The sloth build
- Mrsloth
The sloth build
So here is my first caddy - I've had a T5 previously but wanted a smaller van so I found this.
The ride height I'm a little undecided about, while this will be used for work I think it still sits a little too high.
My first thoughts are to sound proof and carpet the rear as it's a little too noisy for my liking, as it's been lined again it's a good base to start with I think.
- Mrsloth
- Mrsloth
Re: The sloth build
The A3 8V dash vents you have in your van need an adapter to the rear duct.
I'm sure I've seen these on ebay for £25 or there about.
I believe all highline vans from 2011-2015 had Bluetooth hands free as standard, this is a separate module which is located under the right side front seat, about 75mm below the rubber/carpet.
- Beaker2135
Re: The sloth build
What DOC said plus for work I found 60mm lowering springs worked well for me. I’m not a fan of coilovers though
- Mrsloth
Re: The sloth build
That makes sense, at least there is a solution so I’ll get some ordered.Doc wrote:The A3 8V dash vents you have in your van need an adapter to the rear duct.
I’ll look tomorrow but that should make upgrading a little easier
- Mrsloth
Re: The sloth build
I share that sentiment on coilovers so I’ll have a look, is there a preferred option as I can see eibach on eBay that might tempt me.Beaker2135 wrote:What DOC said plus for work I found 60mm lowering springs worked well for me. I’m not a fan of coilovers though
- Beaker2135
Re: The sloth build
I had Eibach on mine and they were great. Don’t forget you’ll need an axle flip kit for the rear axle. I think Eibach do a kit I know for sure they do a 45mm kit so can’t see why there wouldn’t be a 60mm one
- Mrsloth
- Mrsloth
Re: The sloth build
For some reason I didn’t get the before measurements despite showing me them but it was off the scale before.
Despite this it’s still pulling slightly to the left which is annoying - what would cause this usually?
Re: The sloth build
Front right camber is a bit excessive but not much you can do.
Is it pulling to the left of centering the wheel, if you hold the wheel dead straight does it drive straight but pull the wheel off straight if you release it? I've seen quite a few where the steering angle sensor calibration is out and it self centres the rack to somewhere other than dead straight ahead.
- Mrsloth
Re: The sloth build
With wheel straight let go and it steers to the left, it was worse before the alignment.
Re: The sloth build
Try a steering angle sensor calibration.
- Mrsloth
Re: The sloth build
I’ll give that a shot
Re: The sloth build
From what I see in the 3rd picture, you have a RNS 510, not RNS 310(from what I know, these models didn't have bluetooth at all)
I have RNS315 from factory, with bluetooth but I have no bluetooth module under the seat, I think it's integrated in the unit.
What Doc said it's valid just for RNS510?
Current built thread: 2013 SWB Caddy 2.0TDI
viewtopic.php?f=13&t=48634
My previous built: 2007 SWB Caddy 1.9TDI
viewtopic.php?f=13&t=39945
