I have a 2012 caddy with 1k0907379BL abs module. I did a lot of research before trying this because i dont have vcds and had to go to a shop and show them what to code. When i got there i found out that tpms is already activated in instruments coding. Next we activated the 4C tire pressure II virtual module in CAN gateway. But when we tried to code the abs, it said request out of range and rejected the coding. Bytes and bits i tried to activate in ABS was:
Byte 16 bit 1, 2 and 7
Byte 17 bit 2
As far as i understand, my ABS module with software version H31 0152 should support rka+ via mfd but now that i got my coding rejected, i'm lost
Any help is much appreciated!
Tpms via MFD Activation Failed
Soubruh
