Long time ago, back in the mists of time !
It is all in the tread. Basically the middle knob is a little bar steward. Push from the back if I remember (but I don't really) ?
The complete disassembly method is easier in many ways but has it's own pitfalls with alignment and is more time consuming.
Heater control button removal ???
- liamg20025
Re: Heater control button removal ???
Okey doke, cheers.
I’ll apply more pressure!
You wouldn’t have a drawing showing which pins/test points are for knob illumination (LEDs)?
Cheers,
Liam
BG VW Caddy Maxi 1.6tdi 64plate - Currently converting to a camper
Liam
No circuit diagrams for the PCB.
You can see the LEDs easily enough though ...
- liamg20025
Yah I can see the LEDs, just wanted to bench test the new ones before I put it all back together. I’ll just bell out the cable that’s live when I turn the lights on.
So I managed to get the middle knob off by prying the legend plate off and the knob just popped off.
I maybe loosened it with a combination of pulling like F*** and using a terminal driver and hammer that to tap the rear of what I thought was the knob. Turns out that’s a a hollow shaft that sits behind the PCB, so hitting that wasn't the way
Did you replace the 90Deg SMD LEDs too?
Cheers for the help so far!
Cheers,
Liam
Liam
@Papa Bear did the LED changes on his panel (and everywhere else) so would be the source for info, but not been around for a while ... !
- liamg20025
Yeah I saw. Sounds like he’s been busy lately.
Looks like the 90 deg SMD ones are also red, so will need swapping out.
Cheers,
Liam
Liam
