MK4 Caddy Highline Cluster Upgrade - Need Someone to Code & Fit
Posted: Wed Mar 27, 2024 8:45 pm
Hi,
Is anyone close to Portsmouth who can do a Highline cluster upgrade for me as part of my ACC upgrade?
Happy to pay, of course.
I don't mind travelling but prefer to be as close as possible.
Have a cluster here ready 2K5920 976E - Fingers crossed its the one I need.
Code: Select all
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 13 15 16 17 19 25 42 44 46 52 61
VIN: WV1ZZZ2KZGX134566 Mileage: 79590km-49454miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (J623-DFSD) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 GT HW: 04L 907 309 K
Component: R4 2.0l TDI H20 4648
Revision: 8AH20--- CVN: EFE98D0492F1EF3C
Coding: 01110012040509090000
Shop #: WSC 00028 210 00000
ASAM Dataset: EV_ECM20TDI01104L906016GT 004004
ROD: EV_ECM20TDI01104L906016GR_004.rod
VCID: 015F951C818BCDA220D-8054
VINID: 9E606AAAA09BA97A010C414618B8FA0D89
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 41026000001427
Coding: 1479409B9265A482287A027C498825E379F100
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDB53E4B7FF7B52169-806A
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 1K8 907 426 AH HW: 1K8 907 426 AH
Component: AC Manuell H20 0808
Revision: 00001002
Coding: 0010004003
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW32.rod
VCID: 79AFFDFCE95B956268D-802C
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 085 AD HW: 5K0 937 085 AD
Component: BCM PQ35 B+ 122 0183
Revision: BB122001
Coding: 411A583A8025086B08800082900000640301000842028060648087000041
Shop #: WSC 35110 377 08192
VCID: 75B7F1CCC5C3F1020C5-8020
Subsystem 1 - Part No: 2K2 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 21031 26 0512
Coding: 009795
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 1K8 919 465 HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0479
Revision: -------- Serial number: 39291609003540
Coding: 0001050001
ASAM Dataset: EV_EPHVA14VW364GP00 001006
ROD: EV_EPHVA14VW364GP00_VW36.rod
VCID: 76B5F6C0D845FA1A05F-8022
1 Fault Found:
12718592 - Databus
U1121 00 [00001001] - Missing Message
[Steuergerät für Lenksäulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 79599 km
Date: 2024.03.06
Time: 00:45:45
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7N0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 1609220468A35A Dataset Number: V03935300XU 0001
Coding: 00008000FE1339
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361.rod
VCID: 363536C098C5BA1AC5F-8062
1 Fault Found:
1541 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [00001001] - -
[FAULT_MISALIGNMENT_VERTICAL]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 189
Mileage: 79599 km
Date: 2024.03.06
Time: 00:45:45
Control Module temperature: 24 °C
Voltage terminal 15: 11.7 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 2K5 959 655 B HW: 2K5 959 655 B
Component: VW10Airbag00K H08 0018
Revision: -------- Serial number: 003V10001KKX Dataset Number: 2KC003V__A_ 0765
Coding: 00000000000000000000000000000000304B
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3B2327F4A3E767723A1-806E
Crash sensor for side airbag: driver side:
Serial number: 3497ARB404T3VJOSPP05
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3507ARB404T3UMCIH0C%
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 521 FG HW: 5K0 953 569 BC
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20151008101425
Coding: 0000040000
Shop #: WSC 00020 999 12345
ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
ROD: EV_SMLSNGVOLWSR8C.rod
1 Fault Found:
267264 - Control Module Incorrectly Coded
U1014 00 [00001001] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 189
Mileage: 79599 km
Date: 2024.03.06
Time: 00:45:45
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 2K5 920 966 A HW: 2K5 920 966 A
Component: KOMBI H04 1009
Serial number: 00000000000000
Coding: 4802000200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 33330FD48BB7AF32E21-8066
1 Fault Found:
13654544 - Databus
[Steuergerät für Telefon keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 79599 km
Date: 2024.03.06
Time: 00:45:45
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 BG HW: 7N0 907 530 AN
Component: J533 Gateway H56 1673
Revision: H56 Serial number: 020416F1002450
Coding: 357421
VCID: 76B5F6C0D8C5FA1A05F-8022
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 1009
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DD2B09CFD2EFA917-803E
Address 42: Door Elect, Driver Labels: None
Part No SW: 2K5 959 701 A HW: 2K5 959 701 A
Component: Tuer-SG 009 2144
Coding: 0135730
VCID: 323D0AD0782DA63AE97-8066
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 140 3501
Revision: 00H22000
VCID: 392F3DFCA55B556228D-806C
Address 52: Door Elect, Pass. Labels: None
Part No SW: 2K5 959 702 A HW: 2K5 959 702 A
Coding: 0135730
VCID: 33330FD48737AF32E21-8066
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1673
Coding: 030F1873
VCID: 71BFC5DCB1ABDD22D0D-8024
Subsystem 1 - Part No SW: 1K0 915 181 K HW: 1K0 915 181 K
Component: J367-BDM H07 0223
Serial number: 43091828248761826400
