Hello all, Replaced my seals on the injectors today along with a new rocker cover and engine is notably louder and ticking a lot..
Injectors have been replaced in the correct order, new stretch bolts torqued to 8NM + 180 and i have referenced a video i took of each code and location beforehand.
The only thing I may have done better is clean the bore holes for them better as I didn't have a vacuum attachment to clean effectively, which leads me to think maybe they haven't seated well?
Rocker cover wasn't OEM and was an Elring rocker cover however fit well. The only other thing i've noticed is the timing belt cover doesn't seem to sit super tight hence me touching it through the video.
https://www.youtube.com/shorts/daS967EEgG8
Injector knocking after replacing seals and rocker cover?
