BLS Engine Issue
Posted: Tue Jan 27, 2026 12:23 pm
'06 MK.3 / 1.9 TDI BLS / 198k
Not exactly sure what topic folder this belongs in...
I've recently ran into with the caddy, which I originally put down to shitty fuel.
Van was running on fumes and I filled up at the nearest filling station at the time.
Day or two later the van has issues shortly are starting a new journey.
Van starting juddering and jumping under acceleration - I started and stopped the van (while rolling) a few times to try and get it to reset.
The van battery appeared to get weaker and barely restarted the van - it could have been a bump start while rolling.
I'd since found out the filling station is known for selling adulterated muck for diesel - so i replaced the fuel filter thinking the dirty diesel was the issue.
It drove fine for a day or two afterwards so I thought it was down to the fuel.
It then happened last night for a second time - this time it left me completely stranded.
The van completely failed to restart and the lights even dimmed to a point the hazards wouldn't work.
I have no idea what it could be - bad battery / chassis grounds ?
Any ideas ?
**Small Edit**
I do remember that during the first incident the Tacho dropped to 0 RPM but the engine was still running - so possibly a crank position sensor ?
Any ideas ?
**Small Edit**
