompy German Shephard.
From looking at the way the dodo is bonded to the panels I guess it's unlikely she'd be able to start chomping and pull much off especially as she'd be spotted in a few seconds and told to stop
But the main goal is to try to stop heat transfer from outside, and also to cut down on the booming we get driving on the lumpy country roads around here.
Would be very appreciative of any advice you've got.
