Caddy conversion Abs coding problem
Hi
Ive just converted my 2005 SDI caddy to 1.9tdi from a 2008 Touran, I have used the clocks key and ecu everything is up and running minus the glow plug wiring which is easy just haven't got around to it, however I am having some trouble with the ABS coding, i Have move the link wire from pin 25 to pin 19 and coded as a Touran 0017089, but i still get control module incorrectly coded, I assume its something todo with the Vin numbers?
My caddy has ASR and the Touran had ESP, I can code ASR out channel 90 but abs light still on the dash, ASR is coded back in just an FYI.
cant get the steering light off due to the abs prob,
any help would be greatly appreciated
VCDS Version: 23.3.1.0
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WVGZZZ1TZ8W124653 License Plate: K15 URN
Mileage: 257120km-159766mi Repair Order:
Chassis Type: 1T (1K0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56
VIN: WVGZZZ1TZ8W124653 Mileage: 257120km-159766miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 021 ML HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 0510
Revision: --H07--- Serial number: VWX7Z0H03NT16J
Coding: 0050032
Shop #: WSC 66565 257 00032
VCID: 75E154D31CC13F3BE8-8020
VINID: 9E65EAAAA064A889C10841850C0800237F
6 Faults Found:
013112 - Control Circuit for Glow Plug Controller 1
P3338 - 000 - Electrical Malfunction
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 257126 km
Time Indication: 0
Date: 2000.00.00
Time: 00:34:03
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 11001100
Temperature: 14.4°C
Bin. Bits: 01010000
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 000 - Signal too High
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 257126 km
Time Indication: 0
Date: 2000.00.00
Time: 00:34:03
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 11001100
Temperature: 14.4°C
Temperature: 15.3°C
005785 - Powertrain Data Bus
P1699 - 000 - Missing Message from Steering Wheel Electronics
Freeze Frame:
Fault Priority: 3
Fault Frequency: 24
Reset counter: 255
Mileage: 257126 km
Time Indication: 0
Date: 2000.00.00
Time: 00:34:04
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 11001100
Bin. Bits: 00000000
(no units): 0.0
005685 - Powertrain Data Bus
P1635 - 000 - Missing Message from A/C Controller - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 255
Mileage: 257126 km
Time Indication: 0
Date: 2000.00.00
Time: 00:34:04
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 11001100
Bin. Bits: 00000000
(no units): 16.0
005716 - Please check DTC Memory of Instrument Cluster
P1654 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 257126 km
Time Indication: 0
Date: 2000.00.00
Time: 00:50:59
Freeze Frame:
RPM: 882 /min
Speed: 14.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Temperature: 18.0°C
Temperature: 28.8°C
Temperature: 17.1°C
053273 - Control Module for Instrument Cluster
U1019 - 000 - Missing Signal for Oil Level/Temperature - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 255
Mileage: 257127 km
Time Indication: 0
Date: 2000.00.00
Time: 01:00:07
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 11001100
Bin. Bits: 00000000
(no units): 33.0
Readiness: 0 0 0 0 X
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.clb
Part No: 2K0 907 379 A
Component: ASR FRONT MK70 0105
Coding: 0017089
Shop #: WSC 35110 377 00160
VCID: 3169A0C3A829531B74-8064
1 Fault Found:
01044 - Control Module Incorrectly Coded
008 - Implausible Signal
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 M HW: 1K0 937 049 M*
Component: Bordnetz-SG H37 0803
Revision: 00H37000 Serial number: 00000001644685
Coding: 00884F020004100000000000000000000008FB075C
Shop #: WSC 35110 067 57207
VCID: 397998E370599B5BCC-806C
Subsystem 1 - Part No: 2K2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW357 012 0402
Coding: 00065493
Shop #: WSC 35110
2 Faults Found:
00988 - Lamp for Brake Light; Right (M10)
012 - Electrical Fault in Circuit
02399 - Control Circuit for Terminal 30 for Interior Illumination
009 - Open or Short to Ground
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 09 AIRBAG VW52 023 2400
Revision: 04023000 Serial number: 0037TD068UR.
