It could also be a simple wiring fault in the new loom or a plug that’s not seated correctly,especially the one to the lock, not the easiest plug to fit.
Anyone retrofitted electric windows from Touran?
- C Chis
Re: Anyone retrofitted electric windows from Touran?
That’s a really good point, I’ll need to take it back apart and check the latch connector is fully seated, what a ball ache
Cheers mate!
Cheers mate!
Building a 2009 Caddy PD105. Clean base 68K in white. Touran donor ready to be ripped to pieces! Front end conversion in progress.
- C Chis
Check the routing of the cable as well! It could get pulled apart by the window mechanism if it’s not routed and clipped in the right places
Good luck and report back what you find
I’ll have a bash tomorrow and let you know how I get on, cheers!
Fitted the other side today, everything works fine with the Caddy latch, I just have to assume the drivers side latch is faulty, I’ll fit the latch next week. Cheers for your help guys
