alloy wheel upgrade
Eye'd a nice Caddy?
Maybe a member off the forum
What, Where, When in title please.
R11dyw
alloy wheel upgrade
Post by R11dyw »
Hi, New to the forum so please excuse if this topic has been touched on many times before. I have recently purchased a 2016 mk4 swab caddy the highline model. It can with standard 15โ€ alloys. They look lille small on the van. I do not want to put big wheels on but was thinking 17โ€ would look better. I have searched and looked at fleecy and seen many that look ok. I just want to know your thoughts and what VW/Audi/Or any others that will be a straight swap without any adaptations. I am aware that the stud pattern needs to be 5x112 and the centre hub and offset confuse me and what options i have without adaptations
Thank you in advance
Gingerwolf
Re: alloy wheel upgrade
Post by Gingerwolf »
I also have a mrk4 highline with 15ins I am upgrading to 18s to allow for bigger brakes. You can fit any off the vag range wheels on your van. ๐Ÿ‘
jackel
Post by jackel »
Wheels off the new caddy fit lovely as well . Got a set on mine and speedo is bang on
Grzesiek112
Post by Grzesiek112 »
All golf V VI VII rims and models derived to caddy mk3 mk4
to 17 alloy tire size is 205/50 r17 .
orginal size caddy rims is 6x17 et50, 5x112 cenrtal hole 57,1 mm. but 6,5' 7' fit without a problem
2K 1.9 TDI {sold} & 2C 2.0 TDI & 2xSA 2.0 TDI+
Jeff84
Post by Jeff84 »
jackel wrote: โ†‘Sun May 05, 2024 5:36 pm Wheels off the new caddy fit lovely as well . Got a set on mine and speedo is bang on
Arenโ€™t the mk5 caddy wheels 5x120 instead of 5x112 though
jackel
Post by jackel »
Nope fit perfect 17" 1s on my caddy 4
Smashplant
Post by Smashplant »
Got a caddy mk4 now and Iโ€™m putting 17โ€™ alloys on soon. They some aftermarket alloys from a golf mk5.
The caddy is on 16โ€™ Vw standard alloys.
If I was to uprate to big brake callipers, could anyone tell me plz would either of these sets of wheels fit?
sylvaintheb
Post by sylvaintheb »
jackel wrote: โ†‘Sun May 12, 2024 5:41 pm Nope fit perfect 17" 1s on my caddy 4
Hi would you have any pics of your caddy with the wheels in questions just to see the fit ?
jackel
Post by jackel »
Here you go
Nangsdub
Post by Nangsdub »
Smashplant wrote:Got a caddy mk4 now and Iโ€™m putting 17โ€™ alloys on soon. They some aftermarket alloys from a golf mk5.
Iโ€™ve been speaking to my local garage about big brakes and rim sizes.
They said that different rims will have different clearance for callipers. They said that even some 18โ€ rims will not give enough clearance for big brake callipers so I think 17โ€ rims will definitely be too small.
I would have preferred to go for 17โ€ rims personally so that I can avoid fitting low-profile tyres. I think there is a bit of scope to slightly increase the overall outer diameter, but Iโ€™m not sure. Ideally you still want to allow for room to lower it, around 50-60mm?
Ukrutony
Post by Ukrutony »
jackel wrote: โ†‘Wed Apr 30, 2025 4:43 pmHere you go
Hey jackel, Caddy V does use slightly larger tires in diameter doesn't it? Is the speedo still fine as you say and no problems with tire clearances?
On willtheyfit.com it states that with Caddy V 215/55 R17 wheels the speedo will read 4.5% lower compared to 205/50 R17 on Caddy IV.
I would like to mount larger wheels but IDK what to do with speedo then, since it must not under-read :D
https://www.willtheyfit.com?q=QlIfRBlBQ ... lAQlVMFgNR
Never really planned to mod my Caddy until I found this forum