Coding: 0012345
VCID: 7DF14CF324F1677BA0-8028
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 E HW: 1K0 953 549 E
Component: Lenksäulenmodul 021 0050
Coding: 0000002
Shop #: WSC 35110 377 08192
VCID: 3467A9D7573B66331F-8060
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1T0 920 964 A HW: 1T0 920 964 A
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0H03NT16J
Coding: 0000401
Shop #: WSC 00688 210 89628
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H11 0110
Revision: 11 Serial number: 29001053030900
Coding: 3D0F0140079001
VCID: 295948A380F92BDBBC-807C
2 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 16
Reset counter: 235
Mileage: 257127 km
Time Indication: 0
Date: 2000.00.00
Time: 01:12:20
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 235
Mileage: 257127 km
Time Indication: 0
Date: 2000.00.00
Time: 01:12:24
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1212
Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver Labels: 1K0-959-793.lbl
Part No: 1K0 959 793
Component: Tuersteuergeraet 02 0160
Coding: 0000000
VCID: 76E353DF01C73423E1-8022
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.12 1502
2 Faults Found:
02546 - Steering Limit Stop
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Mileage: 7120 km
Temperature: 24.0°C
Voltage: 13.90 V
Voltage: 13.70 V
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 00020408000084040818010010C0
Shop #: WSC 00520 210 91513
VCID: 79F958E330D95B5B8C-802C
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
2 Faults Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
012 - Electrical Fault in Circuit - Intermittent
02483 - Module for Locking of Rear Lid (F327)
Address 52: Door Elect, Pass. Labels: 1K0-959-792.lbl
Part No: 1K0 959 792
Coding: 0000000
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 01:15)--------------------------
VCDS Release 23.3.1: SRI Reset
Control Module Part Number: 1T0 920 964 A Labels: 1K0-920-xxx-17.lbl
Component:KOMBIINSTRUMENT VDD 1212, Coding:0000401
Operation: Please select an operation
Channel Description Unit Current val. New val.
02 Service Reminder Status 0 ---
40 Distance since Service miles x100 0 ---
41 Time since Service Days 0 ---
42 Minimum Distance to Service --- --- ---
43 Maximum Distance to Service --- --- ---
44 Maximum Time to Service --- --- ---
45 Oil Quality 1 ---
47 Soot Quantity km x100 0 ---
48 Thermal Load km x100 0 ---
49 Minimum Time to Service --- --- ---
50 Basic Distance Value for Oil Change miles x100 93 ---
51 Basic Time Value for Oil Change Days 372 ---
Address 03,2K0 907 379 A,channel 90,adapted from,1,to,0,
Address 03,2K0 907 379 A,channel 90,adapted from,0,to,1,
Address 0x44,1K2 909 144 H,Basic Settings,Group 001
Address 0x44,1K2 909 144 H,Basic Settings,Group 002
Address 0x44,1K2 909 144 H,Basic Settings,Group 003
Address 0x44,1K2 909 144 H,Basic Settings,Group 004
Address 0x44,1K2 909 144 H,Basic Settings,Group 005
www.Ross-Tech.com
Coding: 0050032
6 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 257126 km
Time Indication: 0
Date: 2000.00.00
Time: 00:34:03
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 11001100
Temperature: 14.4°C
Bin. Bits: 01010000
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 257126 km
Time Indication: 0
Date: 2000.00.00
Time: 00:34:03
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 11001100
Temperature: 14.4°C
Temperature: 15.3°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 24
Reset counter: 255
Mileage: 257126 km
Time Indication: 0
Date: 2000.00.00
Time: 00:34:04
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 11001100
Bin. Bits: 00000000
(no units): 0.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 255
Mileage: 257126 km
Time Indication: 0
Date: 2000.00.00
Time: 00:34:04
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 11001100
Bin. Bits: 00000000
(no units): 16.0
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 257126 km
Time Indication: 0
Date: 2000.00.00
Time: 00:50:59
Freeze Frame:
RPM: 882 /min
Speed: 14.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Temperature: 18.0°C
Temperature: 28.8°C
Temperature: 17.1°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 255
Mileage: 257127 km
Time Indication: 0
Date: 2000.00.00
Time: 01:00:07
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 11001100
Bin. Bits: 00000000
(no units): 33.0
Coding: 0017089
1 Fault Found:
Coding: 00065493
Shop #: WSC 35110
2 Faults Found:
Coding: 0012345
Coding: 0000002
Coding: 0000401
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 16
Reset counter: 235
Mileage: 257127 km
Time Indication: 0
Date: 2000.00.00
Time: 01:12:20
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 235
Mileage: 257127 km
Time Indication: 0
Date: 2000.00.00
Time: 01:12:24
Coding: 0000000
1 Fault Found:
2 Faults Found:
Freeze Frame:
Mileage: 7120 km
Temperature: 24.0°C
Voltage: 13.90 V
Voltage: 13.70 V
Freeze Frame:
Component: KSG 0401
2 Faults Found:
Coding: 0000000
Address 56: Radio
Cannot be reached
Re: Caddy conversion Abs coding problem
Welcome to the forum.
