Caddy 2014 MSF (+F1) retrofit
Kedimajka
Post by Kedimajka »
Hello all. Im new proud owner of caddy 2014.
My caddy is equipped with cruise control and it has DSG transmission. It came with standard wheel.
I bought golf 6 multifunctional wheel with f1 paddle. My question is what else do I have to buy to make it work.
From what I understood new slip ring is needed, is it just multifunctional slip ring? Dsg in this part is not important or is it? Also do I need new steering wheel control modul to make paddles work?
If someone went the same road so can share with me part numbers it would be great.
Roan’s Caddy
Re: Caddy 2014 MSF (+F1) retrofit
Post by Roan’s Caddy »
I am also wondering the same regarding the slip ring.
spacewalker
Post by spacewalker »
Kedimajka wrote: Fri Dec 26, 2025 7:29 pm Hello all. Im new proud owner of caddy 2014.
first check if your SWCM support MFSW
perhaps is no need to replace
https://wiki.ross-tech.com/wiki/index.p ... e_Versions
if you want to install MK7 / B8 MFSW , I have module for that
