Noise driving me insane
Posted: Sun Mar 17, 2024 5:36 pm
by dontknowz
Hi guys my vans driving me up the wall with a squeak that ive been trying to narrow down, only does it when the van is on and can only be heard from the inside/ next to the door only does it when you let the rpm drop back down to idle but it almost always does it and cant be heard in the engine bay it’s seriously driving me insane, anyone got any ideas on what it could be?
Re: Noise driving me insane
Posted: Sun Mar 17, 2024 7:40 pm
by PJD
As a general rule
Thrust bearings whine.
Wheel bearings grumble.
Belts squeal.
If you can't hear it when it's stationary with your head in the engine bay and it is only audible when at idle and moving, what happens when you drop the clutch at speed?
Posted: Sun Mar 17, 2024 8:39 pm
by dontknowz
When you blip the accelerator as it comes back to idle it almost always squeaks, it’s definitely not belts as I’ve not long had a new front main ,timing and aux belt ,tensioners water pump all that and its not audible in the engine bay at all which is frustrating as i cant understand what would squeak inside the van I’ve ruled out the pedal due to not making the noise when the van is off, if you dip the clutch it will also squeak, does it while driving while stationary and does it the most at lower rpm when releasing the accelerator for some reason i was thinking it could be related to my cracked windscreen or my cluster but very doubtful that it’s actually any of those causing it, only other thing i can think of is engine mounts or maybe a injector or control flap but cant understand why its not audible in the engine bay if it is those or maybe egr with it being further back at close to the firewall?
Posted: Sun Mar 17, 2024 11:35 pm
by BenT
Could it be the lower gearbox (dogbone) mount/bush? The engine normally tugs on this when you blip the throttle so it might be worth spraying it with WD-40 or suchlike. One of the bolts on mine worked loose a few weeks back and made the whole cab vibrate, couldn't hear it under the bonnet. But it was apparent from below. Perhaps have a listen underneath? Could also be an exhaust mounting...
Posted: Mon Mar 18, 2024 11:35 am
by dontknowz
Checked my lower gearbox mount and its doesnt look too
bad idk it it’s supposed to have that split in the top bit or not tho?
My drive shaft shield was also completely loose so that definitely hasn’t been helping, could be that but need get the van dan to test. My fan is also squeaking only the left side tho right is fine does sound very similar to the noise I’m hearing
Posted: Tue Mar 19, 2024 6:29 pm
by dontknowz
It wasn’t my drive shaft shield or my fan still insure what could be the cause does the egr or waste gate open or close at such low rpm?
Posted: Tue Mar 19, 2024 7:44 pm
by Alex mc
@dontknows could the back of the seat be tight to the bulkhead as it could cause a squeak caused by a he vibrations making it rub while at idle.
Are you able to post a short video clip of it making the noise ?
Posted: Wed Mar 20, 2024 11:27 am
by dontknowz
Yeah I’ve got a few videos of it doing it but idk how to post videos on here, with it not being a work van i removed it months ago its a bike van so everything’s tied down.
Posted: Thu Mar 21, 2024 5:28 pm
by dontknowz
Ive put it on YouTube hopefully someone has heard it before because it’s driving me up the wall
https://youtube.com/shorts/YpRYn32_G-k? ... 2AIrwgJANI
Posted: Thu Mar 21, 2024 7:52 pm
by Damo2k
Does it make this noise with clutch depressed?
Posted: Thu Mar 21, 2024 8:59 pm
by Doc
I'd be surprised if that is not a turbo actuator or EGR valve/cooler related noise.
Can you get some oil on those to eliminate them?
Posted: Thu Mar 21, 2024 10:34 pm
by dontknowz
Doc wrote:I'd be surprised if that is not a turbo actuator or EGR valve/cooler related noise.
I can try would it need to be high temp stuff due to where it is? If it’s the egr i don’t think id be able to oil it without taking it apart?
Posted: Thu Mar 21, 2024 10:35 pm
by dontknowz
Damo2k wrote:Does it make this noise with clutch depressed?
Usually this will happen if I depress the clutch while driving soon as the rpm drops it squeaks, ill check tomorrow at a stand still with the clutch depressed