Did you find a Autoscan from a Touran with mk70 ABS pump to determine if the coding you have used is possible?
I suspect that although the Touran is listed as a coding option within VCDS, there may not have ever been a Touran with mk70.
No I didn't autoscan a touran , I still have the touran albeit with the engine etc missing, what are my options can I get it to work? Or can I fit the abs pump from the touran?
I've plugged this in quickly to odis and it says that the vin in the abs is different to that off the vehicle which is now seen as a touran.
How do I get the abs unit to accept the new vin, or do I need to get a new abs unit and fit?
Could I use the tourans abs pump? The only thing is the wiring plug is different but was thinking maybe I could swap the plugs with the help of wiring diagrams
Or if anyone could recomend someone who could fix this issue I'm willing to pay what ever, I have an mot due in a few months
If you have ODIS, you have the equipment to do it yourself.
Fit your original caddy instrument cluster, adapt the ECU immobiliser to that instrument cluster. Then fit the Touran instrument cluster and adapt that to the newly adapted ECU.
Then you have the correct VIN in your instrument cluster, ECU and ABS.
This also means your ABS will run the correct stability program for your chassis and not that of a Touran meaning it'll be safer for you and everyone on the road.
- Bahnstormer
Sorry for the thread hijack - does anyone know if this is the same case with what I'm trying to do at the moment?
I've got a 2011 Touran 2.0 TDI, I'm moving the engine, gearbox, ECU and clocks into my 2012 Caddy. I'll put the Caddy key blade into the Touran key, so I don't need to change the locks. I've autoscanned both vehicles and they both appear to have the same ABS module (MK60EC1).
Assuming I do need to adapt the ECU/clocks/ABS etc. where's the best place to get the necessary bits for ODIS from? I'm assuming VCDS can't do what I need it to?
VCDS will allow you to code the ABS but there is little in the way of a long coding helper, you will need to copy across the coding from the Touran ABS.
Ideally, you would adapt the whole setup to your Caddy VIN and keep your ABS coding the same but to invest in ODIS to do this might be a little extreme.
- Bahnstormer
Ok got it, thanks Doc
- Bahnstormer
@Doc - quick question, do I also need to need to move the link wire (as per the OP)? I've tried pasting the Touran coding in, however it reverts back to all zero's if I switch the ignition off.
The original post in this topic wasn't for a mk60EC1 ABS module, you don't have a link wire.
If the coding is accepted then it is correct, you need to do all the basic settings to make it "stick".
- Bahnstormer
I was confusing myself with the ABS modules
It's does say "Coding accepted" initially, then reverts back if I cycle the ignition. What you said about the basic settings stuff makes sense, I think I saw a video about that by Ross-Tech.
Thanks Doc!
Thanks Doc!
- Lea2kcaddy
Hey mate, how did you get on with this conversion?
- Bahnstormer
Me or the OP?
Mine's all done, not sure about OP though.
Hi All sorry To Just Jump on the post I'm about to take on the SDI Conversion to 1.9pd130 have any of you got any links to the forms or but more information on exactly what needs to be done / used I'm buying a complete pd130 MK4 golf as a doner car any help would be much appreciated!
