1.6 td glow plug loom/harness
Nosmokingthecheese
Post by Nosmokingthecheese »
Afternoon you wonderful peeps. I noticed that there has been a broken/frayed wire going to one of my glow plugs. tried to patch the wire but it is so brittle and not much to play with so I need to replace the the loom. Anyone else has to do this and/or can anyone recommend where to get one or a breakers that are willing to sell. Need to get the van back on the road ASAP for work. Thanks for any advice you can fire this way Image
Re: 1.6 td glow plug loom/harness
I'm sure you could pick up a cut piece of engine harness from a breaker and splice it in rather than replace the entire engine harness.
If I'm not mistaken, most modern VW TDI engines use the same glow plug connection.
