I'm doing this conversion at the min.
I've swapped the ecu over end also the steering rack/subframe
I've been told I need to swap some wires over in fuse box. Could I just swap the fusebox from the tauran.
Which wires did you change for the vac solenoid?
Bls to bkd caddy
Re: Bls to bkd caddy
how did you get on with the wires ive got the vac box with 6 wires but need to know what pins are for the n75 on my bkd ecu i will do away with the vac box and use n7t when i know which wires i need thanks
I don't suppose there is a detailed answer to this boost vacuum wiring issue is there as I have just purchased, by accident, a Caddy that has had this conversion done, but the boost solenoid hasn't been wired in and I have have a two pin plug...... cheers
