Loom swapped tfsi caddy
Can anyone help with a few issues I'm having. I have heavy steering and can't access the steering angle sensor via vagcom. The van has a complete mk5 loom in it. DOC I NEED YOUR HELP
- Lister79
Welcome to the forum….
First place I’d start is looking to make sure the vehicle coded correctly for the Steering angle location dependant on which modules has been used.
Then it’s the completion of the basic Settings (each one following input of security access code).
Re: Loom swapped tfsi caddy
Hmmm, you don't specifically need my help, there's lots of knowledgeable folk on the forum.
First up, a full Autoscan will help determine where you have issues. Post that up and we will take it from there.
- C Chis
Welcome to the forum!
Couple of questions….
Did your Caddy have hydraulic or electromechanical power steering before you swapped the engine?
What are the error Codes (typically found in address 44 steering assist): 02546 and 00778?
What year is your Caddy?
Thank you all I'm a old member just couldn't access old account I've had vag com done and we can't access the steering angle sensor on the options
1ko953549e that's the steering angle sensor part number i have. Doc, a few years back I met you to sort this issue on my 1.8 20v brown with gold if you remember. I'm wondering if all the components are talking to each other. I've been told mk5 golf has angle sensor in rack, so what if its a caddy rack and it can go on
My caddy is 05 and the golf inside is o6 I have both lot of details for vehicles used
Reason: combined two posts in one
I've seen thousands of Caddys buddy, I can't say I recall a 1.8 brown & gold.
If you can post an Autoscan, it will help identify what exactly is going on. I've never tried to communicate directly with a steering angle sensor, it's one of those things that I usually look at measurement from via ABS or Steering assist depending on which ABS is fitted.
You've tried the G85 calibration procedure on the Ross-Tech site?
You met me at services I filled you back to your house you sorted my clocks sat in the back of my van. Anyway I will get the print out for codes for you all thanks again all. What's the g85 procedure
- dan@biali
Should find the G85 calibration procedure on here http://wiki.ross-tech.com/wiki/index.php/00778
Thank you guys
- C Chis
Did you get your steering sorted?
Did you ever solve this issue? I have same problem.
Tuesday,09,April,2024,19:01:18:05844
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WVWZZZ1KZ6W117779 License Plate: LTEST
Mileage: 245490km-152540mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 09 0F 15 16 17 19 25 42 44 46 52 56
VIN: WVWZZZ1KZ6W117779 Mileage: 245490km-152540miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
04-Steering Angle -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 J HW: 1K0 907 115 F
Component: 2.0l R4/4V TFSI 0030
Revision: --H14--- Serial number: VWZ7Z0E3138876
Coding: 040300031C030060
Shop #: WSC 00191 264 15243
VCID: 2D071AB811105322B45-8078
VINID: 9E69EAAAA05BA869C10471C72499FB1438
No fault code found.
Readiness: 0110 0101
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 043 T HW: 02E 927 770 AE
Component: TVS ST2+ 070 1899
Revision: 04507000 Serial number: 00000605290973
Coding: 0000020
Shop #: WSC 06314 000 00000
VCID: 2517E29849E06B627C5-8070
1 Fault Found:
18036 - Powertrain Data Bus
P1628 - 000 - Missing Message from Steering Angle Sensor
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 255
Reset counter: 40
Mileage: 245497 km
Time Indication: 0
Address 03: ABS Brakes Labels:. 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AF HW: 1K0 907 379 AF
Component: MABS MK70M 0104
Revision: 00H32001
Coding: 0020801
Shop #: WSC 35110 377 00154
VCID: 76B5F5D4A4C650FA05F-8022
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 01000009409559
Coding: 00804F030004100057000000000000000008FB0F5C000120000000000000
Shop #: WSC 35110 377 08192
VCID: 323D09C4082E0CDAE97-8066
Subsystem 1 - Part No: 2K2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 250209 021 0501
Coding: 00038805
Shop #: WSC 35110
1 Fault Found:
00156 - Control Circuit for Windshield Washer Pump
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 37
Mileage: 245497 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.15 V
ON
ON
OFF
OFF
OFF
Address 0F: Digital Radio
Cannot be reached
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 2Q AIRBAG VW52 025 2400
Revision: 06025000 Serial number: 0037TR03TWMN
Coding: 0012881
VCID: 7DA7EAF881F003A2445-8028
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 752 0101
Coding: 0012112
Shop #: WSC 06402 785 00200
VCID: 78A9FBECAED2268A173-802C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 007 0050
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K6 920 962 D
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0002403
Shop #: WSC 00403 067 57207
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 280309F1001884
Coding: ED801F02000302007401
VCID: 372B38D0E34CE9F2DE9-8062
2 Faults Found:
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 37
Mileage: 245497 km
Time Indication: 0
Date: 2000.00.00
Time: 00:24:43
02649 - Digital Radio Tuner
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 37
Mileage: 245497 km
Time Indication: 0
Date: 2000.00.00
Time: 00:24:47
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 4312
Shop #: WSC 00243 210 91001
Address 42: Door Elect, Driver Labels: 1K0-959-793.lbl
Part No: 1K0 959 793
Component: Tuersteuergeraet 02 0160
Coding: 0000000
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
Shop #: WSC 02069 000 90108
VCID: 353732D8F9401BE2CC5-8060
2 Faults Found:
02546 - Steering Limit Stop
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Mileage: 245480 km
Temperature: 24.0°C
Voltage: 14.30 V
Voltage: 14.10 V
Freeze Frame:
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 008A0C087F2D84054858010000C0
VCID: 0059930CF6026E4A2F3-8054
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-792.lbl
Part No: 1K0 959 792
Coding: 0000000
VCID: 75B7F2D8B9C05BE20C5-8020
Address 56: Radio
Cannot be reached
End----------(Elapsed Time: 00:50, VBatt start/end: 14.2V/14.2V)-----------
www.Ross-Tech.com
Coding: 0000020
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 245497 km
Time Indication: 0
Revision: 00H32001
Coding: 0020801
Coding: 00038805
Shop #: WSC 35110
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 37
Mileage: 245497 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.15 V
ON
ON
OFF
OFF
OFF
Cannot be reached
Coding: 0012881
Coding: 0012112
Coding: 0002403
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 37
Mileage: 245497 km
Time Indication: 0
Date: 2000.00.00
Time: 00:24:43
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 37
Mileage: 245497 km
Time Indication: 0
Date: 2000.00.00
Time: 00:24:47
Coding: 0000000
2 Faults Found:
Freeze Frame:
Mileage: 245480 km
Temperature: 24.0°C
Voltage: 14.30 V
Voltage: 14.10 V
Freeze Frame:
Component: KSG 0401
Coding: 0000000
Address 56: Radio
Cannot be reached
